Question about LG WM2487H Front Load Washer
Clothes smell like mold - LG WM2487H Front Load Washer
  • 15,935 Answers
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a “Clean Cycle” available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 07, 2010
After completing a load of clothing, the laundry sometimes has a moldy smell. If it doesn't smell right away, it smells after wearing the clothing and sweat a bit. This is not a body smell - this is a...
It sounds like your leaving the clothes in the washer long after the cycle is finished. Once your clothes smell from the washer they will smell moldy dry.
Aug 19, 2010 | Dryers
My washer smells. After washing clothes the clothes smell and i always leave dorr open between washes
Front loaders are known for building up mold and the smell.
It’s caused by using liquid detergent which is made from animal fat. Use powder. And use the minimum amount.
It’s caused by using fabric softener. Dilute it 50/50 with water.
It’s caused by the water remaining in the tub between washes. Leave the door open to allow it to dry. .
Pull the rubber door seal back and clean the mold off .
Oct 11, 2009 | Frigidaire ATF6000ES Front Load Washer
My clothes smell mildewy. Why?
Affresh is recommended by some manufacturers. You run it through a wash cycle with it.
Oct 07, 2009 | LG WM2688HWM TROMM SteamWasher
I have an older front loading washer Frigidaire and it's now smelling like mold on all our clothes thought it was me leaving clothes in to long but it's not. model #FWT445GES2 serial #XC74463636 . I have...
No recall, Pour 2 cups of bleach into the washer, Wash on HOT water, long cycle. Then wipe seal with dry cloth. This will eliminate the mold smell... To stop it from coming back ALL front load washer doors MUST be left open to allow the rubber seal to dry, Just like you close your shower curtain so it doesn't get musty smelling... 2 hours is about the dry time... wiping the seal with a cloth usually helps too... All located in your owners manual/
Jul 31, 2009 | Washing Machines
Why does our duet whirlpol washer smell like mold. Our washer are
Your washer smells moldy because there is mold growing in it somewhere. To kill the mold and clean the inside of your washer do a hot water wash using no clothes but adding two cups of bleach to the machine. It will also smell better then.
Jul 06, 2009 | Hotpoint Aquarius WD640 Front Load...
The seal around the door molds. And my clothes
Just send me your $19.95 and I'll share my secret with you!!!
Jun 26, 2009 | Frigidaire ATF6000ES Front Load Washer
Bad mold and smell from washwe
i have repaired appliance most my life i tested soaps and softer,at our own family shop,i can tell you that washers do not make mold or bad smells either does cloths its what and how much product that you are pulling in the washer that is molding and smelling and it stays in cloths building up load after load,i have a kenmore he3t front load washer i use 1/3 cup powdered only.armen hammer only. non he only.my washer inside is spotless smells clean and fresh all the time, you will need to clean yours inside out with bleach then use affresh weekly switch to 1/3c powered soap
Nov 15, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Mold Smell in front loading LG Tromm
Make a boil wash (with no clothes and detergents) put in the powder's drawer a cup of bicarbonate of soda. It should clean the machine and move out the bad smell. Good luck!
Aug 15, 2007 | LG WM0642H
My Kenmore Elite He3 sounds like it has water in the tub after washing AND smells of MOLD?
there is always some water left inside the machine and that is probably what you are hearing are you using liquid detergent? if so this is almost certainly the cause of the smell. liquid detergent leaves a nasty slime inside thge machine and smells like drains. put on a boil wash with no clothes and revert to using powder detergent
Apr 02, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
LG WM2487H Front Load Washer Logo
224 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
