Question about GE JRS04 Electric Single Oven
When I try to use the oven on broil or bake the oven does not start when I press the start button. It displays an F3
    President:
  • 1,430 Answers
This indicates a shorted temperature probe. This is easy to check and replace. Here is a link that should help http://appliancehelponline.com/oventempprobe.html
Posted on Sep 07, 2010
I have a Whirlpool drop in stove. I had food in the oven baking and all of a sudden the timer started going off. F-1 was displayed on the front of the stove. Can you tell mean what F-1 means?
F1 - Control Board Failure - Replace control board (clock).
F2 - Oven Temperature Is Too High - Check for welded contacts on bake and broil relays. ...
F3 - Open Oven Temperature Sensor (RTD) - Replace oven temperature sensor (RTD).
F4 - Shorted Oven Temperature Sensor (RTD) - Replace oven temperature sensor (RTD).
Whirlpool Google Search
Dec 15, 2016 | Whirlpool Ovens
The temp for bake says 200c what do I set it on for 375 degrees?
265c63b.jpegPress BAKE and BROIL hi/lo
pads for 2 secs till display
show "SF".
Press BROIL hi/lo pad. The
display will show "F", if yall
want "fahrenheit" then hit
START. Press Boil hi/lo again
and yall will see a "C", if
yall want "centegrade" then hit
START. Most stoves.
If you ha listed a make and model it woulda been much easier.
Sep 21, 2010 | Ovens
I have a Norge 59F-5TXW built-in cooking over which has stopped working. When I turn it on it displays the clock and all, but the Broil will only stay on low and the Bake will not go higher than 180...
F3 may be due to a failed temperature sensor or corroded connections to it, but we also see this problem often due to a failure in the control board, which can be repaired: http://www.fixyourboard.com/boards/7601P177-60.html
Jun 23, 2010 | Ovens
Oven won't heat past 290 after that we get an error message
Your oven is in celcius mode to change press bake and broil at the same time SF will appear then press broil and cooking time at the same time a C will appear press again to toggle to farenheight then press start to lock it in that mode. Some models when you press the bake and broil the sf will appear if it does press the press the broil button to toggle between C & F then press start.
www.appliancehelponline.com
May 21, 2010 | GE Profile JTP18 Electric Single Oven
Magic Chef oven displays F3 everytime the bake or broil button is pushed. Not sure what the model # is. Electrical range.
this could be a an open probe or shorted probe connection.you need to check your temp probe harness to your main board.
there is a chance that you need to replace your temp probe.
last thing would be to replace the EOC
Feb 12, 2010 | Magic Chef Ovens
Digital oven will not turn on, I press bake/broil it reads ''Loc''
Look on the control panel for an icon that looks like a padlock near one of the buttons. Hold that button down until it beeps and that should unlock the panel.
Mar 20, 2009 | Ovens
Instructions for Frigidaire oven missing.
I found the manual online. Apparently my unit is malfunctioning and should work by just pressing bake temp and then selecting the temp...
Dec 02, 2008 | Frigidaire FEB27S5A Electric Single Oven
Broil turns ON when pressing BAKE button on RBS275PD Whirlppol oven
Our Whirlpool oven just started doing the same thing!!!! The Delay Start Time (setting it for one minute ahead) and then Start works just fine.  But we fried the tops of three loaves of homemade bread!!!!
Is Whirlpool just a bad brand for ovens?
Dec 07, 2007 | Whirlpool RBS275PD Electric Single Oven
I need to disable my ovens auto shut off
The control is automatically set to turn off the oven after 12 hours baking or 3 hours broiling should you forget and leave the oven on. If you want to remvoe this feature do the following steps: 1. Press and hold, at the same time, the BAKE and BROIL buttons for 3 seconds, until the display shows "SF". 2. Press the DELAY START TIME button. The display shows "12Shdn" for 12 hour shut off. Press the DELAY START TIME button again. The display will show "no Shdn" for no shut off. 3. Press the START button.
May 21, 2007 | Kenmore 33464 / 33465 / 33469 Gas Single...
Clock Display
Press and hold the bake and broil pads together for 2 seconds. SF should appear in the display. Press the clock pad, it will toggle between 12, 24, and off for a black display. Toggle to 12 and press start...Catriver..post back.
Oct 08, 2006 | GE Profile JT912 Electric Single Oven
GE JRS04 Electric Single Oven Logo
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
