Question about Brother XL-5130 Mechanical Sewing Machine
Lower thread very loose. can=t get even stich top and bottom?? thanks ruth hatch
    Genius:
  • 1,788 Answers
Unthread and rethread the machine according to the manual. Sounds like you do not have it threaded right, make sure that your needle is inserted right (flat side faces away from you) and that it is not bent, replace it if you aren't sure if it is dull.
Posted on Sep 08, 2010
Top stich is normal, bottom stitch is loose
Tighten up the top tension so it will pull the bobbin thread up. The top and bobbin threads should meet in the middle of the fabric.
Apr 20, 2017 | Sewing Machines
How can I fix the top stich
I like to adjust with 2 colors, then you know which is from the spool, and which one is from the bobbin.
Most bobbin shuttles have a small screw to adjust the tension.
It sounds like your upper thread is adjusted too tight, but only if the loops around it (from the bottom thread) are tight and small. If those loops around the top thread are loose, then you need to tighten the shuttle screw. ;)
I notice this happens to me if I change thread types, also if I sew different thickness of cloth on the same settings. I tend to adjust until the point of breaking thread, then loosen the top a teeny bit.
Sep 06, 2014 | Sewing Machines
When iam stiching the bobbin thread is not interlocking with the pool thread ,the straight stich is not stiching properly
Do you have thread in your bobbin?
Is your needle fully inserted in the needle bar?
Is it the right needle for the machine?
Is your needle damaged, bent or dull?
Jul 26, 2012 | Singer 7470 Computerized Sewing Machine
I have a White 7140 quilters sewing machine. I can't find the manual and I am having trouble threading it. The stiches are coming out loose on top, but ok on the bottom. I have tried adjusting the...
try http://www.singerco.com/accessories/instruction-manuals and search by typing in your model number. I couldn't see it there but there are other white machine manuals there so maybe one will give you help with threading. It sounds like the bobbin thread is not under tension, usually if the top is loose it is the bottom thread which is not tensioned and visa versa.
May 30, 2011 | Sewing Machines
My top stich is tight,but bottom is loose of my singer sewing machine.
Think in opposites... the top stitch is formed by the bottom thread tension and the bottom of the stitch by the top. So either the bobbin thread is too tight or the top thread is too loose. Check the bobbin thread first as that is the one most overlook. It should come out of the bobbin without having to yank it hard but it should have a little resistance.
Mar 22, 2011 | SINGER 7470 Sewing Machine
How to adjust tension the underside stich is loose and tangled, the top stich is fine
Usually it is your top threading is not right, double check that. Read you manual carefully, even if you think you know how to thread it, do it over again. Good luck
Jul 24, 2010 | White Sewing 935 Mechanical Sewing Machine
Top stitche is to tight and bottom stitche is to loose
Meaning you have adjusted the tension for the top thread as well as the bobbin?
Use two distinct colors of thread - one for the top and one for the bottom.
Thread the machine with the presser foot up.
The two threads should meet in the middle of the stitch with neither obvious on the opposite side of the seam.
Set the top thread tension to 4 and adjust the bobbin as needed.
May 01, 2010 | Brother CS6000i Computerized Sewing...
Good Morning: My wife has a Husquvarna Viking 320 Electronic Sew Easy. I have tried to re-work the bobin and the thread through the needle. When she stiches the hem on a pair of blue jeans it stiches...
since you are doing jeans it can be on either side so lets start for the beginning, rethread the top thread making sure that the thread went through the upper tension, second remove the bobbin and make sure to thread it through the lower tension(there is a spot on the bobbin case for the thread to go through for there to be tension on the bottom) if the thread on the bottom pulls really easy by hand like there is no resistance then take it to a local dealer and have him adjust it if it feels like there is a pull do the same with the upper thread put the foot down and try to pull the upper thread(don't break a needle) if it has tension adjust the upper thread tension tighter
Oct 19, 2009 | Sewing Machines
I HAVE Kenmore 385 165 24 bobbin case is loose and I can not get even one stich. Do I miss a srew to hold it in a place? Thanks for help.
if the bobbin case is loose and pops out when started. it is not inserted correctly
make sure you hold the clasp when inserting case and hear the slick into place
make sure upper thread is threaded right and the bobbin thread is even
bring bobbin thread up and pull both threads to the back about fou inches
hold threads and stich a few stiches by hand or foot pedal befor letting fo of the thread.
Aug 26, 2009 | Kenmore Sewing Machines
Stiching
It's very possible the bobbin is in upside down and the thread is coming out of the lower tension. Pull on the thread and the bobbin should turn counter clockwise if it is correct . If it turns clockwise, flip the bobbin over , put the thread through the lower tension and try it again. The topside stitch is loose either because the lower tension is loose(or non-existent) or the top thread is too tight.
sewman7
Jul 06, 2008 | Janome 4623 Mechanical Sewing Machine
Brother XL-5130 Mechanical Sewing Machine Logo
63 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
