My Frigidaire Galaxy Washing maching will not allow water into the tub.
  • Washing Mach... Master
  • 43,501 Answers
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Posted on Sep 08, 2010
Is it normal to have substantial amount water remaining in the washer after final spin?
Hey friend, thank you for allowing me to assist you!
It is normal to have water in the tub after your Frigidaire washer has completed the final spin cycle. The water that is in the tub is there to help prime the pump. Hope this information is helpful. -Matt
Jul 27, 2014 | Frigidaire Affinity ATF7000E Front Load...
Water intake valve
CHECK THE HOSE RUBBER SEALS GASKETS
Apr 13, 2014 | Frigidaire Affinity ATF7000E Front Load...
The water will fill the tub, agitation will begin,
Yes, you have it figured out...
The soleniod valve is bad.... here is a tip that will help...the problem you have is with the same part but the opposite problem...
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
heatman101
May 05, 2010 | Washing Machines
Water enters after washing is over
If it's letting water in whle the machine is not in use, I would say you have a stuck water valve. It can allow a little water to tickle in, and over time, it'll fill up the tub
Apr 05, 2010 | Frigidaire ATF6000ES Front Load Washer
Tub is filling with water while off. is it the control valve inside the washing mach?
You need to check your water level switch. Make sure the clear hose that runs from the tub to the control panel is clear, not kinked or clogged and has not come loose at either end. Hope this helps
Mar 21, 2010 | Maytag Ensignia MAV2757AWW Top Load Washer
Hotpoint First Edition washing maching won't spin
hello any spin problems could be down to the module circuit board
shaun
Aug 02, 2009 | Washing Machines
Neptune-is water supposed to remain, after wash is finished, between tub and outer shell
if you hear water when you spin the basket,that is the front tub balance ring.it is filled halfway with water in order to assist mach in balancing load.that is a normal sound.the mach may also leave some water between the basket and outer shell depending on lengh of drain hose.as long as the clothes do not come in contact with the water it is fine.
Sep 27, 2008 | Maytag Neptune MAH5500B Front Load Washer
Leaking frigidaire top load washer
yes there a seal under the tub ring make sure tub ring has all the snaps in place
Mar 01, 2008 | Frigidaire GLWS1233A Top Load Washer
Washer spins but not enough to extract water from clothes or tub.
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Dec 31, 2007 | Washing Machines
Washing Machines Logo
60 people viewed this question
Top Washing Machines Experts
