SOURCE: assembly instructions for disney princess
Here is a picture I finally found on ebay It was so frustrating trying to find these so I wanted to share with you
SOURCE: need instructions
Suggestion..
Have a look on Ebay..
Find somedbody that is selling, and also shows there email or contact number.
Try and see if they would be prepared to scan a copy in for you.
Most people would be prepared to do this as good nature.
I know I would.
SOURCE: I have a dora and puppy tent to put over my
First you need to open the tent up so you know what your working with.Then find the two longest poles that go into the holes and cover the tent.To connect it to the bed you will need straps to either hold in down or connect it to the bedset
SOURCE: Hello. I have a disney princess bed tent that my d...
I got a Princess tent with sleeping bag from Disney foer my daughter thisevening and I too thought the instructions were missing ( foud this site upon searching for it online) until I looked at the hanging label sewn to the pink satin cover for the collapsible posts. look on both sides. You will see the instructions in 5 steps. in case you don't have it,
1, unfold tent and lay bottom flat on a surface,
2. straighten poles and snap together at joints,
3. Insert poles diagonally into sleeves on top of tent.
4. place the end of each pole in pocket on bottom corners of tent,(poles will bend as this is being done.)
5. Hook corners of rain fly into four loops on sides near the top of the tent.
http://www.youtube.com/watch?v=kt5Kw2qxe9Y&feature=related
the above video also explains about snapping the poles. goodluck
hope this helps
SOURCE: i have a disney princess
Remove the tent and poles from the packaging. Select an indoor area with a high ceiling or an outdoor area without overhead obstacles. The poles are not excessively long but they will be difficult to assemble without space. Lay the Princess tent with the floor on the ground. Pull on each corner to tighten the floor. Assemble the two tent poles by inserting the male sections into the metal ferrules. Slide one pole through each of the diagonal sleeves. Place the end of each pole in the fabric pockets on the corners. This will flex the poles and raise the tent body. Place the fabric roof on top of the tent. Attach the hooks on each corner of the roof to the loops on the top of the pole sleeves. The roof fabric will stretch tight and cover the ventilation gap in the tent ceiling.
