Question about GE MiniCam Pro HO98067 Webcam
Mac?? Will this camera work with a mac? I am able to hear sound from the mic.
    Scholar:
  • 143 Answers
From the 'net:
http://webcam-osx.sourceforge.net/cameras/camera.php?id=636
Posted on May 14, 2008
BUILT IN MIC WILL NOR WORK, but was ?
Have you tried system restore to a period when your MIC worked just fine and see if this helps?
Oct 06, 2017 | Apple Isight Web Camera M8817ll/a
Peavey 16 fx
are you going from the board to a 'mic' input, or a 'line input' on the Mac? you will need to attenuate the signal to a mic input. try reducing output from the board by 50% and reduce the input level on the Mac by 50%, and see if the distortion is lessened or eliminated. From there balance board output to Mac Input until you find what sounds good outta the Mac.
Oct 16, 2013 | Music
No output signal for vocalist live 3
If the mic is a low Z- mic, that might be the issue. Check the mic straight into the sound card of the mac and see if it works or if it is shorted. Is there a switchon the mic? it may be dirty.
Jan 28, 2012 | Music
The nexxtech hd portal 720p installation disk comes up on my mac desktop but when i click on it, it goes in to a file and i can't seem to instal anything everything either has no default application...
I have the same unit and it works fine on my Mac Mini. All the stuff on the disk is for PCs, not Macs. You don't need to install any drivers for this webcam when using it with a Mac. Just plug it in and it will work. If you are using it on Skype, for example, you have to select "preferences" / "sound" and then change the "input" to USB. That will make the microphone work. You can adjust the mic input volume in your Mac "System Preferences" / "Sound." This is one of the few cameras out there with a mic that works through the USB, so don't give up on it too easily!
I get a very slow frame rate with this camera, but I've had the same problem with every other webcam I've plugged in!! Otherwise the quality is fine. If anyone knows why my frame rate is so slow, I would appreciate your ideas!
Jul 09, 2011 | Computers & Internet
Got a MacBook Pro...problem recording with external microphone
Hi
... sound issues like you are having do pop up occasionally ... the best thing to do is to reboot the system ... sorry.
Cheers.
Apr 29, 2017 | Apple GarageBand Jam Full Version for Mac...
How to use a condenser mic on a mac/in garageband?
If you are sure that the microphone and the cable is OK, it could be that you're phantompower is to low.
Normally you need 48 Volt, you can check that with voltage meter between pin1-2 and 1-3 from the XLR.
regards,
Gerard
Jan 22, 2010 | Audio Players & Recorders
How can I make an MP3 recording of my voice on my PowerMac Mod. M6498 desktop?
You need a mic input. I did a slick voice-over on my G5 by using the mic in the iSight camera. It's a very good quality voice mic.
If you don't have that, purchase iMic from a local computer apple store. This will allow you to hook up a mini stereo plugged mic to your computer with a USB connection and you can record from within Imovie and also from the system preference control for sound input. Then copy the sound file onto a CD as an mp3..
Nov 29, 2009 | Apple Power Mac G5 Desktop
Web cam and IM fine between pc and mac but no sound heard on pc
can you try to record anything in the mac computer to make sure it is working or not
Oct 01, 2008 | Yahoo Messenger
I have a MAC MINI AND MY USB MIC IS NOT WORKING ON IT.
This product uses native driver support on a Mac. No Logitech Mac Software is available or required.
It should work instantly check your sound settings the mic might be on mute or your useing wrong input on your program.
Jan 14, 2008 | Logitech USB Desktop Consumer Microphone
Mokrophone is not working
Found the problem... What Apple has is a line-in port...it requires a pre-amp to boost the signal of your mic. A PC likely has a mic-in port.
They're different ports...very similar but they accept different levels of input. Apple likely wants you to use their built-in mic for mic use and the line-in port for line-level audio sources.
Thsi appears to be our solution... Griffin iMic / USB Audio Interface
What a pain.
Oct 20, 2007 | Sennheiser BINAURAL HEADSET :unitsize...
GE MiniCam Pro HO98067 Webcam Logo
387 people viewed this question
Top GE Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Ricky Ostrom
Ricky Ostrom
Are you a GE Computer and Internet Expert? Answer questions, earn points and help others
