Question about Samsung Computers & Internet
I just bought a Samsung Netbook, and it says to charge it completely before using it the first time. None of the information that came with it tells me how long it takes. How long should I charge the battery from completely dead?
    Sergeant:
  • 172 Answers
You will see the battery indicator flashing if its still charging normally it will stop flashing or it will be solid green/orange once its fully charge
hope this helps
Posted on Sep 07, 2010
I use samsung netbook nc110, it works normally until I play a video and the screen goes black and won't come back to normal. I bought it 9 months ago and this begin happening last week. Any solutions?
You can use an external monitor to test it. If the external screen does not display anything, then your GPU and or motherboard is dying. If your netbook works good with the external monitor, then your screen is dead.
You can check the operating system and application using this Norton Utilities:
http://download.cnet.com/Norton-Utilities/3000-18512_4-10907620.html
Mar 09, 2014 | Samsung NC110A02 Netbook
Using while charging?
SURE BATTERYS GET DESTROYED BY HEAT I WOULD RECOMMEND PULLING THE BATTERY COMPETELY OUT IF YOU ARE GOING TO LEAVE IT ON AFTER ITS CHARGED. IF YOU ARE GOING TO LEAVE IT RUNNING FOR A WHILE
May 08, 2013 | Samsung N150 Netbook
Samsung N145 Plus battery charge failure
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Sep 03, 2012 | Samsung Computers & Internet
My Acer aspire one just stopped working for no reason. I plugged it in to charge it but none of the lights come on, and nothing happens when I hit the power button...
Assuming that the AC/DC Power Adapter is not faulty no LED lighting up at all and no image at all on the screen might mean a power management fault on the motherboard.
First try removing the battery underneath the netbook. Then connect the netbook to the power cable without the battery installed. If the netbook powers up without a battery installed then the battery is probably faulty most likely with completely depleted and unchargeable power cells. if so you will almost certainly need a new battery and some little known guidance on the correct management of a netbook or notebook battery (see below). Dead batteries tend to generate a more than normal amount of heat.
If the AC/DC adapter is not faulty and using the netbook without a battery does not help then check the DC power jack where the power cable connects to the netbook to see if the jack is loose or detached from its original solder point on the motherboard.
If the none of the above are the cause of the problem then the motherboard probably has a power track or capacitor fault which might be repairable (as would a loose DC jack) but these types of fault even if successfully repaired can easily come back and the cost of repair might be high compared to the value of the netbook and not worth it since a brand new state of the art netbook with a full warranty would not be very expensive.
Many users take an incorrect approach to netbook/notebook/laptop battery management. These batteries are rechargeable and are only supposed to be connected to the power cable when their cells are low or depleted. Once the cells are fully charged the power cable should either be disconnected and the computer used on battery power alone or the battery should be removed and kept for when battery powered use of the computer is next needed.
Once a fully charged battery is removed the computer can be used directly connected to the electricity without the battery installed.
A disconnected battery needs to be reinstalled and recharged from time to time if it is stored for long periods of time, because the charge in its power cells very slowly dissipates even if is disconnected from the computer.
Nov 08, 2011 | Acer Aspire One Netbook 8.9" Notebook
How much time I have to charge time Samsung 5722 phone for the first time???
hi once your phone is official drained, make sure that it is turned off then charge it. just let it charge and tell you that it is full. if you want to time it if you have the fast charger it is most like to complete in 4 hours. it you have the slow charge about 6 hours
thanks
Aug 25, 2011 | Samsung B5722 Cell Phone
Basically my samsung n145 netbook wont power up unless its connected to the power supply and also i cant disconnect the power supply when fully charged as it cuts the laptop off straight away :( cheers
Replace your battery to solve this trouble.
Get a battery from a FixYa.com advertiser or anywhere computer batteries are sold.
Thanks for your question @ FixYa.com
Jul 28, 2011 | Samsung N145-JP01US Netbook
Dear Sir/Madam, I bought a Asus Netbook (ASUS 1201N) last month. I re-charge my netbook about 6-8 times. I always charge my netbook more than 8 hours like the point out in the user guide. Now, I have a...
Yes you can use it with half charged battery.
Sounds like you conditioned the battery when new which is a good thing. It will keep your battery in good shape now that it has been conditioned correctly as per your user manual.
Just remember that leaving your battery charging for extended periods of time will reduce its lifespan. When it says the battery is charged take it off the charger.
Aug 17, 2010 | ASUS Computers & Internet
The left hand hinge cover has broken..can I get a replacement?
You will have to return the laptop to where you bought it and tell them what you want done. They will send it off to the manufactuer and replace the broken hinge, but you may be charged a small fee.
Hope this helps ^^. Please dont forget to rate, Thanks
Mar 03, 2010 | Samsung N13013B Netbook
Samsung NC10 will not boot up
Take it back to the store and get the manufacturers to fix it.
Jun 13, 2009 | Samsung NC10-14GW Notebook
Computers & Internet Logo
183 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
