Question about Car Audio & Video
On a 2007 altima the cd player gives me a temp/mech error it will not load or eject a cd
ginko
  • 19396 Answers
SOURCE: cd error message
Try to disconnect battery contacts and connect it back. Check also if there is an emergency opening device. In some model you have a pin hole underneath the cd tray. push a staple tip inside the hole, and this will release the cd.
If the tray still does not open, you may need to have a repairman opening your stereo at your local service point.
Regards
Posted on Apr 03, 2008
  • 232 Answers
SOURCE: CD Player not workinig
Try using a cd player cleaner disk, then remove the radio fuse in the fuse block wait about five minutes then re-install. This is done to restart the radio. If that don't work disconnect the negative from the battery, wait five minutes then reattach, this will restart the cd player for sure. This will also restart the car computer just so you are aware.
Posted on May 13, 2009
localwonder
  • 6784 Answers
SOURCE: 2007 nissan maxima will not load or eject CD's...or even play the
Hi, this is a common issue within car CD changers. the load motor go through lots of trauma during the life span that i usually 3 to 5 years. the load motor operates everything in the changer. it works the load tray and spinning of the disc as well. when this motor is out, the changer will be rendered useless. replacing the load motor will fix this issue or, you can just purchase a new changer and save a lot of money.
Posted on May 21, 2009
SOURCE: 2004 cadillac srx cd player jammed
I had the same problem. disconnect the battery cables. then reconnect them. this will reset the cd player and it should relaese all your cd player problems.
this happened twice to me and the above worked fine both times.
Posted on Aug 24, 2009
SOURCE: 03 expedition CD player Error
Turn key switch on and off, Remove Fuse's 7 and 31, turn Key on and off , Then put back the fuse's and it should work again!
Posted on Nov 12, 2009
Why can't I load a CD in the player?
The deck's electronics are shot - Will cost a fortune to have repaired if even possible. Time to move on.
Sep 21, 2015 | 2009 Chrysler Town and Country
Cd player in my 2007 nissan altima 3.5sl loads, but will not play
check the format needed by the cd unit to read the cd's.
Jan 04, 2014 | Cars & Trucks
My CD PLAYER SAYS TEMP MECH ERROR HOW TO FIX IT
You might TRY un hooking your battery for about 30 minutes, and hook the battery back up. That usually resets the software.
Aug 18, 2012 | 2009 Nissan Altima 2.5
My dodge journeys cd player say
My cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix this
Jan 03, 2012 | 2010 Dodge Journey
Cd player shows error "Mech"
MECH message means a "mechanical communication error", when display on your car cd player indicates that there is a problem with cd player that has do with the mechanism which is jammed up.
You need to open up the player and clean out the dust inside.
Good luck.
Oct 12, 2011 | 2007 Dodge Nitro R/T New Cars
Hi, this saturday i tried to change a cd from my honda civic copue 2006 stereo, but the cd didnt came out, it just made some noises and a message came up, mech error... please help!!! I push the eject...
If you gently push another cd in the cd player (not all the way but most of the way) it will either eject the cd or with your other hand hit the eject button and the other cd should come out. Mine did this but unfortunately it will not load cd's now so I don't if that made it worse or if it was already going downhill :(
Aug 16, 2010 | 2006 Honda Civic Hybrid
It will not load cd or dvd it keeps coming up
The loading mech or poss. the read portion of the disc player is out of whac. In other words the cd dvd portion of your deck is defective and short of having it repaired by a techinition there isnt much you can do. Its a **** shoot but you may be able to unplug the unit let it set for a few minutes and plug it back in may rest the mech., but like I say its a **** shoot. Sounds like its time for a new deck or a trip to the repair center.
Jul 30, 2010 | Dual Electronics XDVD710 Car DVD Player
Disk tray wont open
Either loading belt for mech has gone meaning not unloading for door eject,or door belt has gone
Dec 28, 2008 | Sony CDP-XE570 CD Player
Cd player wont eject
You can try pressing the reset button on the display, it is a very small indented button that you need a paperclip or something smaill like that to press it. This is the only user action that can be done.
Do you hear the cd mech making any noise at all (gears trying to turn, motor running)? if not, you may have a supply voltage out for the cd mech, bad ribbon cable, defective loading motor, or one of several other possibilities.
If you hear something trying to happen, it will most likely be a jammed up mech. There is a plastic piece inside the mech that is very difficult to get to that may need to be replaced or at least re-aligned.
If you are not familiar with these type of mechs, you really should not try and fix it, you will most times cause more damage to it.
sorry there was not better news for you. let me know if resettng helps or if you feel you can fix it yourself, I would be glad to offer more help.
Jun 12, 2008 | Kenwood KDC-516S CD Player
CD Changer MEC ERROR
i have the same problem!!!
do anybody knows how to fix it??
thank you very much
Oct 26, 2006 | Sony DHC-ZX50MD Shelf System
Car Audio & Video Logo
474 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
