Question about Sharp EL-334AB Calculator
I have a Sharp Elsi Mate EL-334A model caculator and my display is still not working right even after installing a new battery, is it toast? Or, is there something else wrong? This has been a really good calculator and I would hate to have to toss it out. Thanks for your help!
Where is the battery door to replace battery on my Sharp Elsimate EL-334A calculator?
Posted on Mar 20, 2015
If there is an answer for my question (instruction manual for Sharp Metric converter, EL344G) how to I find the answer?
Here is a link to the Sharp customer support website. There you can find manual for their calculators. Some manuals are available for downloads, other are not.
Jan 19, 2012 | Sharp Office Equipment & Supplies
HOW DO SET TAX RATE ON SHARP ELSI MATE EL-2125
Easy. Press M- key [has RATE SET] above it. This will shown your current setting say 17.5. Amend to 20.0 and Press M- key again. Rate should now be set at 20%.
Test by entering:
100 and pressing +TAX key - Answer should be 20.
100 and pressing -TAX Key - Answer should be 83.33
Jan 04, 2011 | Sharp EL-330AB Calculator
How do i get rid of the "p" on my sharp caculator. I have a EL-520W
On the back of the calculator, there is a little "reset" hole. Use a pen and press it into that hole for a few seconds, then release. You should now be able to turn on your calculator as if it was brand new from factory without the "p".
May 19, 2010 | Sharp EL-520WBBK Calculator
I have a Sharp elsi mate EL-1611P and I am trying to get out of the P.E mode. How?
Push as many buttons at the same time as possible. Throw the calculator on the floor. That should do it.
Oct 01, 2009 | Sharp EL-1611P Calculator
The calculator is intermittent: Most of the time
Not knowing what to do, I tried anything that could possibly help:
I installed fresh batteries and I pushed the reset button on the back of the calculator (Sharp EL-546L) and finally, it work all right after more than 5 years I own the calculator and where it did work correctly for 5 minutes. I tried the reset button in the past (long time ago) and it didn't work. This time it worked because, maybe, I've used fresh batteries.
Marcello
Jun 03, 2009 | Sharp EL-738 Scientific Calculator
Setting tax
If the model is EL-2125 , and not 2125C or 2125E the following will work
1)switch on
2)press CE and then CA (you should see 0. with small 00 in top left hand corner but nothing else)
3)press M- button (rate set button),current tax rate 17.50% will appear with tax at left hand side
4) type new rate eg 15.00 (making sure to hit the decimal and two zeros, tax at the left and % should still be on the screen)
5) press M- (rate set button) (small 00 will appear in top left hand corner)
6) press = ( new rate and G will appear small 02 in top left hand corner and = sign below it)
hope this works for you, please let me know either way
David
Jul 31, 2008 | Hanns.G Corporation HW191D 19" LCD Monitor
Errors??
Sounds like the printwheels are out of time. Sorta of major repairs. gears on side of printer have to be lined up in proper areas. there are small black arrows on the gears. Best bet is look at a working machine and try to line up. Machine may not be worth the time unless you jsut want to try it. Sharp uses the same printers in many different models.
Jun 21, 2008 | Sharp EL-1611P Calculator
SETTING TAX RATE
On your Sharp press
CA
C.CE
C.CE
RATE SET(+TAX Key)
175(No decimals for they are not taken into consideration)
RATE SET(+TAX Key)
To check if all went well press
CA
C.CE
C.CE
RATE RECALL(-TAX Key)
It should read your tax rate.
May 01, 2008 | Sharp EL-330AB Calculator
Need to change tax function on Sharp EL-334A
I had the same problem and finally figured it out. Here's what you do:
Press C-CE twice
Press +TAX (Rate set)
Key in your new tax rate as an integer (e.g. 5)
Press +Tax (Rate set) again
Press C-CE
Then you're ready to calculate with the new rate!
Now what's the GT button for?
Nov 19, 2007 | Sharp EL-334AB Calculator
Display not showing correctly
Did this machine get wet? Or was it dropped? It sounds like the lcd display is either damaged or defective! John
Jun 12, 2007 | Sharp EL-334AB Calculator
Sharp EL-334AB Calculator Logo
420 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
