Question about Craftsman Garden
27 hp koler no fire to plugs - Craftsman Garden
  • 148 Answers
How have you verified the no fire condition? In other words have you removed a spark plug and held it against metal to see if you are getting a spark? If you have then I would suspect that your magnetic coil is bad.
Posted on Sep 07, 2010
Im not getting fire to cyclinders to my 27 Hp kohler engine,I replace key switch.
Check your ignitions coils under your engine shroud and you can do that by pulling your spark plugs and leaving those intact in your spark plug boot. make sure your plug is meeting your engine block and turn you ignition key on to start and check for spark or go to your auto parts store get a ignition coil tester. they can be expensive depending on the store. If no spark then you need a new or used coil. Try Ebay that.
Jan 12, 2018 | HP Garden
13 HP TECUMSEH BACKFIRE
ck your mounting bolts on the ign coil located just under the cooling fan cover , i suspect it's come loose throwing your timing out , see my U-tube video on replacing coils on koler engine , for details on how to reset proper gap using a paper match pack , will be near the same for your engine
Feb 24, 2015 | Garden
I have a 16 Hp koler command that surges at low or high rpm
check for muck in the carby bowl tending to block the main jet.
Jun 13, 2013 | Cars & Trucks
Need to know how to wire koler command voltage regulator
We do not have this wiring diagram. Sorry.
May 14, 2013 | Cars & Trucks
Can the solenoid on the carburetor be bypassed
Yes you can by just slicing the needle off inside, however this is an anti fire solinoid if removed you can and will get very loud bangs when you switch the engine off due to unburt fuel entering the hot muffler
Mar 18, 2012 | Garden
I HAVE A 6000 CRAFTMAN WITH 26 V KOLER STARTS RUNS WITH THE CHOKE OUT . AS SO AS I PUSH THE CHOKE IN IT STOP RUNNING
Its a fuel problem. Remove fuel line from carb. Remove fuel cap, vent in it is common problem. A small hole in cap.
Aug 31, 2011 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
Bobcar 225 nt 16 horse koler motor It will spin over but will not start, no fire to plugs
make sure the shut off isnt grounding the spark out
then check the plug for damage
next check the coil wire for cracks and gronding
and then the coil
Jul 26, 2011 | Miller Wildcat 200 Welder Generator...
The motor is osilating up and down with good oil, fuel.
make sure your spark plug and air filter are clean. typically when this happens the spark plug isn't firing correctly.
Aug 31, 2010 | Briggs & Stratton Intek Snow Horizontal...
SPARK PLUG TORQUE
Torque for the spark plugs is 27 ft-lbs
Firing order is 1-5-3-6-2-4
Jan 03, 2009 | 1998 Jeep Cherokee
Garden Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
