Question about Brother HL-5240 Laser Printer
Hi Today one of the two HL-5240 decided it wouldn?t print, with a solid RED Status LED. After trying a few of the press-here-on-off solutions, it happens it was a paper jam. NOW the printer still will not do a complete power ON cycle. The Status light will go green, if I try to print, it will go solid yellow and do nothing ? not a sound. If there is something still jammed, I can?t find it. Can?t get it to print a Status (start up/Go) page either. If I press the Job Cancel button the status LED will blink red/yellow/green continuously. I?ve interchanged the toner and drum from the working printer to this printer and can?t get it to work either. Thanks for your help Luis
  • lcajigas Sep 07, 2010
    Hi tbreeze47,
    Thanks for your reply. No I dont think is a toner count problem, I never had the toner or drum led on to begin with. Anyway I have used 2 different toners/drum and still wont do a full start up when you turn printer on.
    thanks
    Luis
  • lcajigas Sep 08, 2010
    thanks
  • 666 Answers
What you will want to do is go into the users guide and find the reset factory defaults option usually it involves holding a button or two while starting the device however are sometimes very different
hope this helps
Robb
Posted on Sep 08, 2010
  • 3,083 Answers
Here is an excerpt from pricegrabber.com:
Found that unit will run fine past its replace date just fine. you must reset the unit and look at a message that warns the drum life is coming to a close. We have done more prints like this then when the 1st message appeared. It looked like these would be compatible with dr-510 Not true. What a expensive lesson.
Here is how to reset it:
http://www.ehow.com/how_6875410_reset-toner-count-brother-hl5240.html
Good luck, hope this helps, and thanks for using FixYa.
Posted on Sep 07, 2010
Have a problem with HL-5370DW Status LED is red &
Hi, if you status led become red and only that light is on must be 1 of the following problems:
1.- Front Cover is opened
2.- Memory Full
3.- Option Tray is installed too much
4.- Print Overun
Sep 13, 2013 | Brother HL-5370DWT Laser Printer
My Brother 5240 laser printer has a red status light when i turn it on. I hit cancel job, and the light turns green. however, when i print a file, the file goes into the print queue for a few seconds then...
It may some paper jam inside your printer . open the front cover pull out the cartridge and look any jammed paper is there or not. if not the the problem may came from your toner drum.
Nov 25, 2009 | Brother HL-5240 Laser Printer
What does the red status light mean.
Unplug the Printer and again Turn it back ON after few minutes. A Solid Red Light Status means that, more than often it is for Paper Jam.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 04, 2009 | Brother HL-5240 Laser Printer
Hl 5240 i installed new toner cartridge still status is solid red toner is solid yellow
The new toner cartridge is not properly installed. Remove the toner cartridge and reinstall it.
Download and read the service manual
http://ekse.pp.fi/Fixya/sm/BROTHER%20HL-5240,%20HL-5240L,%20HL-5250DN,%20HL-5270DN,%20HL-5280DW%20Service%20Manual.pdf
Page 3-2 to 3-6 has the instructions on how to properly install the toner cartridge.
The page numbers are 63 TO 67 if you look at the page counter.
Oct 08, 2009 | Computers & Internet
Status light solid red not printing
Press the menu button for 20 sec and then try to turn on the printer
Sep 15, 2009 | Brother HL 5140 Laser Printer
Toner light and Status light stays on
well it may need to be completely reset or you could try seeing if it is jammed or stuck in some way
Sep 11, 2009 | Brother HL-5240 Laser Printer
All lights on solid, not flashing, wont print
Recommendation: See HL-5240/HL-5250DN USER'S GUIDE: Section (4), Control Panel: LEDs, (light emitting diodes) starting on pg. 44.
Apr 14, 2009 | Brother HL 5250DN Laser Printer
HL-5140 Brother laser printer red status light remains on.
The red lite indicates one of the following needs to be looked at:
Cover open (Front cover) Close the front cover.
Cover open (Jam clear cover) Close the jam clear cover of the fuser unit.
Memory full - Press the go button.
Print overrun - Press the go button.
Clean drum unit - Clean the corona wire.
Jan 15, 2009 | Brother HL 5140 Laser Printer
New HL-5240 printer red status light upon powering up
My HL-5240 did the same thing, Here is what I found:
Look at the back of the printer. Pull down the back cover. Look to the right and the left of the exposed internals of the printer and there should be another handle/knob you can pull down. Pull these both down simultaneously and check to make sure there isn't a piece of paper in there! This was a shock to me! My office printer was held up for days until I found this hidden door in the back! I felt like an idiot that it was from a stupid paper jam!
Jul 22, 2008 | Brother HL-5240 Laser Printer
Brother HL-5240 Laser Printer Logo
234 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
