Question about GE (PSS26MSRSS) Side by Side Refrigerator
Model # tfx25zryd aa drain in bottom freezer is clogged causing water to freeze in bottom & now leaking to the floor, How to unclog drain
  • 1 more comment
  • mrssweetange Sep 07, 2010
    Do I have to unplug the refrigerator to let it thaw or just open the freezer door, if so approx time to thaw with door open
    Okay. I'll let you know how things turned out when I have another free day to tackle this problem.
  • mrssweetange Sep 08, 2010
    Okay I want to get something straight. The water is dripping from a clogged hole in the bottom of the freezer section, not the refrigerator.It has a frozen block under the tray that when the water is running to make ice or etc., it just drips over the ice, out the freezer side onto the floor. I usually keep a whammy to catch the excess Now does your instructions still apply?
  • 17,970 Answers
1. Turn off the power to the refrigerator. Do this by either unplugging the refrigerator or turning off the power to the circuit where the refrigerator is installed. 2. Locate the drain tube. If you cannot locate the tube inlet, try looking in your owner's manual. You can also consult the GE website for information about the drain tube inlet for your particular model. A common location for GE models is in the bottom of the refrigerator, but it may be located elsewhere.
3. Insert the end of a thin plumbing snake into the drain opening. Push the snake in as far as it will go. Move the snake back and forth once it is inside the drain tube to break up any clogs inside.
4. Mix 1 teaspoon of bleach with one pint of warm water. Use a turkey baster or cooking syringe to inject this solution into the drain.
Also, could try this for the drain is behind the back panel in the freezer at the bottom. Sounds like it is frozen over which is pretty common. Will need to remove panel and thaw out drain by running hot water down. You can use a putty knife to break up ice first. Make sure you get all ice around the drain above and below the thin aluminum tray at the bottom. After the drain is free don't be alarmed if you get some water on the floor because the drain pan may not hold all of the water you ran down the drain. Not anything you can do to prevent this on this model.
Hope helps.
Posted on Sep 09, 2010
  • GE Master
  • 43,501 Answers
To unclog the drain you will need to shut the refrigerator down and completely defrost it and unfreeze the drain. Then take a stiff wire and run through the hose to the bottom of the fridge where it comes out into the pan. Some hot soapy water may help flush the **** out...compressed air if you have an air compressor also works good... I use a CO2 tank....the very high pressure works wonders...
Then before starting the refrigerator back up, take and wrap a copper wire around the defrost coil and stick it into the tube to keep it from freezing...
I explain exactly how to do that in this tip...
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 08, 2010
  • GE Master
  • 11,800 Answers
Empty the freezer and let it thaw. Once the freezer is at room temperature clean the inside thoroughly. Then take a long zip-tie  (or something similar - long, bendy but not soft and without sharp corners) , insert it in the hole and twist it, pull it out, clean the muck it accumulated and put it back. Repeat until the zip tie stays clean. Finally get some sink unclog solution in a syringe  - 25 ml should be enough-  and pour it down the hole, wait a few minutes then add some water till it starts to leak on the floor from the back of the fridge. If the water pours easily in the hole you will know it's unclogged.
Posted on Sep 07, 2010
  • 1 more comment
  • Azrael SRL Sep 07, 2010
    Unplug it from the wall, every single piece of ice from it must melt before you do anything, otherwise you might puncture the plastic hose that is attached to the hole and get yourself in a lot of troubles - replacing it is very difficult.
    BTW it will take about 4 hours for a full thaw if you do it in the middle of the day - shorter if you live in a hot climate.
  • Azrael SRL Sep 08, 2010
    Yes, they still apply.
My bottom drawer freezer is accumulating a sheet of ice
Your defrost drain line is clogged or frozen so the defrosted water is leaking into the freezer compartment and freezing into a ice layer in the next cooling cycle. Get your defrost drain line unclogged.
Sep 16, 2014 | Whirlpool Refrigerators
Plugged drain
Need to completely defrost freezer. hot rags, hot water, paper towels, etc. Until you get all the ice out you don't have a chance of unclogging the drain. Could be just ice clogging it too which in that case hot water will solve that as well. If it's something else clogging the drain, I've used a mini bottle brush to unclog them or even a stiff piece of solid wire.
Mar 18, 2013 | KitchenAid KFCS22EVMS Stainless Steel ...
My maytag refrigerator is leaking water from the freezer drawer. what do i do
More than likely the drain line coming from your freezer is clogged. Take everything out of the freezer. The drain line should be right below the evaporator. Usually in the bottom back of the freezer. First try pouring hot water down it then try anything long and skinny to unclog it. A lot of the time it is just ice clogging it so the hot water will do the trick though. This can happen simply from the door being left open on the freezer or something more serious like there being a problem with the defrost cycle on your freezer. Just be careful after you unclog the drain line to not leave the door open and if it starts being a problem again soon then you may want to call a technician.
Mar 18, 2013 | Refrigerators
Water drain tube is plugged, leaks inside the frig
Water accumulating on the ceiling of the refrigerator is usually caused by a clogged drain in the freezer section beneath the evaporator. The clogged drain will cause water from the self defrost cycle to leak into the divider between the freezer and refrigerator. This water may then freeze and cause condensation build-up on the refrigerator ceiling. The solution to this problem begins with unclogging the drain. It may also be necessary to remove the entire freezer/refrigerator divider to thoroughly dry the insulation in the divider. Occasionally the insulation needs to be replaced to prevent a recurrence of the problem.
Mar 29, 2010 | Refrigerators
Water pools and freezes at bottom of the freezer. When tray is full water leaks out of freezer onto kitchen floor.
I am uncertain as to what you mean by "when tray is full"? However, you probably have a clogged drain in the freezer compartment. During the defrost cycle, which usually occurs every eight hours, defrost components (defrost thermostat & heater(s) ) melt the ice that has accumulated on the evaporator coil in the freezer compartment. The water from the melted ice drains through a hole in the freezer compartment (behind the freezer's rear panel) and accumulates in a drain pan below the refrigerator. This water should evaporate over time, whereby you should not have to regularly empty the drain pan. If the drain hole is clogged (usually from algae or other debris, etc.), the water finds another path to flow (which is inside the bottom of your freezer compartment). This water will usually freeze. Water will then flow toward the front of your freezer compartment and out of the door on to the floor when you open the door.
Contact an appliance service company to unclog your freezer drain. Also have them check your defrost components (thermostat & heater(s)).
Feb 15, 2010 | Frigidaire Refrigerators
Freezer malfunction
Drain hole is clogged behind the panel that covers the coils. I found a peice of solder blocking mine. Water was freezing on the bottom of the freezer and leaking out to the floor.
Aug 04, 2009 | Maytag MSD2756G Side by Side Refrigerator
Samsung Fridge Freezer leaking water
hi August.
Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leaking out of the freezer and refrigerator.
3 common refrigerator problems you can easily fix yourself
The freezer drain hose will drain the defrost water into a drip pan at the bottom of the freezer. When this pan becomes full, it will leak water onto the floor. This is a regular maintenance task whenever the freezer defrosts. Empty the drip pan during the defrost cycle.
How to Fix Water Leaking From the Bottom of Freezer
Why is my fridge leaking water on the floor? If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.
SOLVED Water leak in refrigerator Refrigerator
Dec 03, 2017 | Samsung CoolTech Plus / Basic Bottom Mount...
Clogged fridge drain tube
The drain is behind the back panel in the freezer at the bottom. Sounds like it is frozen over which is pretty common. Will need to remove panel and thaw out drain by running hot water down. You can use a putty knife to break up ice first. Make sure you get all ice around the drain above and below the thin aluminum tray at the bottom. After the drain is free don't be alarmed if you get some water on the floor because the drain pan may not hold all of the water you ran down the drain. Not anything you can do to prevent this on this model.
Oct 07, 2007 | Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
153 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
