Toshiba DLP Model 52HM84 S/N 20717899 Symptoms: It ultimately blinks a lamp problem code after trying to start 8 times. A New lamp does not correct. I hear a 2 stage whine when it tries to start. I suspect it has a color wheel problem instead ??? Is this replaceable by itself? or is the complete light engine the more realistic approach to repair.??
  • ZNREL Sep 07, 2010
    Thank you. It is always good for the Ego to get a second opinion that reinforces my diagnosis.
    ZNREL
  • 10,594 Answers
Color wheel for Toshiba 52HM84 comes along with light engine and price is $330, available in Discount-Merchant.com
Click above link to view light engine images and price info.
Thanks.
Posted on Sep 07, 2010
Samsung HL -5656 fan light blinking BUT no other lights blinking
Its probably not the lamp but I would try it first. Buy it from a place that will take it back as I suspect you have a bad power supply. http://support-us.samsung.com/cyber/popup/iframe/pop_troubleshooting_fr.jsp?
check this link against your symptoms and then check out Pureland Supply for a new lamp. Samsung DLP TV Lamp
Jan 10, 2018 | Hitachi UltraVision CineForm 55VG825 55"...
Toshiba DLP green light flashes 5 times
Inspected lamp?
Does lamp fire even for a second or two?
Any high pitched whine or fan like sounds?
What I usually do if working on a set like this is rule some things out and then Google the model to get to the Toshiba site---see if your model and blink code are listed there.
Apr 11, 2012 | Toshiba 52HM95 52" HDTV Projection...
Repleaced lamp on Toshiba DLP 52HM84... still wont turn on. It goes through the auto start up 8 times and still no screen. The red and green lights blink at the same time. What does this mean?
The fault is indicative of the lamp circuit, check the lamp fittings, check the power circuit and the ballast.
If the voltage insufficiency is present from the power supply it can lead to low current and thus the lamp will not power up. Also if the replaced lamp is faulty, not of original quality or if there are connector issues, this must be rechecked.
Check all the connectors on the power supply side and the motherboard. remove and reconnect.
Oct 13, 2011 | Toshiba TheaterWide 52HM84 52" Rear...
Hi: My Toshiba starting showing the symptoms (as it has in the past) that it needed a new bulb. The red light comes on, is steady, but then the green light comes on and flickers. I have now put in 2 new...
I think that you have a problem with your ballast board this is the power source to the lamp if for any reason it starts to wear out or weak it will not be able to turn on your lamp check this link out it is about Toshiba lawsuit
http://www.avrev.com/home-theater-rear-projection-hdtvs/dlp-rear-projection-hdtvs/toshiba-ordered-to-pay-out-in-dlp-lamp-lawsuit.html
Sep 21, 2010 | Toshiba 62HM95 62" DLP HDTV
62HM15 Toshiba DLP TV won't respond to remote or control panel
Blinking is a trouble code. Try unpluging for a longer time then hold power button in when pluging back in to try and reset.
Mar 15, 2010 | Toshiba 62HM15 62" Television
I have a Panisonic pt-52lcx66 that won't come on.
OK AT THIS POINT IT COULD BE A BALLAST ISSUE IT SOUNDS LIKE IT'S NOT SENDING THE CORRECT AMOUNT OF VOLTAGE TO THE LAMP TO TURN IT ON, AT THE START IT NEEDS A KICK OF 15,000VOLTS TO TURN ON AND IF THE BALLAST IS WORKING CORRECTLY THIS WILL HAPPEN
HOPE THIS HELPS
http://www.fixyourdlp.com/2007/11/24/reset-your-panasonic-lamp-counter-after-installing-a-new-lamp/?click=48428
http://www.discount-merchant.com/how-dlp-works-like-magic-a/141.html?click=48428
Nov 19, 2009 | Panasonic PT-52LCX66 Projection Television
What are the blinking light codes on a toshiba dlp meAn?
90% of the time your lamp needs replacing.( DLP sets only )
Jun 18, 2009 | Toshiba Televison & Video
Problem with Toshiba DLP Projection TV Model #52HM84
It is possible the lamps may be defective or that they may be the wrong replacement for this model, as it may have a different wattage setup with the ballast. If you want to try to order the TB25 lamp from a different vendor, you can order the original Toshiba replacement lamp for this model (52HM84) from a major Toshiba parts distributor at the link below:
Toshiba 52HM84 Replacement Part TB25 Lamp / Bulb
Apr 10, 2009 | Toshiba TheaterWide 52HM84 52" Rear...
Toshiba 52HM84 DLP TV with new bulb but the lights keep blinking
They exact way the lights blink are telling you what the failure is. If the tv is firing the lamp and the lamp is bad, you will hear a buzz sound for about 1 second. The tv tries 8 times before it gives up and spits out the lamp error. Check the user manual for led diagnostics. If you put in a new lamp but still have issues, you've likely got a bad ballast (most common on this model) or colorwheel (less common). Both are part of the optical block (light engine) and I don't believe they're available as individual components from toshiba.
Nov 28, 2008 | Toshiba 52HM95 52" HDTV Projection...
Televison & Video Logo
85 people viewed this question
Top Televison & Video Experts
