Question about Briggs & Stratton Garden
I have a22 inch yYarMchine lawn mower. I have change the coil, the filter , I emptied the gas and put new gas and also change the oil and the spark plug and it still does not start, I get tried of pulling the damm string and it wont start. what can it be?
    President:
  • Briggs & Str... Master
  • 1,545 Answers
Maybe try cleaning the carburetor...especially the brass bolt that holds the float bowl on as it is the main jet to the carb.
Posted on Sep 09, 2010
Lawn mower stopping by itself
CHECK THE FUEL FOR CONTAMINATES OR OLD GAS
EMPTY COMPLETELY OUT AND PUT IN NEW GAS!
ALSO CHANGE SPARK PLUG!
IF YOUR LOW ON OIL, IT MIGHT AUTOMATICALLY SHUT OFF ALSO!!
Jun 15, 2014 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Hi I did a tune up ,changed and checked every thing I done ..too I changed the oil ,oil filter ,gas filter air filter ,got a new battery changed the plugs there new too...even a new belt new key ...but...
Spark and gas??? Must have both. Pull spark plug wire and check for spark. If you have spark, check gap on spark plug. Check the bowl on carburetor. loosen bowl screw to see if gas is coming out. If you have gas coming out, carb needs to be taken off and cleaned or rebuilt.
Oct 11, 2013 | Cub Cadet Street Sign- tractor lawn riding...
My mower will run for about 30 minutes then die and then have to wait for awhile and process starts all over. i have changed oil, spark plug, plug wire and coil, fuel filter, air filter and screen,...
Try this.
When the mower is about to die, loosen the gas cap.
My mower gas cap vent holes plugged up and kept stalling the mower.
If it works, drill out the vent holes.
Gary
Jun 27, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My lawn mower srarts than dies its not out off gas or oil
There are a few popular solutions for your problem. You can try changing out the old gas completely, with new fresh gas, you can try changing the spark-plug and air-filter. You can try cleaning the carburator or replacing it if you find it is broken. And you can try removing the spark-plug wire and putting in-line, a spark tester. The ark should be blueish white Not dull orange or yellow. If the spark is insufficient then you can try removing the pull-string cover and lightly sand the magnet that is on the fly-wheel and passes by the ignition coil. Good-luck.
May 21, 2010 | Craftsman Push Rear Bag Lawn Mower w High...
Oil change
STOP !
Your lawn mower is has a 4 cycle engine
It does not require oil to be mixed with the gas
The oil for the crankcase should be a 10W-30 or 10W- 40
NO GAS IN THE OIL
What you have is a 2 cycle oil that is mixed with gas for most weed eaters, chain saws, ect
Putting a gas/oil mix in your mower WILL severely damage it destroying the main bearings and could lead to an explosion or fire.
Please be careful
Apr 04, 2010 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
I have to prime the toro mower every time I empty the bag to get it to start?
  1. what is the model, manufacturer and year of mower?
  2. has any maintenance been performed on this mower?
  3. if no, try replacing the spark plug and air filter (it's possible the spark plug could be fouled and/or the air filter is clogged) be sure to follow the manufacturers recommendations for oil, gas, filters and plugs.
routine maintenance involves:
  1. sharpen/replace blade
  2. oil change
  3. replace air filter
  4. replace spark plug
  5. new gas
Aug 31, 2009 | Toro Lawn Mower With Toro Power Tools
I have a murray 22 inch lawn mower with a 4.0 hp briggs and
Change your air filter, spark plug, fuel filter, and oil. Then make sure the gas is fresh. Gas starts going bad after a month. Spray carb cleaner in hole underneith the fuel filter. Oh yea dont put more than 20oz of oil in it.
Mar 27, 2009 | Garden
Yard Machine MTD push lawn mower won't start
Sounds like you need a complete tuneup. Start with the carb. then clean all coil contacts, air filter and this will start you in the right direction. Good luck.
Mar 24, 2009 | Mtd 22" Yard Machine Push Mower
Garden Logo
63 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
