Question about Brother MFC-5840CN All-In-One InkJet Printer
Ink cartridge cyan is not working
I think the printer cannot sense the cartridge cyan because every time i put the cartridge in its slot in the printer the printers says change cartridge install cyan.i tried to install cyan cartidge for many times but it still says no cartridge.please help me in my problems with my printer.thanks
  • knucklehead4 May 15, 2008
    i installed 3 new HP ink cartridges. Two are still showing empty when i click print and the printer will not work. Please help! Need my printer!
  • popester3901 Jul 22, 2008
    same problem just replaced the black ink carttridge and it still reads no carttridge reinstall
  • 3 Answers
Beside of the color ink there are photocouplers, check them
Posted on May 23, 2008
How do I fix Service Engine Error 181.514. INK Sense BPD Prine Error.
Have you removed the plastic covering the ink jets on a new cartridge?
Feb 21, 2015 | Lexmark OfficeEdge Pro 5500T Multifunction...
Can you put a non photo ink cartridge in a photo cartridge location
Use a syringe pull the ink out of the full cartridge and refill the empty one
Jul 24, 2014 | Canon Cyan Printer Ink Cartridge For Pixma...
Im using hp deskjet 2660 cartridge says INTRODUCTORY HP TRICOLOR PRINT CARTRIDGE (colors) cyan magenta yellow 60 it's not producing yellow images that i printed are in pink or purple i...
This model printer has only two slots for ink cartridges. One is for a black ink cartrigde and the other is for a tri-color cartridge which contains cyan, magenta and yellow inks.
This tri-color cartridge has run out of yellow ink, you need to replace this tri-color cartridge.
Aug 12, 2011 | Office Equipment & Supplies
My brother multi function ( NOT) MFC 260C keeps telling me Cyan empty replace which I have done 3 times so far and kepp getting same message.I have tried the tape etc but to no avail.
Hello
Make sure none of your other cartridges are empty. I have seen this over and over. Two cartridges empty at the same time, and the person replaces one of them but thinks they actually replaced the other one.
Turn the printer off. take out the color cartridges. on the end with the ink openings, in the middle is a small opening and a little plastic window. you've got to cover the plastic window with a small piece of duct tape. work the edges of the tape into the slot.
Evidently the machine senses ink levels thru that opening.
Apr 24, 2011 | Office Equipment & Supplies
I have problem with my HP business ink jet 2230. Problem is with cyan ink cartridge. I put new original cyan ink cartridge in printer, after that message is display "Attention cyan ink cartridge expired"....
hello sir, hi, the ink comes out from the ink cartridge to the ink cradle where the ink pass to the paper, this is clogged, need you to clean the ink cradle, you can use warm water to soften the dried ink.
Sep 16, 2010 | HP Business Inkjet 2230 Printer
Won't print after replacing cartridges
The following text copied from HP website to tackle this problem. minimtop.gif Follow the instructions below to install the print cartridges. NOTE: If you are installing ink cartridges in the unit for the first time, be sure to use only the print cartridges that came with the unit. The ink in these cartridges is specially formulated to mix with the ink in the print head assembly at first-time setup. s.gif Installing the print cartridges minimtop.gif
  1. Verify that the unit is on.
  2. Open the ink cartridge door. Figure 1: Opening the ink cartridge door c00718797.gif
  3. Squeeze the gray tab below an ink cartridge slot to release the gray latch and then lift the latch. Figure 2: Lifting the latch c00721793.gif 1 - Ink cartridge latch for the black ink cartridge 2 - Ink cartridge latches for the color ink cartridges NOTE: The ink cartridge areas are color-coded for easy reference. From left to right, the ink cartridges are black, yellow, light cyan, cyan, light magenta, and magenta.
  4. Remove the new ink cartridge from its packaging.
  5. Hold the ink cartridge by the handle and then slide the ink cartridge into the empty slot. NOTE: Make sure that the ink cartridge is inserted into the slot that has the same shaped icon and color as the ink cartridge. The copper-colored contacts should be facing the printer as the ink cartridge is inserted. Figure 3: Inserting an ink cartridge c00721795.gif
  6. Press down on the gray latch until it clicks into place. Figure 4: Closing the gray latch c00721796.gif
  7. Repeat steps 3 through 6 for each ink cartridge that needs to be replaced. NOTE: All six cartridges must be installed. The printer will not work if an ink cartridge is missing.
  8. Close the ink cartridge door. Figure 5: Closing the ink cartridge door c00718798.gif
s.gif s.gifHave a Good Day
Jul 17, 2009 | HP Photosmart C4580 All-in-One InkJet...
Install black cartridge, but will not print
Lets do it this way. Follow these steps again carefully and try to install the Ink.
Introduction
Follow the instructions below to replace the ink cartridges.
Replacing the ink cartridges
4. Pull the ink cartridge toward you out of its slot to remove it.
5. Remove the new ink cartridge from its packaging.
6. Hold the ink cartridge by the handle and then slide the ink cartridge into the empty slot.
7. Press down on the gray latch until it clicks into place.
8. Repeat steps 3 through 7 for each ink cartridge that needs to be replaced.
9. Close the ink cartridge door. Print a test page.
If after doing this it does'nt work, then i will ask you to unplug the printer cable from the computer and uninstall the printer driver/Software completely.
Shut down your computer and restart it.
Re-install the printer driver/software from the start as you did when you bought it.
Good luck
Apr 18, 2009 | HP Photosmart C6180 All-In-One InkJet...
My Hewlett Packard OfficeJet Pro 7500 has problems recognizing the Cyan ink cartridge. Seems to think the cartridge is empty or missing when in fact it's full and it's there in the slot. I put a new Cyan...
I fixed it, but I'd like to be compensated for providing the solution to you. After all, you wanted to be paid for helping, so I too want to be paid for helping.
Jul 17, 2008 | Office Equipment & Supplies
Ink Cartridge
Some of Epson's cartridges went bad that way. It may be a bad cartridge. Get a new one, pull that one out and see what happens. If it works, call Epson for a refund. They had a class action suit for that type of thing, they lost and paid off. I would think they will help you right away.
C
May 31, 2008 | Epson Stylus CX6400 All-In-One InkJet...
Brother MFC-5840CN All-In-One InkJet Printer Logo
232 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
