Question about Maytag Dishwashers
The soap dish opened, but the dishes were not cleaned. The soap remains on the door even after two or three wah cycles. Checked all of the buttons.
  • 3 more comments
  • djhuff42 Sep 07, 2010
    The flap does open -- the detergent is caked to the inside of the door following a cycle.
    I will follow up with your suggestion.
    Thee small container was filled with water.
    I am completing the cycle with no dishes in the unit.
  • djhuff42 Sep 08, 2010
    • I am using the correct detergent.
    • The water is hot during the wash cycle
    • At the end of the rinse cycle -- there was still water in the tub
    • Not a hard water problem
    Model number DWU9202AAE
  • djhuff42 Sep 09, 2010
    • I did not change who i was talking to?
  • Maytag Master
  • 3,247 Answers
Since you mention that your dishwasher has a dispenser has a flap that opens but detergent does not come out, the problem could be the wash water is not getting to it.
Can you confirm if during wash cycle the water is circulating especially through the top wash arm.
Keep a small container on the top rack and see if there is water collected in it at the end of cycle. Alternatively run the dishwasher with door open (you will have to find a way to enable the door switch inside the latch).
Please post a comment to confirm what you observe.
Posted on Sep 07, 2010
  • 2 more comments
  • Sam Sep 08, 2010
    Forgot to mention - does the water heat up during the wash cycle. Some dishwashers require hot water connection to operate otherwise the detergent does not dissolve. Also are you using the detergent specified by manufacturer? If living in hard water area also make sure you have added the relevent Salt and Rinse aid content.
    Hope I can help you solve this problem soon.
  • Sam Sep 08, 2010
    Need you to provide the model no. of your Maytag dishwasher. I had asked you general questions for detergent not coming out but may have to investigate further for specific conditions of your model.
    Looks like you are not able to run the dishwasher with door open as I had suggested.
    Water collecting in containers means water is getting to the top shelf but hard to know if the wash arm is throwing it on the door and hence detergent dispensor. I am assuming you have cleaned the spray arms.
    Will need the model no.
  • Sam Sep 08, 2010
    Thanks for posting the model no. I noticed your query is locked to another fixya consultant at the moment. I will wait until it is released and then get back to you if still not fixed. cmmiuser01
  • Sam Sep 09, 2010
    I noticed the solution was locked to another expert and you have already rejected my attempts to assist you with finding a solution by giving a 2 finger rating.
    I hope you have solved the problem. cmmiuser01
  • Maytag Master
  • 19,396 Answers
Hi.
If the door soap dispenser door does not open you usually need to replace the dispenser door switch. Problem is not uncommon.
Repair is carried taking apart the door to reach the switch and replacing it.
See:The soap dispenser drawer
To get parts and diagram Enter the model number on one of two websites here
Posted on Sep 08, 2010
  • 177 Answers
I am a qualified service technician and i am able to help you
Posted on Sep 09, 2010
Soap remains on the dishes after the wash cycle is complete.
Check that the holes in the spray arms haven't blocked up and the filters in the bottom are clean. The arms may not be rotating. To check this, when the machine is washing, open the door, turn all the spray arms to face the same direction, shut the door and leave running for about 30 seconds. Open the door again and look at the position of the spray arms. They should have moved.
Nov 25, 2013 | Samsung DMT400RHS Builtin Dishwasher
Hi. My problem is with my dishwasher detergent dispenser. It does open (at least it is open at completion of cleaning cycle), appears to deliver soap to dishes (as they appear clean), however, from the...
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem
Detergent Cup does not Open
heatman101
Feb 14, 2011 | Maytag MDBH985AWB / MDBH985AWS 24 in....
Dishes aren't clean, yet there's still soap residue in the cups
heatman101
May 09, 2010 | Frigidaire 24 in. FDB635RF Built-in...
Soap dispenser problem?
Check the water supply. Start cycle then open the door after it fills and check water level and spray action. If everything is soaking wet, there is probablyl a pizza pan blocking the soap tray.
Jan 05, 2010 | Frigidaire 24 in. PLD2850 Built-in...
OLD KITCHENAIDE MODEL KDI-20 LEAVES SOAP GRANULES ON DISHES.
I have this same problem, plus the pre-wash soap dispenser doesn't open sometimes even though a service guy replaced that. Could he have replaced just one side and not the other? this dishwasher also has a new motor. sometimes it washes beautifully. but other times it does not. even if both dispensers opened.
Dec 04, 2008 | KitchenAid Dishwashers
Dishwasher does not clean. soap door does not open every time.
Well the 2nd part of your question is probably the the reason it doesn't clean. If the soap door doesn't open then the dishes will probably not be cleaned. So.. I would focus on why the door doesn't open first.. is it sticking from old soap residue? If so, clean the dispenser with white vinegar and cycle it a few times without detergent and use the hottest/sanitary setting.. Then make sure you are using an approved dishwashing detergent for yuour wash cycle. Add some detergent to the dispenser and try cycling it without any dishes .. does the door open? If no, then you need to resolve that first.. If it does open, try running a cycle with about 1/2 the normal dish load and see if the door opened and the dishes came out clean.. Routinely, check and clean the drain filter so you aren't redistributing the food sediment from the previous load all over the next load of dishes.. Hope that helps..
Sep 06, 2008 | Kenmore 24 in. 16009 Built-in Dishwasher
Dishwasher not cleaning dishes. Casade cleaner not disolved.???
Run the unit with no soap, after about 5 min. of run time open door and check to see if water is clear or soapy,If soapy then you are having an oversudsng issue.When your washer gets to rinse cycle, your unit (if oversuding),will be rinsing with soapy water and the the drying cycle bakes the soap on dishes.You might be having a white film on your clear glasses.Cut down on soap especially if you have soft water.powder soap is best.Your dishwasher will fill , wash , the drain.Its what you put into it that will cause dishes not become clean.
Dec 01, 2007 | KitchenAid 24 in. KUDI02IRBS Stainless...
Dishsoap stays in soap dispenser
ok, either a spring, trigger prob, on the latch, or a electronic prob. ok so to see if the latch is ok (or not) look closely for soap residue and scum, that may be hindering the latch or spring under. use metho, and warm water to clean this part. secondly go down to a white goods repair place and take your electrical component, button, lights its all one unit, simple unscrew it, i do think you will need a set of torque screws for that tho... anyhow ask the guy to get you a new or second hand one and install it. the timer will run, and the clip will release. good luck!
Sep 25, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
428 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
