Question about Dryers
I have a model 600 gas dryer and it runs but no heat
  • Dryers Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 10, 2010
Dryer wont heat. cleaned exhaust duct still problem exsists. Model 60 series kenmore gas
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 09, 2011 | Kenmore 600 6965 Electric Dryer
Kenmore 600 Gas Dryer runs but does not dry clothes
heatman101
Jul 10, 2011 | Dryers
Kenmore 600 series gas dryer not heating
heatman101
Jun 26, 2011 | Kenmore 600 7965 Dryer
I have a kenmore 600 series dryer that runs but does not heat up. I assume that the heating element is bad. Would that be a good assumption?
heatman101
Mar 09, 2011 | Dryers
600 series gas drier runs but no heat
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Jan 25, 2011 | Kenmore 600 6962 Dryer
Runs but doesn't get hot
You will need to check the heating coils, if electric model or the gas burner , self igniting which can be faulty or block in the pipes..
Please remove to have access to the set to check these parts out which can be the culprit.
Oct 11, 2010 | Kenmore 600 7962 Dryer
I have an kenmore 600 series clothes dryer. It's about 1.5 years old. The dryer tumbles. gas and electric are on but no heat.
It is most likely the element if it is an electric dryer. If it is a gas dryer be sure that the pilot light is on for the gas at the valve.Also this machine is most likely under warranty so check it out.
I am 90 % sure that is an electric dryer so I would check to see that one of your breakers for the dryer are not tripped as one can run the dryer but it needs two to get the heat running as it runs on 220 volt.
Oct 06, 2010 | Dryers
My kenmore 600 gas dryer dont heat up. gas is on electricity its fine it turn on it works fine but just not heats up.
Disconnect the rear vent off the dryer itself and try again. If heat does work the vent tubing is clogged
Oct 06, 2010 | Kenmore 600 6962 Dryer
Dryer runs but don't heat up
heatman101
Aug 09, 2010 | Kenmore 600 7962 Dryer
Kenmore 600 series gas dryer not warm
Make sure the vent is clear and air movement is good through the rear vent.
Ten,
Check and or replace the flame sensor and the gas valve coils.
Mar 11, 2009 | Kenmore 73952 Gas Dryer
Dryers Logo
24 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
