Question about Shop Vac 925-09-62 QSP Plus Wet/Dry Vacuum
My shop vac model #86785-05 just stopped working. Will not turn on. Do I need a new motor? Is it worth replacing or do I need to buy another one.
  • 120 Answers
SOURCE: burned out motor on QPL625 Shop Vac
well if you can find the motor ( find a place that deals with the manufacturer directly so you get the right part ) and it isnt to expensive, most shop vacs are pretty easy, if you look under the top you should see about four screws, remove those and the top should come of giving you access to the motor, take note about the wires and what they hook up to. i doubt the motor is fastend down other than that.
Posted on Sep 18, 2008
MrScary66613
  • 1990 Answers
SOURCE: Craftman Canister Wet/Dry vac- Motor just stopped working
It is Repairable But, The parts will cost almost as much as a New Vac. I would just get a New Vac and save the Hastle and the Cash. The choice is all yours Though. Please Rate My Response! Thanks!
Posted on Feb 07, 2009
SOURCE: shop vac 90L400 stopped working won't start
VERY Helpful Customer service, immediate solution was to send a new power unit no cost to me! Thank you Shop Vac!
Posted on Dec 17, 2009
shastalaker7
  • 1515 Answers
SOURCE: Older model shop.vac parts/owners manuel
Hi, I know on my Craftsman shop vac 2 different sizes of vacs that I use, I try and stick to the craftsman filters, but you can use other brands if they are not available or you want to save some ( $ ) ? As far as a manual for this vac, more then likely you will have to go to the maker and distributor as Sears, O.C.Hardware also sell there products. You may have to go with a manual that is the same peak H.P.and gallons that covers all different makes and models. Filter wise, make sure you have the right ones on or off when using the wet or dry pick-up settings.
Sincerely,
Shastalaker7
Posted on Jan 23, 2010
oldmanewtoys
  • 414 Answers
SOURCE: shop-vac model 90L550A motor wont run
Yes replacing the link would work, but that would not fix the cause. You have either pulled the wiring to the point of pulling apart the connection or there is a short. Which would be in the way of a grounding effect causing the link to heat and melt. A safty issue to be sure. Check all contact with housing and motor to make sure there is not an underlying problem to start with. Unpluged of course
Posted on Feb 25, 2010
Shop vac stopped working
Motors have a thermal safety fuse in the field winding. If it overheats, it will blow and either can be replaced or the whole field winding will have to be replaced. It is wired and is not considered to be a user servicable item.
Apr 22, 2014 | Shop Vac Shop-Vac& Mini Hang Up Wet/Dry...
My Shop-Vac 5870400 was working just fine, and then one day while i vac the floor its just stop working, tried to turn on/off a few times, swicth to different outlet. i did even tried to open it, but found...
Same thing just happened to mine. My solution is to get another one but a different brand. I think it should have lasted longer than four years of fairly light usage. From what I read, if it does as we both described, the motor is shot and not worth replacing.
Feb 18, 2011 | Shop Vac 587-04-00 Canister Wet/Dry Vacuum
Where to by replacement motor
you can buy a replacement vacuum for the same price as the motor on its own. I would recommend getting a new unit altogether as they are not very expensive to but but a fortune to fix. I have been in the vac business for 20 years and have a bit of knowledge on shop vacs and a new one is your best bet.....good luck
Oct 06, 2010 | Shop Vac 952-02-62 Hang Up Pro Canister...
I have a Craftsman brand shop vac [model # 113.77420]. It is still picking items when I sweep with it, but it has developed a very high pitched squealing sound whenever I turn it on. The sound makes it...
I have the same problem with a CTC Shop Vac. It's he bearings ... they're worn out and dry ... no lubrication. I've trid taking the motor apart and lubricating the bearings, then it runs super for a few uses but then the squealing starts again. Oitch it and buy a new one.
Aug 23, 2010 | Shop Vac 925-09-62 QSP Plus Wet/Dry Vacuum
Hoover SteamVac quit working.
there is no reset button to this machine. in some cases if the machine stops or makes a weird noise or a smell like electrical, most likely it's the motor that went out or you could just have a switch that went out. if you didn't have any of these things happen, then take it to your local vac shop to get an est. done to see if would be worthe replacing the broken things or would it be better to buy another machine. hope this help's
Aug 01, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Need new switch for Shopvac QSP Pro 10 gallon unit
I just went through the same problem with a Shop Vac. The switch is easy to replace but not easy to find. After removing the switch, I found a match made by Sigma Switches. They directed me to contact a local RV dealer and look in either their Coast Supply or Stag/Parkway Supply catalogs for the appropriate switch (an H2-28 in my case for a QPL45 Shop Vac). After ordering the switch and $5 later, it snaps in like the original with no problems. Certainly beats $70 for a whole new motor assembly.
Dec 28, 2008 | Shop Vac 285-00-10 Back Pack Vac Wearable...
MY SHOP VAC STOPPED WORKING AFTER USING IT FOR A WHILE
If by stopped working you mean that it no longer has any suction, then check the hose for a clog and also clean all the filters.
If you mean that it literally stopped running, then the most common cause is a faulty switch. If the machine is still under warranty, contact Shop Vac for a replacement motor, Switches for shop vacs are not available, only replacement motors. If the machine is not under warranty you can either replace the motor or the whole machine.
Oct 22, 2008 | Shop Vac Vacuums
Shop vac 90L400 stopped working won't start
I had the same problem with the same model. Turned out to be the thermal fuse on the motor housing, between the switch and the windings. Took it apart and replaced the melted solder with 14 guage copper wire. Works fine! No thermal protection but I don't use it for long at a time anyway. Check the switch for continuity, if good then check the thermal fuse for continuity. If good, it's the motor.
Oct 19, 2008 | Shop Vac 925-13 Canister Wet/Dry Vacuum
I have a shop vac. model 500x 1h.p. Center section speratedon impeller cost of new ? or throw away ?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=794495
Generic problem for all Vacuums
I have a shop vac.
Posted by mymino on Jul 17, 2008
I have a shop vac. model 500x 1h.p. Center section separation impeller cost of new? Or throw away?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. There are only 2 ways that I can think of in answer to your question. Either you can replace the fan impeller or you have to replace the entire motor. You would have to contact your local vacuum cleaner dealer in your area or contact the Shop Vac factory @ the website or to call the factory @ the phone 3 listed below; or check your owner’s manual.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://shopvac.com/contact.asp
Customer Service 570-326-0502 Phone #
Customer Service 570-326-7185 Fax #
Shop-Vac Corporation
2323 Reach Road
P.O. Box 3307
Williamsport, PA 17701
Hours are: Monday thru Friday 8:00 am to 5:00 pm (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 17, 2008 | Kenmore Progressive Bagless Upright with...
Shop Vac just stopped
If you remove the motor, you will see that the wires that go from the switch to the brushes. On one side there is one wire connected directly to the brush. On the other side the wire goes to a plastic plug with a second wire going to the brush. This is probably where the problem is. This is a fusible link and it has most likely melted creating an open in the circuit. I put a piece of solder where the link was and the motor ran BUT the brushed arced like a sparkler. Upon further examination the brushes were crumbling apart. I have been unable to find replacement brushes.
This machine has a five year warranty. I called Shop Vac Customer Service 1-888-822-4644 and they sent me a new motor.
I had a Shop Vac QL50EIC which had exactly the same problem but the warranty was expired so that I had to buy another motor for about $50.
Mar 08, 2008 | Shop Vac 285-00-10 Back Pack Vac Wearable...
Shop Vac 925-09-62 QSP Plus Wet/Dry Vacuum Logo
330 people viewed this question
Top Shop Vac Vacuums Experts
Mike
Are you a Shop Vac Vacuum Expert? Answer questions, earn points and help others
