Question about Weller 8200 Soldering Gun
I have a couple of Weller d550 Solder guns and am in need of replacement light bulbs for either side of the tip. Do you have them or can you direct me to someone who does? I am on the west coast. Don
  • 490 Answers
Howdy, here is a solid vendor of weller parts and accessories who has the bulbs you are looking for.
http://www.all-spec.com/search?f=r&x=25&i=2&keywords= 8200
I hope you find this handy:)
farmerbear at FixYa.com
Posted on Sep 07, 2010
  • Brian Nov 04, 2010
    I searched though my spare bulb collection and came across a 2.25 Volt bulb that is ideal.
    You want to use one that has the lens built into the end of the bulb so the light acts like a spotlight and not a floodlight. This is the bulb I use, can be found for less than a dollar.
    PHILIPS 222 .25A 2.25V TL-3 MINIATURE SCREW BASE
I have recently bought a Weller 201 soldering iron, but in a very short space of time out of 2 projects it has made the glass crack in 2 out 3 projects. Could it be getting too hot.
You need to adopt an on-off-on---- action to control maximum temperature. Try to keep the tip so that the solder flows properly, but the tip doesn't try to burn up. Hope this helps!
Sep 14, 2010 | RTO Weller D550 Soldering Gun
The weller 8200n does notheat up
Make sure the tip is tightened fully, use a 5/16 wrench to snug it down.
Feb 28, 2010 | Weller 8200 Soldering Gun
Weller soldering gun replacement light bulbs
that takes a common 6volt screw in type bulb you can buy at most radio shacks or parts stores
Jan 22, 2010 | Weller 8200 Soldering Gun
Lights don't go no weller d550
I cannot see by the picture if you have one or two light bulb model, but if you have the 2 bulb, then you must know that these bulbs are in series so they both must be good and they have to be 1,5 volt bulbs each or you will get a very dull light. If it is a single bulb, then you need to check the screw-in socket and check the bulb with an ohm meter or continuity tester. iF ALL TESTS OK, THEN THE PROBLEM IS INTERNAL AND YOU WILL HAVE TO OPEN THE GUN OR JUST FORGET IT. GOODLUCK, MACGIVOR.
Jan 09, 2010 | Weller 8200 Soldering Gun
Weller D550 fried brand new tip
are you sure you bought the H.D. tip this is the big gun
Jul 12, 2009 | RTO Weller D550 Soldering Gun
Intermittent heat on Weller D550 although lights stay on. When not working, moving the terminals may get it to start working again. Sometimes, just moving the gun will interrupt the heat. Continuity...
Heat gun tips often get bad electrical connection where the nuts tighten to the tip ends. Remove the tip, clean the ends, re-install the tip, making sure the nuts TIGHTEN onto the tip ends. Your problem is common and always caused by a poor connection at the tip ends/nuts.
Jun 20, 2009 | RTO Weller D550 Soldering Gun
Where can I find replacement bulbs for an old D-550 with screw in type lights? I don't know the numbers for them.
The bulb you seek is a type222 2.33v 270mA bulb available from Radio Shack p/n272-1124.
http://www.radioshack.com/product/index.jsp?productId=2102806
Apr 05, 2009 | RTO Weller D550 Soldering Gun
Weller 8200 Soldering Gun Logo
360 people viewed this question
Top Weller Welding Tools Experts
Lawrence Oravetz
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Weller Welding Tool Expert? Answer questions, earn points and help others
