Question about IdeaSoft Nexis 100AP CD/DVD Publisher Burner
The robotic arm on the Nexis 100ap will not go down all the way to pick up and move cd's.
First thing to do is open "DiscDirect" and then click on “Tools” and go to "Properties" click “Calibrate robotics” and then click “Auto Calibrate Robotics” and follow the on screen prompts. Hold the green LED or power button and then plug unit back in. When the unit powers on, let go of the power button and hit the red LED button one time, then hit the green LED button one time.
You can also contact XLNT support at the link below and they can provide you with further assistance for your Nexis 100AP The contact phone number is: 1-800-479-1689
http://store.xlntidea.com/ViewPage.aspx?ContentCode=Contacts
Posted on Sep 09, 2010
I have a Wurlitzer CD jukebox. The arm picks up a CD and immediately returns it to the rack then repeats.
The arm is not closing a switch or a switch is stuck closed in the mech area. You will probably need to clean all moving parts with alcohol because chances are, the old oil or grease has become sticky and things are not moving correctly, especially if you notice the arm moving slower than it should. Check all switches and use a little alcohol on them too.
Feb 20, 2013 | Wurlitzer Jukebox CD Player
My robo kleen moves around the pool but has no suction so it won't pick up any debris
i had that problem, past year
open the motor check for rust stains on the round magnetic surface
i used a steel or copper brillo pad dry to sand down the surface
careful with those plastic motor screw washers to secure motor
Jul 27, 2012 | Smartpool Dolphin Robo - Kleen Above...
I Nedd CD de Instalacion and Drivers
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
if you dont have motherboard disk you will need to download the drivers
http://download.cnet.com/dvdram-en-20071009085435-zip/3000-2110_4-172943.html
http://download.cnet.com/dvdram-en-20070907111350-zip/3000-2110_4-170034.html
http://download.cnet.com/dvdram-win2k-5025-en/3000-2110_4-172950.html
http://download.cnet.com/adaptec-udf-reader-driver/3000-2100_4-10021086.html
Adaptec's UDF Reader enables MultiRead CD-ROM drives to read UDF-formatted CD-R and CD-RW discs (such as those written with DirectCD) under Windows 95/98/98SE/NT 4.0/2000.
if these packages are not the right
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
you might have to try a few times to get it right
hope it helps you
Apr 12, 2012 | IdeaSoft Nexis 100AP CD/DVD Publisher...
Driver issue, cpu does not recognize the drivers anymore. I reinstalled everything and used different cords to connect via usb
click start control panel administration tools computer management device manager scroll through all of your devices if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver if you computer came with a motherboard disk the drivers could be on it
(be precise)also the download software finder under that there will be a list place a tick in the box of any one you want/need
all software windows software mac software mobile and web apps
http://majorgeeks.com/downloads35.html
also this link will provide you with many freeware and share drivers
hope this helps
Aug 09, 2011 | IdeaSoft Nexis 100AP CD/DVD Publisher...
Robotic Arm Edge not working properly
I noticed the same problem on my pin 8 - however it wasn't the issue. I had the exact same problem and emailed OWI for tech support. The problem was with the battery connector plate. The "nipple" was facing out (away from the battery) rather than in so there was no power getting to the one side. You need to take off the arm and the top two round plates, then you can slide the connector plate out, turn it around and slide it back in. Works now! (This is step 16 in the instruction booklet.)
Dec 26, 2009 | OWI Robotic Arm Edge Kit
WURLITZER OMT CD 100 D picking problem
Hello J.P.,
You need to get the manual for this jukebox.
You have to however confirm what the manufacturer and the model number of this is. The One More Time was made by the following manufacturers:-
Wurlizer, Rowe Ami, Rock Ola, Antique Apperatus and Sound Leisure.
Look for a serial plate on the back of the jukebox in order to get any information.
You can get manuals in the USA from www.victoryglass.com
Regards
Alan Hood
ami-man
UK
Nov 17, 2009 | Wurlitzer Jukebox 1015 One More Time...
Hello, I have a problem with WURLITZER 1015 OMT CD 100D. The arm go to pick up the CD, but returns in the same time as it lock the cd in the gripper.Result is the CD is supported on two points instead of 3...
The carousel is locked in position by the latch at the front (about 6 oclock). If the gripper isn't exactly in line with the cd then you need to adjust the latch a bit.
Nov 16, 2009 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer arm keeps running
check the white plastic actuator next to the gear box, it is probably broken and not actuating the microswitch underneath it, these often fail, it may look ok,, but it actually is loose and the set screw on top of it is not clamping it to the rod.
Aug 18, 2008 | Wurlitzer Jukebox 1015 One More Time...
IdeaSoft Nexis 100AP CD/DVD Publisher Burner Logo
85 people viewed this question
Top IdeaSoft Computers & Internet Experts
David Payne
David Payne
Are you an IdeaSoft Computer and Internet Expert? Answer questions, earn points and help others
