Question about Kenmore Elite 45986 Front Load Washer
Washer takes a long time to go through a cycle. sometimes 1 hour or up to three hours. all on the same program ie regular wash cycle.
  • 15,935 Answers
The timer is likely bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 07, 2010
How long should a complete regular load take?
A regular load should probably take approximately 40 minutes, but there are various times for every different washer. The washer I have at home takes about 50 minutes to an hour. It really depends on the quality of the washer. Certain washers today use less water therefore it takes longer to wash
Feb 12, 2018 | Washing Machines
How long does it take in a full cycle of wash to dry
Depends on several things. How big the drum is eg 6 kg or 7kg .the spin speed... The material ie. cotton drys faster than woollen items.is it a washer dryer or do you have a separate dryer.normal full load 6kg on a 1200 rpm spin of mixed fibres takes 1 hours 30 mins at 40 c then the dry time can take roughly 1 hour to 90 mins.
Dec 23, 2014 | Washing Machines
Fisher washer stays on clen for over 3 hours
"Fisher washer stays on clen for over 3 hours" ???
I think you mean the "Dishwasher stays in the clean cycle for over 3 hours", right? First question is "What cycle?" If it's the Pots and Pans cycle, or "Pro-wash cycle" , or "Normal cycle with extra wash heat or sani-rinse options selected, then yes, this is normal! A Normal cycle (without added heat) will take about 2 hours. And a short or quick or 1-hour cycle will take less.
Sep 25, 2014 | KitchenAid Dishwashers
I have model #FGBD243KF1, Gallery 24" stainless. The wash cycle is taking almost 2 hours. Should it take this long? Also, when switching cycles during the wash time the motor whines a bit. Is this...
these units are pre programmed they can wash that longer and sometimes up to two hours and fourty five minutes. there are alot of factors involved.your unit sounds like it is running normally. at this time
Mar 27, 2011 | Frigidaire Dishwashers
Front load washer FTF530FS1 stop mid cycle, sometimes for more then an hour, then starts up again, entire cycle can take more then 3 hours? Also during cycle is very loud.
Seems you have possibly 2 problems. One, check to see if the element is not faulty. If no heat during heating cycle, the washer wont proceed for a long time.. Two, if noisy, especially on spin cycle, the bearings (2 of them) and the seal are faulty. Replace them as soon as possible.
May 27, 2010 | Frigidaire FTF530FS Front Load Washer
I have a kenmore elite washer and dryer is there any way to speed up the time it takes to do a load of wash it takes mine forever. Can it be reprogrammed or a way to reduce the time it takes for a wash...
No way to change pre programmed main control board, although you can use a gentle/delicate cycle that does have a shorter wash time. I would not use this for very dirty laundry. Good Luck, Appliance Specialists
Jan 06, 2010 | Kenmore Elite 45986 Front Load Washer
Bosch SHU4302UC/UO6 runs three hours.
Maybe wash temperature. The machine may be trying to heat the wash water to a preset temp and it is taking an extended time to get there. Maybe a faulty temperature probe or a bad element?
I know you will ask how this is possible when you have a final temp of 120 but that sound like a drying cycle temperature to me; not a wash temp.
I would leave the thermometer in through the cycle and you will probably find it will slowly get hotter in wash cycle and finally switch after a certain temp has been obtained.
Oct 05, 2017 | Bosch Dishwashers
My all in one washer dryer by kenmore is direct drive. the spin rinse spin functions work on all three cycles ie. delicate, permanent press and regular. the fill and agitate functions at the beginning of...
can you get it to start by moving the timer one more click past the beginning of the cycle? Sometimes that is all that is wrong. Other than that, it's more than likely the timer has fused some of the points together and you will need a new timer in that case
Aug 24, 2009 | Kenmore Washing Machines
Washer has timing issue, says it will wash for 45 minutes and wash for 1 hour and 15 minutes. The cycle says 50 minutes but it ends up taking 75 minutes.
This is really not uncommon. The more and more sophistocated the machines become, the more small decisions they make on their own. I have seen a one hour load take up to 2.5 hours.
If a load is off balanced, it will change the time. If the spin cycle doesn't spin enough water out, it will increase the time, and may still be too wet. (In that case you need to clean out the lint/drain trap.)
If you really want more control and quicker washes, there will be a setting like "Quick wash " or "Fast wash." Theis setting is quite basic and does exactly what you tell it to do, and you can always add and extra rinse, or higher speed cycles.
Kenmores and GEs are the highest reported rate of longer times. Relax. The more you add, ie, delicate, two rinses, light spin, medium dry, the longer it will take. It's just trying to do its job! :)
Sirwriter
May 29, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore Elite he3t model 11045972404
POSSIBLE COMMUNICATION PROBLEM BETWEEN MAIN AND MOTOR CONTROLLER
Nov 22, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
93 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
