Question about Sta Rite Sta-Rite Max-E-Therm High Effiency - Propane Heater - 333,000 BTU
I have a sta rite heater installed about a year ago, it is showing Service light on, and it ignites for a couple of minutes then begins to shut down, The gas meter has been changed a couple of times to a larger commercial meter but the problem persists. I have the pool company that installed this looking at it but i do not think they know what they are doing. i was promised that i would not have any issues with this heater at installation, its only been used less than 10 times.
  • 990 Answers
If this is a propane heater and you have changed the meter that means you have natural gas. A converstion kit is avable and all it is is a washer in the gas line inside the heater. You can buy these but my wholsaler just gives them to me when I get a heater. Get your installer to do this for you first before you buy anything else. Also check the size of your gas pipe to the unit. It need's to be sized to the heater and the run of pipe. You can find this info in your book that came with the heater.
Posted on Sep 08, 2010
I have a sta rite 200 gas pool heater. Heater ignites and runs for about 1 minute and shuts off. After another minute it restarts.
Try removing the Thermal regulator. also make sure you have adequate water flow thru the heater. If the heater seems to run OK with the Thermal Reg removed then order a new one.
Pentair / Sta-Rite 77707-0010 Thermal Regulator Kit for MasterTemp / Max-E-Therm
Jul 16, 2016 | Sta Rite Pool & Spa
I have a Sta Rite SR400 BG heater unit fan comes on service heater light . No error message and unit will not ignite. After a few minutes fan turns off unit still not firing and the service heater red...
Are any of the service lights on on the back-side of the board? There are 4 possible lights that can illuminate...if any are, I need to know which ones please. If not, there is more troubleshooting required. If you would like a copy of the owner's manual which covers all these steps in detail, please send me an email using the contact feature of our site at www.arrowpools.net and I'll reply with a copy of it.
John
Sep 18, 2011 | Sta Rite Sta-Rite Max-E-Therm High...
The heater ignites, stays on about 20 seconds and goes off, after starting and stopping 3 times, it displays a service heater light.
It may not be detecting that ignition occurred. There is usually a sensor that detects ignition and if it is not working right the controller tells yo to service the heater. If you call Sta Rite technical support number they may be able to help you determine what device needs to be replaced. I hope this helps.
Aug 13, 2011 | Sta Rite 460763 Max-E-Therm Pool and Spa...
Shows r 5 code when power is turned on. sta-rite
The R5 is a sequence code in the boot up sequence where your error is occuring. There is nothing in the users manual for these pool heaters that explains this error. Your best bet, unfortunately, is going to be to call Sta Rite. Here is their customer service number: 1-800-831-7133
May 08, 2010 | Sta Rite Sr400na Max E Therm Pool & Spa...
Heater for pool not responding
leave power off for about 15 minutes for a reset if still on check control panel heater relay may be stuck or faulty same goes for stat -if both are good most likely mother board is problem
Mar 05, 2010 | Sta Rite Sr400na Max E Therm Pool & Spa...
Sta-Rite Max-e-Therm pool heater -- cycling and HLS
make sure that you have adequate water flow going through the heater and that your water chemistry is balanced.
Jan 09, 2010 | Sta Rite Sr333na Max E Therm Pool & Spa...
Sta Rite Sta-Rite Max-E-Therm High Effiency - Propane Heater - 333,000 BTU Logo
93 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
john h
steve morris
steve morris
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
