Question about HP ZV6123CL-B AMD Athlon 64 3200+ XP Pro with 512MB, 80GB, DVD +/- Burner, 54g wireless LAN and 15.4... PC Notebook
Keyboard removal In order to replace one of the memory DIMMs on my laptop, you have to remove the keyboard. The process is to remove the four screws on the bottom of the case first. Well, one of the screws will not come out. It clicks when I turn it so I am thinking it is stripped or something is preventing it from coming out. Anyone have any ideas as to how to get this one remaining screw out? The other three were as easy as could be.
I do not know how far the screw is in but try prying it up away from the stripped hole with a flat screwdriver while unscrewing it to try and catch the threads, if it is recessed then try a pin with its point bent a little to hook under it.
Posted on May 14, 2008
I want to safely remove, clean and replace all keys on the Dell 610 keyboard
HI michael so if you want to clean your keyboard so first you must take off the keyboard from you laptop .
Let's remove the keyboard. Insert a flat head screwdriver between the keyboard bezel and laptop case and carefully lift up the bezel. Remove the bezel.
You'll find two screws securing the keyboard. Remove both screws.
Now carefully lift up the keyboard. You'll see the default memory module under the keyboard, right above the touch pad buttons. It's possible to replace the memory module without disconnecting the keyboard.
Disconnect the keyboard . Simply grab the blue tag attached to the keyboard connector and pull it up. Now you can remove the keyboard.
So now with removed keyboard you can clean it .
Jan 22, 2013 | Dell Latitude D610 Laptop Computer -...
Remove keyboard 646125-001
  1. Prior to replacing your replacement keyboard for sony vaio vgn-fe880e/h, make sure to remove the keyboard and disconnect the ac adapter from your laptop.
  2. The first step to replacing your laptop keyboard is to remove the screws from the back of your vaio vgn-fe880e/h. Sometimes your laptop will have a picture of a keyboard next to the screws that need to be removed. Otherwise, see your laptop manual for details.
  3. Above the laptop keyboard for sony vaio vgn-fe880e/h, you have a cover panel. If required, remove this part to easily access your keyboard. If you have screws above your keyboard, remove those screws.
  4. Now that you have removed all the screws, you are ready to remove and then replace your new laptop keyboard.
  5. To remove the vaio vgn-fe880e/h Keyboard, take a thin object and pry the keyboard out between the keyboard and motherboard. Be careful when removing the keyboard.
  6. Now that your keyboard is loose, simply disconnect your keyboard. In order to disconnect the keyboard, pay attention to the keyboard connector and connector cable. Unlock the connector cable device and remove your laptop keyboard. Your sony vaio vgn-fe880e/h connector cable should be easy to remove by simply sliding it out.
  7. Now that your keyboard has been removed, get ready to install your new laptop keyboard. Look at the back of the keyboard. If you see any screw holes, you will have a good idea of where to place the screws back in at the bottom of the laptop.
  8. Connect your laptop keyboard for sony vaio vgn-fe880e/h to the motherboard keyboard connection slot. Secure the keyboard cable. Now turn your keyboard in place, and align the grooves on the bottom of your keyboard with your palmrest or plastic bezel. Secure your laptop keyboard in place, make sure it fits properly and is snug. Now simply place the screws back in place.
Nov 30, 2012 | HP 646125-001 - Keyboard Tm - Us
My keyboard has sticky keys. How do I disassemble the keyboard?
Hi
STEP 1
Remove laptop battery.
Remove two screws securing the hard drive cover. Remove the cover.
Remove one screw securing the memory cover. Remove the cover
STEP 2
Pull the hard drive to the left. Disconnect it from the motherboard and remove.
Remove both memory modules.
STEP 4
Remove all screws from the bottom of the laptop.
STEP 5
Remove the keyboard bezel using a smal flathead screwdriver.
Be careful, it's fragile.
STEP 6
Remove four screws securing the keyboard.
Press on the plastic lock (red arrow) and release the keyboard.
STEP 7
Lift up the keyboard.
Be careful, it's still attached to the motherboard.
Feb 22, 2011 | Toshiba Satellite L305-S5894 Notebook
How to replace screen on Pavilion dv7-1040us. is diferent from other hps I have replaced, cannot figure out how to remove it.
Here it is! Have fun!
  1. Remove the four 4 mm P1 Phillips-head screws that secure the hinges to the display panel enclosure.
  2. Remove the two 4 mm P1 Phillips-head screws that secure the metal tabs on the bottom center edge of the LCD panel to the display panel enclosure.
  3. Lift the LCD panel out of the display panel enclosure.
LCD Panel replacement Note: Before replacing the LCD panel, remove the left and right hinges from the old LCD panel and install them on the new LCD panel.
  1. Place the LCD panel into the display panel enclosure.
  2. Replace the two 4 mm P1 Phillips-head screws that secure the metal tabs on the bottom center edge of the LCD panel to the display panel enclosure.
  3. Replace the four 4 mm P1 Phillips-head screws that secure the hinges to the display panel enclosure.
To remove in order to replace LCD, you will have to remove WLAN, keyboardwith the instruction :
Wireless LAN Minicard removal Caution! Observe all precautions when removing and replacing components.
Before you begin: Remove the battery2_bing.gif.
  1. Loosen the two captive P1 Phillips-head screws that secure the memory/wireless LAN Minicard cover to the bottom of the notebook.
  2. Use your finger or a flat-bladed tool to lift the edge of the memory/wireless LAN Minicard cover and remove it.
  3. Carefully disconnect the wireless antenna cables from the wireless LAN Minicard with a small needlenose pliers or tweezers.
    Remove the two 3 mm P1 Phillips-head screws that secure the wireless LAN Minicard to the system board and allow it to release to the spring tension position.
  4. Grasp the wireless LAN Minicard by the edges and pull gently to remove it.
  5. Place the wireless LAN Minicard in a static dissipative bag.
Before you begin: Remove the battery.
  3. Remove the 8 mm P1 Phillips-head screw in the memory/wireless LAN Minicard compartment that secures the keyboard to the base enclosure.
  4. Remove the two 8 mm P1 Phillips-head screws that secure the keyboard to the base enclosure.
  5. Turn the notebook right side up and open the display panel fully.
  6. Use a flat-bladed tool or your finger to lift the top edge of the keyboard and slide the keyboard toward the rear of the notebook.
  7. Using minimal force, push the locking bar toward the rear of the notebook to unlock the keyboard ZIF connector on the system board.
  8. Remove the keyboard ribbon cable from the ZIF connector and remove the keyboard.
Keyboard replacement
  1. Place the keyboard right side up on the top cover and insert the keyboard ribbon cable into the keyboard ZIF connector on the system board.
  2. Push the locking bar toward the front of the notebook to lock the keyboard ZIF connector on the system board.
  3. Toe the tabs on the bottom edge of the keyboard into the top cover.
  4. Press the keyboard flat.
  5. Close the display panel and turn the notebook upside down.
  6. Replace the 8 mm P1 Phillips-head screw in the memory/wireless LAN Minicard compartment that secures the keyboard to the base enclosure.
  7. Replace the two 8 mm P1 Phillips-head screws that secure the keyboard to the base enclosure.
  8. Toe the memory/wireless LAN Minicard cover into the base enclosure.
  9. Tighten the two captive P1 Phillips-head screws.
Dec 09, 2009 | HP Pavilion dv7-1240us Notebook
How do i remove the keyboard from a compaq pressario laptop please? need to replace as keys have been removed, already have new one, but cannot get laptop to split although all screws seem to out???
I removed the panel above the keyboard, removed the four screws and tilted the keyboard forward. Unclipped the ribbon cable and the keyboard was out. Replacement was the opposite procedure to removal, very easy after I thought about it. Thanks
Oct 11, 2009 | Computers & Internet
Need instructions to remove and replace the keyboard
No, not really, it will most likely just come as a keyboard.
its not that difficult to replace a keyboard,
here are pictures of the process.
http://www.irisvista.com/tech/laptops/ToshibaA55/SatelliteA55_remove_keyboard.htm
let me know if you have any other questions, yes its another model but its very similiar, I have a compaq laptop here and a acer laptop, on both laptop I would replace the keyboard pretty much the same way - I've had the keyboards off from both of these, and its very similiar on both brands I don't have a toshiba here but looking at those steps / picture its pretty much the same process.
May 21, 2009 | Toshiba Satellite A135-S2386 Notebook...
We have a hp pavillion dv7-1240us & we need directions on how to replace the screen ???
LCD Panel removal Caution! Observe all precautions when removing and replacing components.
Before you begin: Remove the battery, wireless LAN Minicard, keyboard, switch cover, display panel, display bezel, and inverter.
    Important! Use care when disconnecting the wireless antenna cables from the wireless LAN Minicard. Damaged cables or connectors can degrade notebook performance.
    Note: If three antenna cables are connected to the wireless LAN Minicard, the cable labeled 1 connects to terminal 1, the cable labeled 2 connects to terminal 2, and the cable labeled 3 connects to terminal 3. If two antenna cables are connected to the wireless LAN Minicard, the cable labeled 1 connects to the MAIN terminal and the cable labeled 2 connects to the AUX terminal.
  4. Remove the two 3 mm P1 Phillips-head screws that secure the wireless LAN Minicard to the system board and allow it to release to the spring tension position.
  5. Grasp the wireless LAN Minicard by the edges and pull gently to remove it.
  6. Place the wireless LAN Minicard in a static dissipative bag.
Keyboard removal Caution! Observe all precautions when removing and replacing components.
    Important! Use care to prevent damaging the ZIF connector and ribbon cable.
    Important! Use care to prevent damaging the keyboard ribbon cable.
May 17, 2009 | HP Computers & Internet
Installing memory in dell lattitude c400
I have one of these myself, love it. The other memory chip is under the keyboard. Remove the plastic strip that has the power button on it, and you'll see the four screws holding the keyboard. Once you get the keyboard off you'll see the other memory chip.
Jun 25, 2008 | Dell Latitude C400 Notebook
Compaq armada e500 memory
memory modules are under keyboard,you have to remove this first,1 hidden screw under(indicates a keyboard) and the 4 holds between the Fkeys(pull them down).Remove the keyboard and you''be able to see them....Chris/Greece
Nov 13, 2007 | Compaq Armada E500 Notebook
Computers & Internet Logo
51 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
