Question about Kenmore Washing Machines
Door locks, fills up with water. It than stops and an error code F11 comes up. No where in my Kenmore manual does it give an explanation for error code F11. Please Help
Dont forget lots of errors can be caused by the motor burshes
lots of people will think na they are ok they dont need replaced
however this is actually the case
BUT what happens is as they wear the carbon from them ends up on the case of the motor and more important the electrical plug and socket on it
this causes a current to flow accross the carbon dust
and can upset the normal operation of the motor and the speed sensor and motor condition anaysis
so you can get a ghost error just caused by carbon dust
when you open the machine simply use a dry paint brush and give the motor a good brush around
to remove the conduction path
this dust can lead the the mains supply in your homes safety sensors tripping
i fix this fault about 20 times a day!!!!
Posted on Dec 02, 2014
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. F11 is a communication error between the central control unit (CCU) and the motor control unit (MCU). To start with check the wire harness connections between CCU and MCU, and then check the motor. If both of them appear to be working fine then it seems that the MCU of your washer has gone bad as the control unit seems to be working fine. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 07, 2010
Washer was working.. electicity whet out... when emergency generator came in.. door lock message.. nothin I do works
Why is the "F dl" light come on - Kenmore Elite HE3 ...
https://www.ifixit.com/.../Why+is+the+%22F+dl%22+light+come+o...
iFixitThese are the errors for error code F/dL Door Lock Error Condition A Door Lock ... orrepair the following Door Lock Mechanism broken or removed from the Door ... these are usually indications of a failed door latch assembly and will require replacement. ...FdL code would not reset until I turned washer on to start load.
Troubleshooting - Support - Dexter Laundry
www.dexter.com/support/troubleshooting/
Dexter Washer Troubleshooting. Select your problem form the following list to reveal a list of possible solutions and supporting documentation. Constant ... F1 / Door Lock Error Door failed to lock properly. + ... Error Code F13, F15, F17, F19 +.
Washing Machine Fault Codes « Tips, Tricks & Recipes
www.appliancefactoryparts.com/blog/.../washing-machine-fault-codes/
Feb 20, 2010 - Failure Code, Condition, Check/Repair. "F1?, Water ... "F7?, Door lockrelease fault, ?· Bent pull-rod for door latch. ?· Bad door latch ... Water overflow error, Water supply does not stop after sensing an overflow condition. Turn off household water supply to washer and unplug power cord. ?· Check wiring ...
Why won't the door open on my Kenmore front-loading ...
Dec 10, 2015 | Washing Machines
My kenmore he2 plus keeps giving me an f11 code...I cleaned out the pump and it appears to be working...it fills with eater but does not move at all then pumps the water out ..next it gives me an f11 code
What the F11 means per the Manfactures service manual says "Serial Communaction Error" to put that in simple terms it says the main control board isn't talking to the motor control board. What would need to checked when the F11 code is displayed is for good tight wire connection on all the wiring harnesses between the main and motor control boards, if all the wiring plugs fit tight onto both control board while i hardly advise this and belive in the you can do it byself spirit it , but call for service so the operation of both control boards can be checked to see which on has failed.
Oct 07, 2011 | Kenmore HE2 Plus Front Load Washer
We have a Kenmore Elite Quiet Pak 4 Washer that we have had for 5 years. It has been flashing F11 and DL back and forth for months. We had a tech come out (not sure he knew what he was talking about) and...
The symptoms are pretty specific for the F11 code on the Whirlpool Duet front loaders and clones (Kenmore Elite and KitchenAid):
If the washer starts to fill but the drum NEVER moves, your MCU is bad
If the washer runs through most of a cycle and then gives the F11 before (or during) a rinse or spin cycle, then you have the CCU relay problem.
If you are interested in having me repair your CCU for you, I offer that service on eBay (website coming soon). My username there is "jhagner"
Thanks
Aug 19, 2011 | Kenmore Front Load Washer
I am getting a flashing signal on the timer display that says f11. The washer stops filling and I have to cancel the cycle. The owners manual says that this is an electrical problem I have cycled the...
The owner's manual is not very clear in its explanation! When it refers to 'electrical' problem it really means that the problem is not to do with anything mechanical (water, motor, door not locked etc) rather than 'electrical' being the actual power/ breaker supply.
Whirlpool's 'F11' refers to 'communications error, control unit'- 'electronic' would be a better description. Sorry but this requires a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jul 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F11 & FDL error codes several times per load.
HI. this is a door lock error code.
A Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times before displaying the error.
Potential Causes
• Door Lock Mechanism broken or removed from the Door
• Check Door Lock/Switch Assembly
• Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
• Door Lock/Switch Assembly Failure
Replace failed component.((Which will be a failed door lock assembly in this case))
Aug 31, 2009 | Kenmore Washing Machines
DL error or kenmore Oasis washer
Hi. this is a door lock mechanism failure code. these mechanisms will become unstable overtime. simply replacing this damaged door lock assembly will fix this issue.
If you are uncomfortable with disassembling thsi unit, i recommend calling a service tech for this procedure. he will simply replace the door lock mechanism(assembly)
Jul 27, 2009 | Kenmore Oasis HE 27082 Top Load Washer
I have the F11 and dL code. There is water and
Hi
Error F11 means Serial Communication Error i.e. communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly. You need to:
  • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
  • Check the Drive system for any worn or failed components
  • Check MCU
  • Check CCU
  • Check Motor
  • Error code dl is a Door Lock Error. A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error. You need to check:
  • Please do rate this solution as FixYa and revert for further assistance.
    Thanks
    Rylee
    Jul 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Getting F11 code r8ght after starting,then flashes and stops
    usually if this is a kenmore frontloader f11 is a communication error between the door lock and the ccu board. usually you'll hear a clicking sound before it fails. If so you need a central electric board. It is located directly under the top lid in the back. you can't miss it it's the only thing that has a lot of wires going to it.
    Jan 02, 2009 | Kenmore Elite 45986 Front Load Washer
    How do i find what an error code means?
    if that is a whirpool or kenmore remove bottom panel look for tech sheet in plactic bag codes are in it
    Sep 02, 2008 | Washing Machines
    Kenmore He3Washer Fills then gives error code
    remove lower panel right side underneath tech manual with codes
    Jul 04, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
    Washing Machines Logo
    144 people viewed this question
    Sal DeAngelo
    fordexpert
    Mike Carew
