Question about Dell PowerEdge 2300 Server
We have a Dell Poweredge 4400 & a Dell Poweredge 2300. Both have amber lights blinking - hard-disk failure indicators. They are using RAID. What do I need to do?
    Problem Solver:
  • 12 Answers
Go into the RAID setup during bootup (not always in the BIOS), but will post somewhere on startup (should say SCSI/SAS Controller card press CTRL + M to enter setup) or similar.
When in the raid setup check to see the status of the drive(s).
Was the machine running and it's just happened etc or are these machines you have obtained and are plain not working?
Posted on Sep 09, 2010
Disk 4 "is not ready"
> it does detect it on controller initiation.
Even when the drive is not spinning, it will identify itself (manufacturer, capacity) when queried. So, it's possible that it "checks-in", but files/directories on it cannot be read.
Apr 04, 2015 | Dell PowerEdge 2600 Server
Dell poweredge t110 server Amber error light on front panel blink one time
Had the same thing happen to me today and in my case it was a code 18 as they come...
It started while I was installing a video card adapter for a dual monitor setup. The solution - I had to simply close the side panel I had left open for testing and then reboot the server. The intrusion alarm went off.
Feb 02, 2012 | Dell PowerEdge T110 Server (GB/2GB)...
My dell poweredge 1800 doesnot boot, it gives an amber light after turning on . I have tried to remove the Ram but still the problem persists
An Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard.May also be caused by a defective card installed in the motherboard, i.e. video card.
Jan 31, 2012 | Dell PowerEdge 1800 Server
Hi - I have a Dell 8400, fails post. Diag indicators are A,B,C green and D amber. Sometimes the screen is black with a single blinking cursor and sometimes it shows the Dell splash screen. Cannot get to...
Unfortunately the dell website (not me) is not very helpful. Here's what is says about your diagnostic lights
Another failure has occurred.
  • Ensure that the cables are properly connected to the system board from the hard drive, CD drive, and DVD drive.
  • If there is an error message on your screen identifying a problem with a device (such as the floppy drive or hard drive), check the device to make sure it is functioning properly.
  • The operating system is attempting to boot from a device (such as the floppy drive or hard drive); check system setup (see "Boot Sequence") to make sure the boot sequence is correct for the devices installed on your computer.
  • If the problem persists, contact Dell.
Apr 20, 2010 | Dell Dimension 8400 PC Desktop
I cant boot my server the hard drive can not be detected
Try taking the side off and removing and replacing all the hard drive leads. Remove and replace all the scsi drives and generally check for loose connections. If this does not work you will need to post more infomation.
Oct 29, 2009 | Dell PowerEdge 1800 Server
Hi i have a dell poweredge 2850. Orange LED blinking
It sounds like a hard disk has failed or fallen out of sync.
This can be a serious problem if not addressed ASAP.
Call Dell, they have lifetime phone support for their servers.
Write down the Express Service Code and Service Tag number that is on the server chassis before you call.
This is the last number I used for server support: (800) 945-3355
If it doesn't work you should be able to find a valid number at support.dell.com
I hope this helps.
Jun 12, 2009 | Dell PowerEdge 2300 Server
The aid hard disk in the containers cannot be found by the system
MAYBE YOU LOST YOUR CONFIGURATION BUT DO YOU SEE THEM UNDER PHYSICAL VIEW IN THE CONTROLLER BIOS?AS IT BOOTS DID IT REPORT THE CONTAINERS OR NOT POWER DOWN UNPLUG POWER CHECK THE CABLE ATTACHES TO THE BACKPLAIN, POWER UP,,,,,,GO INTO THE [PERC BIOS UNDER MANAGED CONTAINER VIEW .(A EASY WAY TO CHECK THE CABLE IS ... IF YOU HAVE A SPARE DRIVE YOU CAN PLUG IT TO THE CONTROLLER MAKE SURE TO PUT POWER TO THE DRIVE IF YOU SEE THE DRIVE WELL THAT ELIMINATED THE CABLE)
GOOD LUCK
Apr 01, 2009 | Dell PowerEdge 4400 Server
Setup can not find any hard disk while installing win 2003
During setup you must specify any raid drivers that are required. Have the raid controller driver on floppy and insert when prompted.
Mar 31, 2009 | Dell POWEREDGE 1950 Server
Beeping PowerEdge 1300
When a Dell server beeps in every 3-5 second that mean it comes from Raid controller.
Dell calls PERC Controller.
It usually reason of a disk failure.
Install open manage server administrator on your server.
See which disks are failed ?
Try to run Power edge diagnostics on the failed disk.
If it passes the test reseat the disk.
if it fails disk has to be replaced with a new one.
If passes the quick test, reseat the disk and update disk + perc firmware and driver to the latest level. that will solve the problem!!
99% beeping comes from perc controller because of a failed HDD
cheers
Aug 18, 2008 | Dell PowerEdge 1300 Server
Constant beep on poweredge 840 appears to work alright
Hi
Besides standard beeps codes indicating Processor, CPU, Memory or Systemboard failures,
Dell PERC (PowerEdge Expandable Raid Controller) or SAS Controllers (Serial Attached SCSI) generate beeps to alert failures on the RAID sub-system.
From your description of the issues (when the beeps start), i suggest you check PERC or SAS setup. If you have Dell OpenManage Server Administrator installed, you can log-in and check for more information. Additionally, on the next reboot check the PERC/SAS/CERC boot up for any messages. You may also access the PERC (Ctrl+M), SAS (Ctrl+R) CERC (Ctrl+A) Management Menu for specific failures and attempt a rebuild (assuming you have a redundant RAID Volume).
You can also speak with Dell Support and raise a warranty call if the system has warranty.
Note: PowerEdge 840 would ship with PERC or SAS Controller. PowerEdge 700 will ship with PERC or CERC.
Mike
Apr 02, 2008 | Dell PowerEdge 700 Server
Dell PowerEdge 2300 Server Logo
743 people viewed this question
Alun Cox
