Question about Panasonic Lumix DMC-FZ18K Digital Camera
Dust Just got a panasonic fz18 you can look past the lens barrel straight into the camera body,nasty for getting dirt into it Can one install a couple of extension rings on the barrel housing and attach a filter to it to keep the camera clean Thanks Jan
I have a Panasonic FZ18 and the Lens is not interchangeable so why would one be removing the lens in the first place?
Posted on May 16, 2008
  • 111 Answers
This problem has plagued digital slr users for years. Unfortunately adding extension rings will change the focal length of whatever lens is used (could be a plus, but most likely not). Best thing is to change lenses in a clean environment, keep all your lenses clean and capped when not in use. Also when changing lenses it may help to keep the camera inverted with the body opening pointing downward. If stuff gets inside (which it will its only a matter of time) take it to a shop for a sensor cleaning (typical $40-50) or read about cleaning tools here http://www.photosol.com/
Posted on May 14, 2008
  • Mark Day
    Mark Day May 15, 2008
    If what youre suggesting is some sort of vacuum to **** out any dust from the camera body, then I can tell you straight up that its not going to work. The issue is that the ccd sensor is electrostatically charged. Dust is drawn to it where it sticks like a magnet. Stirring up any dust inside the camera will only worsen the problem. My suggestion of professional sensor cleaning or the use of eclipse fluid and sensor swabs still stands.
Camera was placed in a dusty/dirty environment. Now when turned on the lens tries to come out but dose not open. What can I do ??
Dust or dirt will do it, especially around the gaps of the lens barrels (a single grain of sand can jam it). Recommend trying the sliding paper and vacuum fixes of this article.
Jul 05, 2011 | Panasonic Lumix DMC-ZR1 / DMC-ZX1 Digital...
I have a quantaray 2.8 macro lens for Nikon. The lens barrel stuck and could not move. It was fixed by Ritz Camera once it was less than one year old and there was still in warrantee. Right now maybe the...
Right now you are on the "Free" side of the list. I'm an independent not associated with any of the camera, lens or accessory manufacturers I'm a Freelance Photographer that uses this equipment to make my living. Repairs to a lens like this if it were in Canada would run about $120.00 but I'd be asking Ritz cameras first if there were a warranty. If the lens is working for you and you are satisfied with its performance then It's up to you if there is no warranty and it's a pay to repair deal. What I would be asking myself is why is this lens barrel sticking and my answer would be dirt. Lint and oils from our hands will enter the lens barrel and cause all sorts of problems. Also if you use this lens in the field there is sand and other environmental nasty things that get in between the two barrels. I see a lot of questions about these Quantaray lenses, never used one so can't really voice an opinion except that non of the lenses I've owned over the past 30 years have ever stuck because dirt has entered the lens.
Jan 24, 2011 | Quantaray 50mm f/2.8 AF Macro for Nikon
Hi, The zoom on my camera keeps on getting stuck and sometimes it wont turn. Is there a repair center in South Africa for Panasonic Lumix?
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Ps, Ek is self van Suid Afrika, laat weet as dit wek.
Groete
Regards
Andrea
Aug 30, 2010 | Panasonic Lumix DMC-FZ18 Digital Camera
Lumix fz 18 zoom is stuck wont take pictures
Hello
Regards
Andrea
Aug 25, 2010 | Panasonic Lumix DMC-FZ18 Digital Camera
Panasonic Lumix System Error (zoom)
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Aug 06, 2010 | Panasonic Lumix DMC-TZ1 Digital Camera
I have a panasonic lumix dmc-fz18, it has developed what look like three dust spots on the sensor, its just over two years old, shouldnt this camera be sealed against dust? If the above is comfirmed then I...
It's impossible to seal against the inevitable dust. The best we can do is protect our cameras as much as possible. If you want to be able to clean a sensor, you need to step up to a DSLR camera. Maybe you're ready...I know you will be very happy with one even though they are a bit of an investment to get started.
Jan 30, 2010 | Panasonic Lumix DMC-FZ18 Digital Camera
Lens stuck open position
you can try a couple of things genltly twist the lens one way until you hear a sound,turn off and try powering up again,also particles of dust or dirts can become cloged of lodged in the gears that move the lens, this may cause the lens to stuck,try blowing the area between the lens barrel and the camera body to remove some dust and dirts. hope this helps
Jan 03, 2010 | Canon PowerShot A560 Digital Camera
I have some dust on the sensor of my fx500. not sure how it got there, but it's there. anyone tried taking one of these apart for cleaning? is it fairly straight forward?
I have the same camera and the same problem as I always keep the camera with me in my pocket. The camera can be taken apart and cleaned if you have a clean work space. I would not attempt this if you do not have experience separating electronics with delicate ribbon cables. Wants the camera is apart it is easy to see why this happens as there are several gaps in the lens barrel. If you have patience it can be done but I recommend as much of a dust free environment as possible, some cleaner for a DLSR sensor and some air duster. When I tear my camera down I start with the bottom and work my way to the sides. The most difficult part about separating the camera for me is the top portion of the camera where the zoom control an on off switch is located is attached permanently to the flash and the flash capacitor. This needs to be wiggled with the utmost care and pulled straight up and out of the camera. Once the camera body, sides front and top are separated the LCD screen lifts up and there are a couple of screws that screwed directly into the back of the sensor mounting bracket area once these screws are removed the sensor is easily accessible. Again you do not have experience with not touching anything while you're doing work like this do not attempt this. Once the sensor is pulled up a can be dusted and cleaned my typically blowout the lens barrel with the air duster, obviously making sure that you do not tilt the can because even the slightest residue will set you back even further.
Nov 15, 2009 | Panasonic Lumix DMC-FX500 Digital Camera
Lense stuck out and can't take pictures
In all probabilities, the lens barrel must have tilted, preventing the lens from retracting into the barrel. It could also be possible that some dust particles got stuck in between the segments of the lens barrel. Check for these. Try to straighten the barrel without using much force, and try to remove any dust particle that got stuck between the segments.
Jan 14, 2009 | Panasonic Lumix DMC-FX01 Digital Camera
Open Questions:
Panasonic Lumix DMC-FZ18K Digital Camera Logo
119 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
