OK, in a nut shell -- Cant get XP to start. Computer ONLY reboots and reboots. Want to ERASE hard drive and start over OR SELL COMPUTER after erase. HOW CAN I ERASE HD -- HOW DO I GET TO THAT POINT AS COMPUTER IS (ONLY) BOOTING ??
    Sergeant:
  • 172 Answers
You need an XP CD.
insert the disk to the CD/DVD drive and boot from CD
you can change the boot sequence in bios or press F12
when it says press any key to boot from CD rom
press anything on your kybd
and let the windows to load
it will ask you if you want to repair or install windows press enter
then press F8 to accept the EULA
then press ESC to install a fresh copy of windows
you can delete the partition by highlighting the drive that says
C:\Windows then press D to delete then Press L to confirm
and follow the onscreen instruction
hope this help
Posted on Sep 07, 2010
Missing or corrupted system 32 wont install off windows xp disk
try going to the bios and change the boot sequence for hard drive to cd
put the copy of xp in the external hard drive and reboot the computer
when it powers up it should boot up off the external hard drive
if that works go to computer --device manager and find recovery section
you may also go restore to a previous date and try for a fix from there
go google and get to microsoft and find that file download for xp and install it
if all that works shut the computer down and reboot back to bios and change back to reboot from hard drive
remove the disc from the external hard drive
Mar 13, 2017 | Compaq Mini 110c-1001NR Notebook
I need to know how to unintall all the data on my WD hard drive and start over again fresh. Can you help me?
Mac OS X
1 Connect the Western Digital My Passport hard drive to the computer. Power on both.??
2 Open "Disk Utility," located in the Utilities sub-folder of the Applications folder.??
3 Select the drive you wish to reformat. Typically, drives appear twice; choose the furthest left.??
4 Click "Erase," and pull down the Format menu. Choose "FAT32." Enter a hard drive name, if desired.??
5 Click "Erase." A confirmation screen will appear, stating that all information on the drive will be lost if erased. Click "Erase." Once completed, the erased drive will function on both Windows and Macintosh systems.??
Windows
1 Download and install the Western Digital FAT32 Formatting Utility.??
2 Connect the Western Digital My Passport hard drive to the computer. Power on both.??
3 Open the FAT32 Formatting Utility and select the desired external hard drive. Ensure that "Restore factory original FAT32 partition" is selected.??
4 Click "Start." A warning message will appear, stating that all data on the drive will be destroyed. Click "OK" to continue. Click "Yes"' to navigate through.?
May 03, 2011 | Computers & Internet
Could not proceed to boot
To check your hard disk drive if its detected, turn on your computer and press DEL or F2 to enter BIOS setup. Then go to standard cmos setup and there should be the hard drive detected as Primary or Secondary IDE or SATA. If detected and not loading into windows that case your operating system is corrupted. However If your hard drive is not detected on your bios, turn off your computer and unplug and plug your hard disk drive then turn on your computer start pressing again DEL or F2 then check again your hard drive if it is detected.
If your hard disk drive and cd/dvd rom drive are the same cable you can switch the cable to check if the cable of the hard drive are ok. After you have checked and you found out that the two cables are ok that means you will have to format your computer. But you must backup all your data and files before doing so. Formatting your computer will erase or delete the entire space of the partition which you perform formatting.
Here is the video tutorial on how to format your computer using windows xp
Have a nice day.
Apr 05, 2011 | ASUS Computers & Internet
BSOD after power failure during check disk-now I cannot reboot from recovery console or disk. How can I uninstall the OS then reinstall OS from eMachines T6524?
You need to enter the BIOS. immediately upon starting the computer start tapping either the F2 or the tab button. Once in the bios, go to boot order and set the cd/dvd drive as the first boot priority, hard drive second. It is ok to leave this permanently, save and close settings which will reboot the system and considering everything goes as planned you should be able to start up from a disk and then repair or replace XP. When replacing XP remember to delete partition and write a new copy. THIS WILL ERASE ALL INFO ALREADY ON THE HARD DRIVE!!!
Feb 23, 2010 | E-Machines T6524 PC Desktop
Erase a hard drive
IF you have the XP installation CD you can easily do that, Just set your BIOS to boot from the CDrom then put the XP CD on your CD drive then restart the computer , so your computer will automatically boot from the XP installation CD then on that process you will have an option to format the entire hard drive that you have using the XP CD installation, then just let the installation finish...
Oct 16, 2008 | Computers & Internet
Installing windows XP - Error encountered
Can you reboot and get into windows or is now corrupt?
What do you mean by 'uninstalled XP'??
You cant uninstall it unless you format the drive, in which case the recovery discs are now probably useless as they rely on a folder on the HDD called i386.
Recovery discs normally dont have the OS on them, they rely on the I386 folder to gather info about the computer and then restores it to the state when it was new.
If you can acess the system, reboot and go into the bios and change the boot sequence to CD, then insert the first recovery disc. then save the settings and the computer will reboot and start the recovery process again, this should clear up the error.
If it does not it will be because the i386 folder is missing in which case you can either explore the recovery discs for it or you will have to buy a copy of Windows XP.
Aug 11, 2008 | Toshiba A105-S4054 Notebook
Want to erase drive
If your Laptop is purchased with Recovery Disk, you can use that disk to restore the default setting of your laptop. It usually FORMAT your hardisk and erase all programs and files saved on your Hardisk. If Recovery Disk is not available then you can simply use your provided Windows Installer to format your Laptop and install a Fresh Windows on your Laptop, be sure to format the Whole Disk Drive to erase the files.
Jun 11, 2008 | Dell Inspiron™ E1505 PC Notebook
Can't erase two old videos
go to applications then utilities then open disk utility
on the on the left side all the hard drives will be listed. click on your camera then click erase, look here click "erase" and then "ok".
PC:
go to start, my computer. in the new window your camera name will apear right click then click format. make sure that quick format is checked and then click "ok".
Feb 21, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Formating
You can do format while rebooting your pc and opening it in safemode command prompt that arrives by pressing F5 or F8. First you format the drives in which your OS is not present. Then format your primary hard drive on which OS is installed. In command prompt write C:/>formact C:\
Sep 13, 2007 | Computers & Internet
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
