Question about Brother CS-6000
Wrong type of stitch/tension not working
I'm sewing with the fabric right side up, but the stitches come out looking like they should be on the wrong side of the fabric. I tried adjusting the tension but it doesn't seem to work.
Has this machine had a lot of tension issues?  How can I make the stitches "normal" again? Is there anyway to reset the machine?
Help! Thank you!!
  • PeaceMex Aug 24, 2008
    The CS-6000i was working just fine, but all of a sudden it started
    sewing ALL of the different stitches really weird. I've only had it 10 days. I live out of the county (in Mexico) so the nearest service center is 1000 miles away. Someone PLEASE HELP!! The stiches come out
    looking all wrong on the top of the fabric - and on the bottom, the
    stitching looks correct (like the selected stitch).
    For example: when we try to use zig zag stitch #4, the thread on top of
    the fabric looks something like a sloppy stitch #12, and the under side
    looks like it should (like stitch #4). No matter what stitch I select the stitching on top comes out looking similar to stich #12 -- it also bunches up. I know it sounds like the tension. That was the first thing I tried. Then I tried changing speed, thread, fabric, and needles. But nothing changes the stich on top.
    So I have already tried adjusting the tension both up and down. We've tried
    different fabrics, unplugging the machine, cleaning everything,
    re-threading the machine, changing the needle, using different speeds,
    etc. I wrote to the company and got a form letter back telling me to do exactly what I had told them I'd already done. I don't think they even read my email.
    Thanks for any help you can give.
  • flowbee56 Dec 23, 2008
    I have a brother CS 6000 and have tried to adjust the tension to all different settings and it STILL comes out with the top thread looking normal and the bottom thread is all bunched up. I have rethreaded the machine and the bobbin according to directions and sitll no luck. I am beginning to think this machine is a piece of junk.
Found a solution to my own problem.... hope this helps someone else. Make SURE the bobbin case is seated correctly! (follow the instructions carefully). Don't put the cover back on right away after you put the bobbin case in. First check and make sure it doesn't move when you turn the hand wheel.
Also, when threading the bobbin make sure the thread passes down through the tension adjusting spring of the bobbin case.
Posted on Aug 24, 2008
I could not find a screw on the bobbin case so I took the case out and cleaned the fuzz out then put it back in as tightly as possible and tried again; this seemed to help
Posted on May 15, 2008
My thread keeps bird nesting on the bottom of my fabric what am I doing wrong? What are the correct settings for a straight stitch?
Is your bobbin threaded correctly? You should be able to pull out the thread slowly while feeling it very slightly holding back. It should not pull out easily or quickly.
Could be something wrong with your tensions, try adjusting the upper tension first by starting at the middle setting and working gradually higher and then lower till you get a neat even stitch.
Nov 29, 2015 | Sewing Machines
My runaway stitches on wrong side of fabric
Rule of thumb:
1.Too much thread on bottom then tighten top (tension).
2. Too much thread on top then loosen top (tension).
Just remember this works very well only if your bobbin is set properly.
Apr 05, 2015 | Brother Sewing Machines
Ho can i get bobbin tension right?
Bobbin tension depends on the thickness of the fabric that you're sewing on. A cotton fabric should have medium tension...but a heavy wool would need a looser tension. Best way to get the tension right is to take a few stitches, then look at the bottom side of the fabric. If the threads are loose, then tighten the tension one notch or number. Sew a few stitches, then test again. If the fabric is pulling up tight, then loosen the tension and check again. Top stitches and bottom stitches should both be the same.
Jul 04, 2014 | Husqvarna Freesia 415
Tangled thread on wrong side. The thread on the
I'm guessing it is because the tension is not just right, the bobbin might not be the right size, the thread type top and Botton might not be the same, or you just might need put in a new needle the right size.
Aug 09, 2017 | Brother CS-6000
I am sewing a knit fabric on my Lily 540 and it is skipping stitches like crazy. I have tried adjusting the tension and the stitch length with no success. seem to always have a hard time with getting even...
It sounds like you may be using the wrong needle. For knit fabric you need a ball point needle in order for it to sew correctly. A regular sharp type needle can cause the stitches to skip. Also make sure you have the right size for the type of fabric. Lighter weight fabric needs smaller size needle and thicker types need bigger sized needles.
Also make sure you have the right presser foot and the right pressure on the presser foot to get nice even stitches. A roller foot helps when sewing knit fabrics.
May 18, 2011 | Husqvarna Lily 540 and 550
Hi, I have been using a zig zag stitch on cotton, but recently the stitch has appeared on the wrong side of the fabric - that is the side that I am looking at shows the back of the stitch, and the...
Sounds like the bobbin case tension is not properly adjusted. Try turnibg the adjusting screw about 1/2 to a full turn clockwise and see if it is better.
Jun 13, 2010 | Brother XL-5700 Mechanical Sewing Machine
Kenmore sewing machine #16227 needle thread making big loops on wrong side of fabric. Changed needle, cleaned, adjusted/readjusted and readjusted needle and bobbin tension. Will sew a decent stitch...
It is most likely because you have it on a type of stitch but did not switch the didstance that you want the zig zag to be. Just change you stitch or your distance.
Nov 20, 2009 | Kenmore Sewing Machines
Stitches are on the reverse of the fabric
hi! there,
set dial tension to #3 and stitch tension to #12 try on straight
sewing,check bobbins winder if thread was wind on clockwise rotation before sewing.if ok try to sew and observed the change.
have a nice day regards,dont forget to rate me
thank's
Apr 09, 2009 | Singer 7444 Mechanical Sewing Machine
JANOME RX18S
If it was sewing correctly BEFORE the needle break...why did the needle break in the first place?...and what fixes did you make?
If it sewed properly...what changed?
Cut your upper thread close to the spool...make sure the presser foot is raised and pull the cut off thread section through/out of the machine from the needle area (sewing direction...do not pull the thread backwards!)
Clean out the bobbin area...remove any traces of lint or pieces of thread...look for any broken off needle pieces... brush the bobbin area out....then add a drop of sewing machine oil (but only if your manual says to oil that area).
Remove the needle plate to expose the feed dogs...brush/clean out that area too and add a drop of sewing machine oil...then secure the needle plate back on.
Replace the needle...do it again...yup...some needles arrive bad from the factory. Make sure the needle is inserted and positioned properly. Then thread the machine WITH the presser foot in raised position. (The thread needs to get seated into the upper tensions.)
..with the.presser foot down...thread the new needle.
Oh...and use the correct needle for the thread. (a universal 80/12 is standard).
Thread can cause issues too. Try a different bobbin, or maybe a different spool of thread to see if that makes a difference.
Mar 25, 2017 | Janome Memory Craft 9500 Computerized...
Brother CS-6000 Logo
698 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
