Question about Garden
The mower head on my stihl FS55RC won't turn - Garden
  • marilyn18 Sep 07, 2010
    The mower head on my stihl lawn trimmer won't turn. I have removed thd head and it is not disconnected. What else can I do to get the mower head to turn?
    This was very helpful. Thank you so much.
    Brigadier General:
  • 3,917 Answers
Posted on Sep 07, 2010
  • 11,896 Answers
These are usually turned by a shaft or cable. Remove the head and make sure that it is not disconnected .
  • Nate Stansfield
    Nate Stansfield Sep 07, 2010
    The Belt may be worn or frayed; replace it. See your Owner's Manual for instructions on replacing the Belt. Check for proper alignment of the V-Belt and verify Belt Guide Positions.If the Trimmer Head still will not spin, follow the try adjusting the Belt Tension through the Trimmer Control Cable
Stihl fs 55r head won't turn
Check drive shaft. Some models have a flexible cable drive shaft that is prone to breaking. also make sure the drive shaft is engaged in the clutch drum and in the gear head end.
Mar 25, 2013 | Stihl Garden
How to change heads on stihl fs 81?
There should be a hole in the gear box for a pin. Insert something in that hole to hold the shaft from turning and unscrew the head. I believe it is reverse thread
Jan 01, 2013 | Stihl String Trimmer Brushcutter Service...
Stihl fs55rc rotor spring
Determine which direction it needs to go to pull the cord out of the hole and COMPRESS the spring. put the tab on the tail end into the housing, and put the white spool in the inner end of the spring. rotate the spool while keeping your finger on the spring to hold it onto the spool. Once it's sufficiently wound enough to fit back into the housing, insert it and reinstall the washer and clip.
Jun 04, 2012 | Stihl Garden
Stihl fs55rc crab problem willnot run full power
You probably need to adjust your carburetor. You can slowly turn the jet closest to the air filter in 1/8 turn increments while at full throttle and check the response. Ear protection is necessary to be able to distinguish the RPMs from the audio pitch of the running engine.
Mar 28, 2012 | Stihl Garden
Stihl FS 44 weedeater/trimmer and I can't get the head off to repair/replace broken plastic pieces. The line spool is off but I need to remove the head itself and I can't find the manual
Hi, there is a hole down through the top of the gear head. Place a pin punch or small screw driver down through the hole and rotate the head until it locks. Then grasp the head firmly and undo it (left hand thread). Hope this helps, regards Phil.
May 08, 2011 | Garden
Stihl fs170 parts
Unfortunately, Stihl parts are only available through your local Stihl dealer. Stihl will not allow dealers to post parts diagrams or pricing info online. Go to www.STIHLdealers.com to find your nearest dealer.
Aug 30, 2010 | Garden
STIHL Trimmer, Model FS55RC Parts & Repair manual
Several online parts dealers have detailed parts breakdown diagrams of many different machines. Try doing a search maybe and see some of them come up, Repair manuals would be great but they are not normally available on these sites
Aug 07, 2010 | Garden
Stihl fs 45 trouble getting the cutting head to engage
repair shop shortened shaft just a touch to take up slack in drive cable
Aug 02, 2009 | Garden
Garden Logo
964 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
