Back to:
Tags:
HP Pavilion DV1010  PC Notebook
Upgrade for processor
posted by lil logan on May 14, 2008
HI, Does anyone know what newer processor is compatible for HP DV1010US notebook computer. Thank you!
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on May 14, 2008
Helpful (85)
EngineerGR
Rank:Guru Guru
Rating: 95%, 98 votes
Dear lil logan,
The most advanced cpu regarding this laptop would be the
Intel Pentium M 745 (1.8-GHz) with 400-MHz front
side bus (FSB).
This info is official and can be found at the following HP Service manual shown below. (Section 1-2)
http://h10032.www1.hp.com/ctg/Manual/c00444244.pdf
Many Regards
EngineerGR
Please rate this solution as Fixya if you found it to be your answer! This keeps us going :)
Comment by EngineerGR, posted on May 14, 2008
Just a note..
The rest of the CPU's that this laptop is supporting are the following..
Intel Pentium M 735 (1.7-GHz) with 400-MHz FSB
Intel Pentium M 725 (1.6-GHz) with 400-MHz FSB
Intel Pentium M 710 TJ85 (1.4-GHz) with 400-MHz
Intel Celeron M 340 (1.5-GHz) with 400-MHz FSB
Intel Celeron M 330 (1.4-GHz) with 400-MHz FSB
Regards
Rating Locked! (?) lil logan has rated this solution as Helpful
Thank You!
Was the solution helpful?
Show your appreciation by commenting on upgrade for processor:
I don't want to Accept this solution
Can you Help with these PC Laptops problems?
PC Laptops
The charger slot on my Amilo Pro v2055 laptop had become...
PC Laptops
I don't really have any problem with the laptop now... I...
PC Laptops
Pls help me to find SATA drives to be integrated on XP...
PC Laptops
when i want to send webcam to any one which is in my list...
PC Laptops
From time to time for work, I would like to change...
Loading problems.
Repair Service
Find PC Laptop Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
