Question about Acer Aspire 7520-5757 Notebook
My acer aspire 7520 will only charge when switched off
  • 2,567 Answers
Try removing the battery from the laptop & see if it will power up. If not, then you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether
Posted on Sep 07, 2010
4 Suggested Answers
  • 103 Answers
SOURCE: Acer Aspire 7520 turns off and on repeatedly
The reason why your pc is repeating this cycle is because a file from windows is corrupt or lost causing windows not to be able to start up. This can be cause by a windows file being infected with a virus or worm and is then removed by an antivirus. You would need to Re-install your operating system software or repair it using an operating system cd.
please rate me. thank you.
Posted on Dec 03, 2008
tat4u
  • 520 Answers
SOURCE: Reattach Acer Aspire laptop Key?
they just clip on.put key back in place and push down firmly.you may have to wiggle it a bit back an forth.
Posted on Mar 03, 2008
ericvb2005
  • 194 Answers
SOURCE: how do i connect acer aspire 7520 to tv
if your TV has a VGA connector,,, buy a cable to that ...
vGA port at the back panel of ur laptop TO VGA port of your TV
Posted on Oct 19, 2009
Touch pad not working
It is possible that the micro switch underneath the button is defective. If this is the case, then the laptop ,(if still under warranty),should be returned to the manufacturer for repair. Otherwise, a new motherboard will be required as the micro switches cannot be replaced.
Dec 18, 2013 | Acer Aspire 7520-5185 Laptop
My acer aspire 7520-5185 will not turn on
Hello. There is a hardware failure with the laptop not the AC charger. AC chargers have some range of protections of their own. If the power requirements of the laptop are bigger then what the charger can handle, the charger will turn off. Also other parameters can bring the charger offline. In your case, you have a problem with a small chip, the battery charge controller unit, witch regulates the amount of current required to propperly charge the battery. When this thing fails, the charging requirements for the battery are reported rong and the AC charger is forced to give more power then necesary. This results in disconnection of the AC charger ( an internal fail safe of the
AC charger) and the laptop to swich back to battery power. When the laptop is turned off, it can charge the battery because the power requirements are low, having all processor, main board, hard disk etc turned off. Therefore the AC charger can handle the load. However you will need to have it checked by a service center as it is a hardware fault. Both AC charger and laptop needs that check.
The charge controll circuit needs to be replaced probably. It will be a somewhat expensive repair. Don't buy any other battery untill you have the laptop checked.
Acer Aspire 7520
Jan 13, 2013 | Acer Aspire 7520-5185 Laptop
Laptop is plugged in but the battery is not charging.
how do i remove the keyboard on my acer aspire one ,Model No.ZG5?
Nov 21, 2010 | Acer Aspire 7520-5185 Laptop
Mijn probleem is ik heb een acer aspire 7520 laptop als ik hem opstart boot hij steeds door,als ik windows xp wil instaleren kan hij de harddisk niet vinden.
Acer Aspire 7520 heeft een SATA-harddisk, kan Windows XP niet installeren. Lees deze
http://news.softpedia.com/news/Install-Windows-XP-On-SATA-Without-a-Floppy-F6-47807.shtml
Oct 19, 2010 | Acer Aspire 7520-5185 Laptop
How do i turn on wireless network switch on aspire 7520
user manual here http://us.acer.com/acer/service.do?LanguageISOCtxParam=en&miu10einu24.current.attN2B2F2EEF=3750&sp=page15e&ctx2.c2att1=25&miu10ekcond13.attN2B2F2EEF=3750&CountryISOCtxParam=US&ctx1g.c2att92=453&ctx1.att21k=1&CRC=2054404012 Theres some special keys at the top of the keyboard and one of those has a symbol - which i cant post here - but it looks like its the the key on the far left of the set - Page 26 of manual
Apr 19, 2010 | Acer Aspire 7520-5757 Notebook
Hello sir,my laptop is acer aspire 7520 no charging,no run on main,run on battry only,laptop power adaptor led is damage,
this could be due to the fault in the ac adapter,please try swapping another adapter if it works then you need to replace your adapter.
Jun 20, 2009 | Acer (ACERMOTHERBOARD)
Acer Aspire 7520-5324
clean the board by crc or c40... or you can use coller fan external to avoid to much heating
Jun 07, 2009 | Aspire Acer 7520-5324 Laptop
Acer Aspire 7520-5757 Notebook Logo
723 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
