Question about Compaq Presario M2000 Notebook
Hard disk faulty how to replace - Compaq Presario M2000 Notebook
    Problem Solver:
  • 10 Answers
The online guide is here:
http://www.scribd.com/doc/7994162/Compaq-Presario-M2000-Maintenance-and-Service-Guide
I would go to (page 2-5 of the manual above) first and run a Hard Drive test from the Tools menu, before replacing.
Then go to replacement procedures (Page 5-7 of the manual) and it will instruct you, it is very simple, usually taking out two screws, removing the caddy (plastic holder). You then unscrew the old hard drive from the caddy (four screws) and then screw in the new hard drive (four again), slide it in, screw the caddy in (two screws) and voila', your new hard drive is installed.
This does NOT include instructions on how to backup your files, re-install your software or anything OTHER than replacing the physical hard drive.
You will need to format the new drive and install an operating system and software.
If you need further instructions, please ask.
Posted on Sep 07, 2010
When turning on my computer, I am taken to a black screen where I see: A disk read error occurred. Press Ctrl alt del to restart. How do I fix this?
This error occurs when the notebook cannot boot up from the hard disk. The hard disk may be faulty.
Try re-seating the hard disk to make sure it makes proper connection to the motherboard.
Next go into the BIOS configuration and check to see if the BIOS detects the hard disk, if it is not detected the the hard disk is probably faulty.
To get your notebook operating again, replace the faulty hard disk, install Windows on the new hard disk, plus the notebook's device drivers and your programs.
Jan 29, 2011 | Dell Inspiron 6000 Notebook
My conon IR 105 photocopier shows E 602-0001 on screen it does'nt work
i guess you have to replace hard disk
The wiring is faulty (short circuit, open circuit, disconnection). The installed
system file is faulty. The hard disk drive is faulty. The main controller
PCB is faulty.
Condition
0001 A fault is detected in the mounting of the hard disk when the system
on the hard disk is started up using the BOOT ROM.
Oct 27, 2010 | Canon imageRUNNER 105 Copier
Not detecting hard disk
first thing to do is to remove and reconnect the hard disk to the system. devices like hard disk not detected often is just a result of loose connections. if this will not work, may be a good idea to test another hard disk with your computer or test the hard disk on another computer to isolate if the hard disk will need to be replaced.
Sep 04, 2010 | Computers & Internet
My hp laptop says replac hard disk 1 and will not
There seem to be a problem with your hard disc, that is why it is saying replace hard disk 1.
It either is because the connection of the hard disk is loose or the hard sick is faulty.
All you have to do is to unscrew the compartments below, You will have direct access to the Hard disk. Take note of the cable to see if it is loose, if it is, just adjust it.
And if it is not loose, disconnect it from the board and reinstall it back.
Then turn it on again. If it does the same, then the hard disk is faulty and needs replacement.
Replace the hard disk and it will be in good condition again.
Take care
Jun 23, 2010 | HP Pavilion dv4000 Notebook
P4pe x cannot detect hhd drive
If the BIOS cannot detect the hard drive then :-
1. The hard drive data cable or power connector may not be inserted properly.
2. The motherboard disk controller is faulty.
3 The hard disk is faulty.
To test the motherboard disk controller, connect another hard disk to the motherboard and go into the BIOS to see if it detects the hard drive.
If it detects the hard drive, then the other hard drive is faulty and need to be replaced.
Another way to test the "faulty" hard drive, connect the hard drive to an USB hard drive adapter and plug it into a working computer's USB port. If this computer sees it as an external hard drive and you can open the folders and files the the hard disk is OK, and the fault is a faulty disk controller on the motherboard.
Jun 14, 2010 | ASUS P4PE-X Motherboard
Hardrive not detected
You may have a hardware fault.
Try re-seating the hard drive.
Then check the BIOS to see if the hard disk is detected.
If the hard disk is not detected then either the hard disk is faulty or the disk controller on the motherboard is faulty.
To further test the hard disk, remove the hard disk and connect it to an USB hard disk adapter and plug it into a working computer's USB port. If this computer cannot see it as an external hard drive nor can you open the various folders and files, then the hard drive is faulty.
Then you need to replace the faulty hard drive, install Windows on the new hard drive, together with the laptop's device drivers and your programs to get a working laptop again.
Feb 25, 2010 | Asrock 775i65G Motherboard
Hi, trying to install windows xp on an acer 5920g. After the installation cd asks you to hit the enter key to start the installation there is a complaint about not finding a hard drive to install to. I...
You do not need a hard disk controller driver. The hard disk is configured in the BIOS automatically.
If Windows install cannot detect the hard disk then either the hard disk is faulty or the motherboard disk controller is faulty.
Re-seat the hard disk, it may not be making proper electrical connection and then go to the BIOS configuration to see if it detects the hard disk, if not then the hard could be faulty or the disk controller is faulty. In most cases it is the hard disk that is faulty.
To further test the hard disk, remove the hard disk and connect it to an USB hard drive adapter, then plug it into a working computer's USB port. If this computer does not see it as an external hard drive or you cannot open the various folders and files, then the hard disk is definitely faulty.
Then you need to replace the faulty hard drive.
Feb 24, 2010 | Acer (91AD275018) SCSI Controller
My acer 7520 opens with an error reading NVIDIA boot agent 249.0542, then reads PXE-E61 media test failure, check cable, PXE-M0F exiting NVIDIA boot agent.
This error message could be a faulty hard disk or a faulty disk controller.
Reseat the hard disk to see if the problem is fixed.
If not go into the BIOS settings and check if the BIOS can detect the hard disk.
If the hard disk is not detected then remove the hard disk and connect it to an USB hard disk adapter and connect it to a working computer's USB port. If the this computer cannot detect it as an external hard drive then the hard drive is faulty. Then the Acer needs a replacement hard disk and Windows installed together with the laptop's device drivers and programs etc.
Oct 20, 2009 | Aspire Acer 7520-5324 Laptop
Dell latitude wont turn on
If you hear the hard disk clicking, most likely you have a faulty hard drive.
Go into the BIOS configuration and see if the BIOS has detected the hard disk, if not this means the hard disk is faulty or the disk controller is faulty.
To determine if the hard disk is faulty, remove the hard disk and connect it to an US hard disk adapter and plug it into a working computer's USB port. If this computer sees this as an external hard disk/external storage device and you can open the various folders and files then the hard drive is OK.
If the hard drive is not detected then it is faulty and you need a replacement hard disk and Windows needs to be installed on this drive to get the Dell operating again.
Jul 18, 2009 | Dell Latitude 100L Notebook
GETTING ON MY LAPTP: PXE-E61: Media test failure, check cable
This error message can be caused by a faulty connection to the hard drive or a faulty hard drive or a faulty disk controller.
Go into the BIOS configuration to see if it has detected the hard drive, if it is not detected that is why the laptop won't bootup.
To confirm or check if the hard drive is faulty, remove the hard drive and connect it to an USB hard drive adapter and connect it to a working computer's USB port (you may need assistance from a computer savy friend).
If this computer cannot see this as an external drive then it is faulty. If the computer can see this drive as an external drive and you can open the folders and files on the hard disk then the hard drive is OK and the fault is probably a faulty disk controller on the laptop. A faulty disk controller is part of the motherboard and the only fix is a replacement motherboard. This may not be a cost effective solution and it may be better to put your money towards a new laptop.
Jun 27, 2009 | HP Computers & Internet
Compaq Presario M2000 Notebook Logo
163 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
