Question about Refrigerators
Fridge doesn't feel cold freezer works fine. The airflow in the back of the fridge has two holes were the air comes through it feels weak and seems to only pass through the right side.
    New Friend:
  • 50 Answers
Try to unplug your unit for 2-3 hrs then plug it in..this way you could remove all the accumulated ice inside your fridge..
Posted on Sep 07, 2010
What would cause the airflow to stop to fridge when freezer door is closed? (kenmore model 106)
Ice in the path of air flow to fridge. The freezer also kkeps the fridge cold via a fan that blows the cold air from feezer to fridge.
Aug 21, 2011 | Kenmore Refrigerators
My freezer frosted over everything because the door was not shut tight and now it will not clear.
take out all the food out of the freezer,unplug the fridge and get a hair dryer and start melting out all the ice in the freezer,then blow the hot air into the vent holes on the back wall until you don't see any more water dripping down through the slots in the back wall.turn the machine back on,open the fridge door after around 5 or 10 minutes and if you feel cold air blowing into the fridge you fixed the problem,if you don't feel cold air keep hitting the inside back wall with the hair dryer and keep blowing the hot air into the holes in the back wall.all that it does is the freezer gets cold and there's a fan behind the back wall in the freezer,the fan blows the cold air into the fridge side,if the air ducts are frozen the air can't circulate into the fridge section so you have to melt the ice out so the cold air can blow from the freezer to the fridge.good luck,if you have another fridge remove the food and unplug it and leave the doors open for a day and it will melt out.good luck
Jun 16, 2011 | Kenmore 65234 Bottom Freezer Refrigerator
Refrigerator portion on top does have cooling but freezer on bottom works fine. I have read that the cooling all happens in the bottom and a fan transfers cool air to the the top.
if the fridge part is cool and freezer is fine what problem are you having?is the fridge not cold enough? a common problem with bottom mount freezers is the freezer door doesn't get closed all the way,warm air enters the freezer mixes with the zero degree air and freezes up the air ducts,when you open the freezer door you should hear the fan blowing,if it is check the ceiling in the freezer to see if ice is on it,check the packages for frozen water droplets and stick your hand in the fridge where the air ducts are to see if you can feel cold air blowing into the fridge,if you can't feel air blowing into the fridge,unplug it,open the freezer door,remove the top basket and remove all the food out of the bottom basket,with a hair dryer blow into the back wall into the vent holes and melt out all the ice in the ducts,you'll see water dripping down through the vent holes,when the water stops dripping plug it back in and see if the fan is blowing the air into the fridge.also you can remove the bottom kickplate and you should see a tech sheet in it,read it and it will tell you how to put the machine into defrost,it will stay in defrost for like 20 minutes,you can do this instead of unplugging it, there's a heater that comes on behind the back panel in the freezer,this can help you melt out the ice but if it seems to hard to do just unplug it.
May 25, 2011 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
No cold air blowing in fridge but the freezer is working?
The fan that blows cold air out of the freezer into fridge is not working or the passage is blocked check fridge side wall verify openings from freezer are clear and feel for airflow. I need a specific model # to provide better info.
Mar 17, 2010 | KitchenAid Refrigerators
Freezer cold, fridge part cold at first then warming
hi friend
it is fan problem check it....it may also be a thermostat not working proper,,check them both ,
thank u,,,,,,,,
May 03, 2009 | Estate TT18TKXKQ Top Freezer Refrigerator
Refridgerator not very cold
It could be some many things, to save time let me give you this check list:
Do what you feel qualified to do.
If you found this helpful please Vote. Good Luck!
Mar 04, 2008 | Kenmore 64823 Top Freezer Refrigerator
Freezer okay, fridge warm
any time the compressor is running the fan in the freezer should be running now you need to empty the freezer do you see a lot of frost on the back wall of the freezer you either have a defrost problem and frost has built up so much its stalling the fan or the fan its self is bad pull the back cover off the freezer wall and tell me what you see please also give me your model number off the serial plate which should be in the fridge section put your freezer stuff in the fridge while we check it out
Jan 30, 2008 | Haier HTE18WAA Top Freezer Refrigerator
Fridge too cold
There is a damper motor that is behind the vent where you feel the cold air coming out in the fridge section.  That damper should open and close after making temp. adjustments.  See if you can look in the vent and see if it is wide open.  Set your freezer on the coldest setting and check this vent again an hour or so later.  If it is still wide open then that damper motor is bad.  Let me know if you find something different or have any questions.
Oct 10, 2007 | GE GDS20KBS Bottom Freezer Refrigerator
Refridgerator not cold but freezer is freezing fine.
This model uses the cold air from the freezer, defrost complet unit for 24hrs, turn back on and it should work ok. Regards Advisor
Aug 19, 2007 | Whirlpool ET0WSRXML Top Freezer...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
