Question about Kenmore 60721 Refrigerator
Only cools to 50 degrees - Kenmore 60721 Refrigerator
  • Kenmore Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 12, 2010
Can I add 50/50 antifreeze to top off my radiator and reservoir?
Yes. Some vehicles require special antifreeze, but there is a 'universal' type, and it comes pre-mixed at 50/50. This mix will protect from freezing to -40 degrees (assuming your cooling system already has 50/50 in it) and prevents boil over in the summer. A coolant checker is cheap, and you can pick one up at the auto parts store when you get the 50/50 mix to check the freeze protection level you currently have.
Theoretically, you only need to add the mixture to the reservoir and the cooling system will draw in what it needs, but I usually fill the radiator as well. Obviously, make sure the engine is cool before removing the radiator cap.
Mar 20, 2015 | Cars & Trucks
What is the on/off temperature (heat) range for a RTH111 series
Heat range: 40 to 90 degrees F
Cool range: 50 to 99 degrees F
1 degree deadband
Here's the operation guide:
https://customer.honeywell.com/resources/techlit/TechLitDocuments/69-0000s/69-2603EF.pdf
Please mark my answer as helpful.
Jan 05, 2015 | Honeywell Digital Manual Heat/Cool...
What is the high temperature range for the coolant
Your question isn't a simple black or white question, it's all relative to how many PSI is your radiator cap and what mixture of anti-freeze your running, and also, how old or new the anti-freeze (coolant) is.
The pressure cap on a cooling system is the key to raising the boiling point of the 50/50 mix of antifreeze and distilled water. For every pound of pressure cap rating the boiling of point of the above mixture raises 3 degrees. If you had plain water in your cooling system with a 15 pound pressure cap the water would boil @ 257 degrees. If you had a 50/50 mix of antifreeze and water the coolant would boil @ 265 degrees with a 15 pound cap. The boiling point would raise to 270 degrees if you had a 60% antifreeze mixture with a 15 pound cap. If you had a 70% mixture the boiling point would raise to 276 degrees.
Mar 11, 2014 | 1989 Cadillac Eldorado
What is the best temperature for white wine to be in?
It is important to keep the wine cool and in stable temperature that doesn't fluctuate very often. Bright tart white wine: 48-52 degrees; sparkling wine: 50-55 degrees and rich white wines: 58-62 degrees.
May 29, 2012 | Furniture
Fridge side working but only cooling to 50 degrees
My 14 years old GE profile refrigerator keep cooling above 50 degrees and not going down to below 40 degrees. I did clean condenser coil and fans are running fine. I adjusted temperature control to maximum cold .Do you think it my be short of refrigerant?
Jun 17, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Refrigerator 50 degrees inside
..plz check ur refrigerant gas..
Sep 17, 2009 | Refrigerators
Freezer cools to 10 degrees, refrigerator cools to 50 degrees
check if the fan is working and you are circulating air efficiently. You may check on the coils at the freezer if there are ice formation. I would suggest to have the ice melted by unplugging it and ensuring that all parts are ice free. Clean the unit while at it.
Jul 15, 2009 | Refrigerators
Ge Side by Side not cooling
check the freezer panel in the back for frosty ice build-up. is the freezer evaporator fan running?
Aug 03, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Wont cool below 50 degrees
Seems like the T-stat may have a dead spot on it since it started when you changed the settings. It is possible to trick (short) the t-stat to cause it to cool FOREVER, that would check your refrigerant charge is good. Would lean more toward t-stat problem first.
Oct 20, 2006 | Beverage-Air BM23
Kenmore 60721 Refrigerator Logo
64 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
