Question about Fisher and Paykel DE06 Electric Dryer
Making grinding noises. bearing bad? can we check it our selves?
  • Fisher and P... Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Posted on Sep 12, 2010
There is a grinding noise from the front of the vehicle while driving. All new brakes. The wheel bearings have been checked and are fine.
Is it more like a vibration and humming, than grinding noise? If so it would be a bad engine or transmission mount. To check bearings while driving.. Find an empty parking lot, Make right and left turns/circles. Making a left, if the noise get loader, the right side bearing is bad. and vice versa. Do around 10 MPH while turning circles.
May 12, 2015 | 2005 Chevrolet Equinox
1998 Chev.S10 brakes making a grinding, roaring noise
THIS SOUNDS TO ME LIKE YOU HAVE BEARINGS THAT ARE BAD. WHEN IT ACTS LIKES BRAKES ARE APPLY ON THERE OWN AND GRINDING,THAT IS THE BEARING LOCKING UP.HAVE CHECKED ASAP
Dec 23, 2014 | 1998 Chevrolet S-10 Pickup
Noise on front driver side and i replaces rotors and brakes
may be the backing plate is hitting. or it may be the wheel bearing is bad. check by making turns and see if the noise goes away or starts grinding like a washing machine. IF grinding is worse replace wheel bearring.
Apr 16, 2013 | 2005 Pontiac Montana SV6
What causes my 2002 dodge Durango make a grinding noise when I turn right
sounds like you have a bad wheel bearing. the play in the bearing causes the brake rotor to rub on the caliper or the abs sensor rubs on the toner ring of the rotor.. check your wheel bearing.. hope this helps..
Jul 06, 2012 | 2002 Dodge Durango
When I turn the steering wheel to make a right hand turn it grinds and clunks.
take a look at the front drive axle joints and also wheel bearings. this noise may be due to a bad ujoint and as you turn the joint binds up and makes noise, same as a bad wheel bearing. the wheel bearing would make more of a grinding noise as it doesnt hold the wheel and brake rotor in place and the rotor may be hitting the caliper bracket so i would start by checking this stuff first. good day.
Sep 11, 2011 | 1990 Chevrolet K1500
Hub making grinding noise tie rods need replacement
A grinding from the hub sounds like a bad wheel bearing.
Jun 01, 2010 | 2001 Buick Park Avenue
When turning hard right or left a noise occurs not sure if it is awheel bearing or 4-wheel drive u-joint
Raise wehicle and use long handle prybar and try to lift the wheel straight up. If it is play then you have bad bearings. Please Note that wheel bearings will make grinding noise igf they are bad on any speed above 25Mph no matter that you turning your steering whel or not. Grinding noise from turning your steerin wheel it is comming from sterring pump. Check your fluid.
Feb 19, 2010 | 2002 Ford F250 Super Duty SuperCab
It makes a grinding noise and only on the passenger side. just started making noise when turning
Check brakes, then check axle bearing. If brakes check out OK, then jack up so the wheel is off the ground, put car in neutral, now spin the wheel and put one hand on the coil spring, if you feel any roughness, the bearing is bad.
Nov 03, 2009 | 1992 Toyota Camry V6
Hear a grinding noise from the right front wheel when I make left turn (mostly). Noise has now progressed to anytime the wheel is in motion. Also hear squeeking sound (ball bearing possibly?). I've changed...
You should definitely pull the front wheel and check the bearings (they are roller bearings, not ball bearings). With the wheel off, you should be able to isolate where the noise is coming from, but I vote for the bearings. Check, replace and/or repack, and adjust properly. If you have noise, you should be able to feel the "play" in the bearings, or see the wear problem on the spindle and bearings. I hope this helps you.
Oct 30, 2009 | 2000 Nissan Maxima
I Think I have a front wheel bearing problem
Check wheel bering for play if there is no play , it doesn't mean that bearing is NOT bad its can still be dry and would be making that grinding sound you described Also check axle and see if boot is broken. That may be your problem also make sure that rotors are not gouged/scraped up and pads are good.Contact if you need more help and thanks for using FIX YA
May 05, 2009 | 2004 Kia Sedona
Fisher and Paykel DE06 Electric Dryer Logo
126 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Craig Butler
Craig Butler
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
