Question about HP OfficeJet 6110 All-In-One InkJet Printer
What cartridge do I need to order? - HP OfficeJet 6110 All-In-One InkJet Printer
You need a HP #56 for black and a HP #57 for colour.
Posted on Sep 07, 2010
Testimonial: "Thank you!"
What you mean by 'toner low' in cannon MF4320-4350 ??
Toner Low message appears on the printer display screen when the toner cartridge is exhausted and there is no more toner powder left in the cartridge. At this point, you need to replace the toner cartridge in order to print. It is recommended that you buy an original toner cartridge to replace it because original cartridge will give you better results
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 23, 2011 | Office Equipment & Supplies
I HAVE JUST REFILLED MY LEXMARK X2550 PRINTER COLOR CARTRIDGE NUMBER 35, BUT A MASSEGE ON MY PC SAYS: "Invalid Cartridge". How do l get it to be recognised so that l can use it?
hello
35 is color ink cartridge .. high yield,
A new color print cartridge needs to be installed.
If available, click the Continue button on your computer screen to print using the
black (or photo) print cartridge. (The Continue button is available only at the
beginning of a print job.)
Note: A variable amount of ink remains in the color print cartridge.
Follow these steps to replace the color print cartridge in your printer:
1 Cancel the print job if not already canceled.
2 Replace the color print cartridge with a new cartridge. For more information,
see "Removing a used print cartridge" on page 35 and "Installing print
cartridges" on page 35.
3 Print again.
To order supplies, click Order Ink on your computer screen. You can also see
"Ordering paper and other supplies" on page 40 in this guide.
Troubleshooting 54
manual = http://www.lexmark.com/publications/pdfs/2007/2500/v3708617_en.pdf
Installing print cartridges
1 If you are installing new print cartridges, remove the sticker and tape from the back and bottom of the cartridges.
1 2
Warning-Potential Damage: Do not touch the gold contact area on the back or the metal nozzles on the
Maintaining the printer
35
list of ink cartridge part numbers
http://www.lexmark.ca/lexmark/product/home/455/0,6970,204812589_653399443_1037657543_en,00.html?tabId=7
Dec 23, 2010 | Office Equipment & Supplies
WHILE TEST PRINT CYAN INK NOT SHOWING WHAT SHOULD I DO SIR
This issue will only occur if an ink cartridge(s) is or was installed inthe wrong position (slot) in the machine. When a cartridge is installed, the ink tube system is filled with the ink from the cartridges, to prepare the machine for printing. If the cartridge is inthe wrong position the tube will fill with the wrong color.
NOTE: If you just installed or replaced the ink cartridges and your printed documents are missing colors please refer to the solution - I just installed or replaced my ink cartridge and my printed documents aremissing colors. What can I do? Blank
To resolve this issue you will need to clean the print head.
NOTE: It may require 10 to 15 cleanings to clean the ink tubes and print head. During the cleaning process, the ink in the cartridge(s) will be consumed. Additional ink cartridges may be required to completethe cleaning process.
1. First verify the position of the ink cartridges:
a. Open the ink cartridge cover and check to make sure the ink cartridges are in the correct order.
b. Starting from the left side, the correct order is Black, Yellow, Cyan(blue), and Magenta (red).
- If the ink cartridges are installed in the correct order, close the ink cartridge cover and continue to STEP 2.
- If the ink cartridges are not in the correct order, remove the ink cartridges that are installed in the wrong position by pressing down on the release lever(s), located above the ink cartridge and remove the cartridge(s) from the machine.
Next, reinstall the ink cartridge(s) in the correct position in the machine by gently pushing the cartridge in until it clicks.
When all the cartridges are installed, close the ink cartridge cover.
2. After closing the ink cartridge cover, the LCD will prompt - Did youchange XXXX (XXXX = the color) This message will be displayed for ink cartridge that was removed. Press the - (Minus Key for No). This willkeep accurate data of how much ink is left in the cartridge.
1. Press the INK key.
2. Press OK to select Test Print.
3. Press OK to select Print Quality.
4. Press the COLOR START key.
5. Review the Check Sheet. The colors on the Check Sheet should be in a specific order: Black, yellow, Cyan (Blue) and Magenta (red).
a If the colors on the Check Sheet are in the correct order and are notmissing any dashes, press + (Plus Key for Yes) on the key pad and continue to STEP 7.
b If the colors on the Check Sheet are not in the correct order, are missing dashes or blank or a color other than Black, Yellow, Cyan or Magenta printed press - (Minus Key for No) on the key panel and continueto STEP 6.
6. The machine will need to perform cleanings to flush out the incorrectcolor or dried ink from the ink tubes and print head.
a. The LCD will ask you BLACK OK. If black is fully printed and is the correct color, press + (Plus Key for Yes). If it#s blank, missing dashes or is the incorrect color, press - (Minus Key for No).
b. The LCD will ask you COLOR OK. If any of the 3 colors (yellow, cyan (blue), and magenta (red) are fully printed and are the correct color, press + (Plus Key for Yes). If it#s blank, missing dashes or is the incorrect color, press - (Minus Key for No).
c. The LCD will say START CLEANING + for YES and - for NO. Press + for YES to start cleaning. The machine will go through a cleaning cycle that will take approximately one to two minutes.
d. After the cleaning is completed, the LCD will say PRESS START. Pressthe BLACK START key. This will print out the print quality check sheet again for you to check and see if your print quality issue has been resolved or not
NOTE: If you wait 1 minute after the cleaning cycle is completed, the display will return to date and time. You will need to go back to STEP 3 to print the Print Quality Check Sheet again.
e. If the ink color order is correct and all of the dashes are present, press + on the key pad to select YES and continue to STEP 7.
If the colors on the Check Sheet are not in the correct order, are missing dashes or blank or a color other than Black, Yellow, Cyan or Magenta printed press - key to select NO. Repeat the cleaning process byfollowing STEPS 6a through 6d. You may have to perform this procedure up to 15 times in order to clean the ink tubes and print head
NOTE: During the cleaning process, the ink in the cartridge(s) will be consumed. Additional ink cartridges may be required to complete the cleaning process.
7. Test by printing the document that had the reported problem (wrong color printing).
Dec 08, 2010 | Brother DCP 165C Compact Color Inkjet...
What lexmark ink cartridge is the same as Dell Series 7 ink?
The best way to get series 7 cartridge is to either order online or order with dell over the phone. 18006249896
Jul 15, 2009 | Dell 924 All-in-One InkJet Printer
Dell 5110 004-310 reset printer error
This may not solve your problem but it did mine when I got the "reseat cartridge" error. I had inadvertently ordered the cartridge for the 5100cn, which looks exactly the same as the 5110cn and actually fits if you order the generic version (the Dell 5100cn cartridge looks like the 5110cn but doesn't quite fit).
So, first make sure that you ordered the 5110cn cartridge. (And if you need two opened 5100cn cartridges, I've got them up on ebay :( !!!!)
Jan 23, 2009 | Dell 5110cn Laser Printer
I need to order a new color cartridge door latch. where do i find one?
Here is the part number you need.
Link below where you can order.
C4557-60046
Cartridge latch (Color) - Holds color ink cartridge in place
http://www.feedroller.com
Dec 14, 2008 | HP PSC 500 All-In-One Printer
I have a lexmark 2660series printer and cannot buy a set of ink cartridges anywhere for it as the 'order on line' prompt does not appear to have a web page
Thank you for clarifying the model.
The links that are shown in the post above are links directly to Lexmark to order cartridges from them.
If you want to order it direct from lexmark, just follow the links I provided previously, or call their order department and place the order over the telephone with a live person. that number is 1-800-539-6275 Monday thru Friday, 6am to 6pm PST
the cartridges you need are the 14 for black, and 15 for color.
there are other places you can get these cartridges other then directly from lexmark though.
For instance, these are stocked in store at most Target's. I am not sure if you have any Target stores in your area, but if you do, they should have them there. there product information is
Lexmark 15 Ink Cartridge - Color
ASIN: B0015MVV0U DPCI: 080-04-0538
Lexmark 14 Ink Cartridge - Black
ASIN: B0015MX7NY DPCI: 080-04-0537
Another alternative is to go to www.ebay.com and type lexmark 14 black in the search and you will see several auctions and/or ebay stores that sell this. Same for the Lexmark 15 color.
Good luck, and please take a moment to rate this solution.
Thank you,
Oct 11, 2008 | Lexmark Office Equipment & Supplies
Printer cartridge
Go to:
www.lexmark.com. There you can order the cartridge you need and you can also download to look at the guide on how to set up the printer under publications in support.
I suggest you take a look at the guide and see where the cartridge goes and then if the cartridge is not there, order what you need.
The guide is in pdf format so you need to have acrobat reader installed in order to read it. That is a free download at www.adobe.com/acrobat.
Aug 06, 2008 | Lexmark X2350 All-In-One InkJet Printer
HP OfficeJet 6110 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
