Question about Samsung HL56A650 56 in. TV
My tv has gone thru 2 lamps one replaced in nov 09,in may went bad,had a tech out to check t.v.said it was the lamp ordered another lamp from jand j international,it lasted 6 weeks been out since the middle of july,400 dollars later still no t.v.
    Problem Solver:
  • 17 Answers
Replace the ballast.
Posted on Sep 09, 2010
Changed 6 lamps y65 none work can they all be bad
Sounds like the circuit that is responsible for sparking and maintaining the voltage to the lamp has gone bad. It's called the Lamp Driver.
Don't waste any more money on lamps. Get a tech to have a look at either repairing or replacing the lamp driver.
Sep 13, 2014 | Toshiba Televison & Video
Lamp life
This lamp life is about right if the TV is getting constant use. Please check that the cooling fan is running at the correct speed and the vents are unobstructed.
Oct 06, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Tip
DLP TV shuts down
If you find your DLP TV is shutting down intermittedly, it may be just a simple lamp gone bad. Follow your user guide to remove the lamp, check for visible damage or parts that have burst inside the lamp bulb itself, if so, go online to order a new lamp and replace it. Just enter your model number and the word "lamp" into the google search, order it and when it arrives, replace it the same way you took out the old one. Make sure you order the lamp "with housing" which is a little more expensive, but much easier to replace. Good luck!
Best Regards,
Beach TV Repair
Treasure Coast, FL
info@beachtvrepair.com
http://www.beachtvrepair.com
on Jul 05, 2010 | Audio Players & Recorders
My 3.5 year old wd-57731 has gone thru 6 lamps since purchase. I vaccumm the rear of the tv every month and the last tech that came out changed a sensor. TV is still under warranty. Any suggestions on what...
Howdy;
It is your ballast that is causing your short life of your Lamp. The original Part Number for the 'PWB Power' is 934C228001.
I have had this problem at least 100 times and it will give your Lamp a life of about 2 years, 5,500 hours.
Good luck with your Warranty Company, Big Irish.
Dec 03, 2009 | Mitsubishi WD-57731 57" Projection HDTV
DLP 5063WX. Sound but no picture. Screen Black. Just replaced Ballast. Problem still there..Flashing green Timer/Lamp..Cycles a few times and turns itself off. Any suggestions?
Is the Lamp ok? Go to the rear of the set and turn on the set with your remote while looking at the vent slats. If you can see a bright light through the vent slats then your Lamp is working. If the lamp is on and you have sound and no pix, then the Digital bd is in what we call "Video Mute" and will have to be replaced. Also make sure that the Lamp Door is installed and the screws are tight.
Jul 14, 2009 | Samsung 50" Slim-Depth DLP HDTV
52HM95 Lamp Issue
The Tv will shut off and sho error if the ballast is bad. Replace the ballast and you should be fine.
Mar 22, 2009 | Toshiba 52HM95 52" HDTV Projection...
No picture and no sound after replace lamp for Mitsubishi WD-51525
did you use an original mitsbishi lamp. did it slide in easily? one of the most common problems with a lamp replaement is pushing the connector away from the lamp if it doesn't slide in easily. unplug the set, take out the lamp and look with a flashlight to see if the connector is in place. if so put the old lamp in and see if it works. if it does then your new one is bad. if it doesn't then email me
ima_rm2000@yahoo.com with your number and we can talk more.
ken
Nov 10, 2008 | Mitsubishi WD-52525 52" Rear Projection...
TV WONT TURN ON. BLUE LIGHT GOES ON THEN THE TWO RED LIGHTS BLINK IT HAD BEEN WORKING THEN ONE DAY IT JUST WONT TURN ON.
I'm going throught the exact same thing right now. After the lights quit blinking, and the blue light goes off, does the red lamp light stay on. This usually means your lamp has gone bad ($200.00 plus). But when I ordered the lamp, it did the same thing. Had to have the certified hitachi repair man come out for the and told me it had to be a bad lamp, so I ordered a 2nd one with the same result. He came out again and had to take the TV away, later telling me the ballast must have blown when the original lamp went bad. Another $200.00 part. I haven't fought this one with Hitachi yet but am going to try. The ballast shouldn'e go just because the lamp goes out. The set is only 21/2 years old and I've already had to spend about $700.00 on the light enging replacement and now this lamp and ballast expense. Love the TV but would expect a lot less problems from a $2500.00 top model Hitachi. I'm going to see if they feel the same way, hopefully not but I'm not real optimistic they will care. Hope this helps.
Dec 14, 2007 | Hitachi 50V500 50 in. HD-Ready LCD...
Lamps
color wheel brakes then causes this same affects check your wheel
Nov 05, 2007 | Samsung HLP4663W 46" Rear Projection HDTV
Sony Wega KDF-55WF655 blue ghost problem after replacing lamp
It is a defective light engine and it must be replaced. I hope you have a warranty because Sony will not help you.
Apr 06, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
Open Questions:
Samsung HL56A650 56 in. TV Logo
133 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
