Hello having a problem with Maytag MLG2000AWW during a wash water was leaking from all around, after the cycle finishedI opend the door and a flood of water came out. Any idea what could be the cause? is there a drain valve or somehting, Please help.
    Top Expert:
  • Washing Mach... Master
  • 78,919 Answers
You most likely have a blocked drain pump filter, they get full of all kinds of stuff, money fiber and so on, go to the web link below to see how to clean the drain.
http://www.ehow.com/how_6513885_clean-neptune-front-load-washer.html
Posted on Sep 07, 2010
Leaking water from bottom door over two bolts
Change the door gasket or realign the door.
Jan 12, 2014 | Maytag MHWE201YW
Water flooding out of bottom of door during wash cycle. Door seal is good and nothing else is leaking. Thanks,
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
Sep 07, 2010 | Frigidaire FDBB1940D Dishwasher
I have a Maytag Neptune front loading washer, After a complete wash cycle I hear water sloshing in the machine when I open the door and turn the durm. Is water supposed to be in the machine after the cycle...
Yes. The tan/gray colored inner ring attatched to the inner wash tub actually has a calcium chloride solution in it to aid in balancing the machine out during spin. Clothes go to one side, liquid to the other. It's all good. It is sealed so it cannot leak out or create odors.
Hope this answers your question!
Jun 23, 2010 | Maytag Neptune MAH5500B Front Load Washer
Hello - we have a top loading Maytag Performa washing machine that leaks water during the spin cycle when my wife is washing heavy items that she has placed on center spindal to avoid an unbalanced load....
Maytag Epic is leaking water from the bottom about 8 or 9 inches from the front door back on the right side. Is there and thing i can do. It only about 2 years old or less.
Oct 13, 2009 | Maytag Performa PAV2200
Maytag neptune MLG2000AWW does not turn off at end of spin cycle
d sounds as if your having a timer issue here. not recognizing the end of cycle and entering a new one ( bad timer).. as far as time of unlocking this is normal, theres a wax motor holding the door shut for i believe 3 min's.. and the water sloshing sounds is also normal they use a "water filled" balance ring around the perimeter of tub to help with the overall balance of machine
Mar 20, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune mlg2000aww door will not lock or spin
Removing the top cover of the dryer, you will find, in the front right, the machine electronic control board with a burned resistor. This resistor burns up when the washer lock motor fails. The lock motor and control board will need replacing. Parts cost will be around $220.00.
Feb 05, 2009 | Maytag Neptune MLG2000A Front Load Stacked...
Maytag Neptune Leaking From the Door
possibly door lock not latching could be a bad wax mtr (within door lock asm) or control board
Dec 12, 2008 | Maytag Neptune MAH5500B Front Load Washer
Water Leak at vent area in door...
On this model the vent is open and shut by a wax motor. The vent should be closed tight during the entire wash cycle and the first 6 minutes of the drying cycle. Check the operation, make sure there is not a bunch of gunk restricting it. If you are handy with a meter check the resistance of the motor. It should read approx. 2100ohms. Another reason for leaking at the base is oversudzing. Also check the upper spray arm for cracks or splits shooting water into the vent area. Catriver...post back.
Oct 23, 2006 | Maytag 24 in. MDB4000 Built-in Dishwasher
Washing Machines Logo
41 people viewed this question
Top Washing Machines Experts
