Question about Disney D7500PDD Portable DVD Player
Split screen picture
I make connection from DVD player to the TV Screen and the picture and sound come on clearly, but the problem is the picture is double, split in the middle.
Thank you
    President:
  • 1,284 Answers
Your DVD player is set to the 480p (progressive) scan mode. Place it back to the 480i (interlaced) mode and it should work normal.
Posted on Jun 10, 2008
DVD player is black and white and screen is split
Make sure the player is compatible with your TV broadcast standards. A Pal player will show b&w pictures when connected to a NTSC tv and vice versa
Feb 26, 2015 | Samsung DVD-V3500 DVD Player/VCR
My tv is coming up with a split screen when connecting DVD player
If it is a "3-D" DVD player, and your TV cannot handle "3-D" output, you get a "split-screen" (whole picture on left 50% of the screen, whole picture on right 50% of the screen).
Jan 01, 2014 | Sanyo Televison & Video
No sound on lg tv when connect dvd player through hdmi
I have the same problem. Good picture with no sound at all. I have a LG DVX583KH and LG TV LM7200. I connected the DVD player to TV via HDMI cable, I have a clear picture but no sound. I try to hook up the DVD to other TV and it works both sound and picture. Please help
Apr 13, 2013 | LG DVX583KH Player
Bought a new flat screen tv. my dvd player gives
Yes, this would be a connection problem or it may be a bad board in the tv. I would double check the connections and if they are good I would exchange the tv.
Jan 03, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Split screen
just open the menu and go to tv settings then adjust it to interlace mode.or use your component input if your tv has an ability to receive a YPBPR input much clear than an ordinary video.
Sep 24, 2009 | Televison & Video
Dvd player split screen
I had the same problem. It turned out to be my cable that went from the dvd player to the TV. I replaced with new cable & everything worked fine again. Hope this helps & please remember to rate my answer. Thanks.
Feb 06, 2009 | Panasonic DMR-ES40V DVD-Video Recorder
Split screen on DVD player
This sounds like a progressive scan issue (unit in P.Scan Mode) here is a C&P from the manual
Set "Alt Video Out"
Highlight "Alt Video Out", then press the RIGHT button to select
one of the following options:
• S-Video - Select this if you are using the S-Video OUT jack on
the rear panel to connect to a TV.
• Component - Select this if you are using the COMPONENT
VIDEO OUT jacks on the rear panel to connect to a
Progressive(480p) or Interlaced (480i) TV.
• See your TV owner's manual to determine what type of TV you
have.
- Interlace : Interlaced Scan mode will work.
- Progressive : Progressive Scan mode will work, and Video
and S-Video will not work.
• Press the Progressive button on the front panel if you have a
Progressive scan TV only. Otherwise, the picture will be
disturbed.
Feb 04, 2009 | Samsung DVD-V3650 DVD Player/VCR
Panasonic TX32LMD70: split and green picture from DVD
Cut feed lead to pin 16 (in the scart not the equipmend!)
Does not matter which end. It just stops the TV from switching to RGB- The DVD is sending non standard RGB - PanamanNE
Jul 04, 2008 | Televison & Video
Double image playing DVD's
check your picture in picture, sounds like your dvd imput is set for split screen, dvd on both sides
Apr 20, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Split screen from DVD player, cable is fine no problem
It is not clear where you say input is from cable, do you mean the Scart input to your Sony TV? Do not use Progressive scan(p), as this is not interlaced. The normal TV requires an interlaced(i) picture of 50 half frames per second giving 25 complete pictures per second to reduce flicker. Some TVs and projectors and all monitors accept Progressive scan.
Oct 15, 2006 | Sony KV-32S25 32" TV
Disney D7500PDD Portable DVD Player Logo
206 people viewed this question
Top Disney Televison & Video Experts
Jaime Hernandez
Demonic-2011
Demonic-2011
Are you a Disney Televison and Video Expert? Answer questions, earn points and help others
