Question about Northstar Gas Powered Wet Steam & Hot Water Pressure Washer 3000 PSI
CANNOT GET BURNER TO IGNITE, NORTH STAR 157310D
My North Star industrial pressure washer trips breaker when burner ignites
Is it all electric? If so, that is maximum load (pump, blower and ignition spark) . Is the breaker on the machine or in your house/building? If yu have a 20 amp machine plugged into a 15 amp circuit it might run cold but trip out when you add the spark and burner blower. Also check if there are other items using the same circuit. If your extension cord is long and light guage wire ( smaller wires have larger numbers, 10 guage wire is heavy duty and 16 guage extension cord is light duty) it could be the cause of the breaker tripping.
Jul 04, 2014 | Garden
Hard to light burners
I have the same question, does anyone know why the igniter takes such a long time to light the burners? At least 6 to 7 clicks. The sparks from the igniter looks blue and has a good spark. This is true with all burners. I have cleaned the stove and around the igniters, Mine is a sealed burner so I haven't opened it up.
Aug 10, 2013 | Five Star Kitchen Ranges
How does a compass always point to due north?
"Due North," by definition, is the direction towards the earth's north pole; or, visually at night, towards Polaris, the north star. Therefore, compasses generally do NOT point towards due North but, rather, point towards "magnetic north," as the other responder described, which is a variably located at some distance from True North, depending upon where the north-locating compass is situated on our planet. In most circumstances magnetic North is close enough so that people are willing to accept it as North in general terms. However, depending on your location, and upon seasonal changes caused by Earth's wobbling rotation (called precession) true North can be many degrees off from magnetic (from your compass's) North. In those cases true North must be determined using declination charts, which will tell you how many degrees to add or subtract on you compass in order to determine true North by the Magnetic North your compass is pointing to. For example, if magnetic North is 10 degrees west of true North at your compass's location (that is, your compass is actually pointing 10 degrees to the "left" of North), then you would correct by considering the +10-degree bearing point on your compass dial as True North--and, likewise, add 10 degrees to any bearing line you happen to determine using your compass. You have one other way of finding True North, which is celestially, by sighting towards the Pole star, aka Polaris, aka the North Star...that is, providing that the sky is UNcloudy and unsunny enough for the star to be visible. Of course, that only works for those located in the morthern hemisphere. Those south of the equator have a "south pole" star but it is not as accurate as Polaris in the northern hemisphere.
Jul 09, 2012 | Camping, Backpacking & Hiking
The igniters on my Five Star TPN535-BGSW Dual Fuel Kitchen Range don't stop after the burner has ignited. This is a long time intermittent problem that effects the most used burners but not the least used....
Most likely one of these two causes:
1. Corrosion or build up on one of the metal surfaces that provide a path to chassis ground from the ignitor through the burner and frame back to the chassis ground connection to the spark module.
2. An intermittent spark ignitor wire or corroded connection to the ignitors.
There is a 3rd possibility if the range has been worked on ...
Turn on all the burners, if the sparking stops then the problem is that two or more of the ignitor wires have been swapped between burners.
Jun 27, 2010 | Five Star TPN535-BGSW Dual Fuel (Electric...
I have a M157305J North Star pressure washer. The
The thermostat in the control is sticking... by turning it a bit you get it to release and kick back on...
You need to replace the control...
Heatman101
Mar 03, 2010 | Garden
Purchased range used. Burner Head assembly with
Yes, you need a burner cap to sit on top of the burner assembly and create the normal star shape flame.
Feb 09, 2010 | Kitchen Ranges
Access to odd numbered spark plugs on North-Star V8
To gain access you have to remove the ignition coil pack. There are only 4 10mm bolts holding it on. Also remove the cross over to have more room.
Oct 31, 2009 | 1998 Cadillac DeVille
When turning on a front burner back burners make a clicking noise and spark.
MY STOVE DOES THE SAME THING THE IGNITERS ARE ALL HOOKED TOGEATHER WHEN YOU TURN ON ANY BURNER ALL THE BURNERS SHOULD SPARK
Sep 28, 2009 | Five Star Professional TPN037 (Gas)...
Northstar Gas Powered Wet Steam & Hot Water Pressure Washer 3000 PSI Logo
116 people viewed this question
Top Northstar Garden Experts
John Trevino
Roland W VanLue
Roland W VanLue
Are you a Northstar Garden Expert? Answer questions, earn points and help others
