Question about Dishwashers
Model KUDS01FLSS When cycle is finished the dishes are still wet with condensation. Condensation is still there on door and dishes if left overnight. Appreciate any advice or help Thank you Dennis nderson
  • Dishwashers Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Posted on Sep 10, 2010
Our Bosch dishwasher always has condensation after completing the cycle. Is there a reason for this?
I have noticed the same with our bosch dishwasher. Once the unit finishes washing, it sits there silently for about 1/2 hour and then exhausts the hot/moist air through the drain pump and illuminates the "clean" light. With the tub still hot, I open the door and prop it open a few inches with the top rack for a few hours. Since the tub is still very hot but open to the much cooler air, a lot of that condensation will leave the clean dishes. A few hours or even overnight should do the trick! It isn't a perfect system but beats having that coil heater in the bottom to warp all of your plasticware.
Aug 13, 2017 | Bosch Dishwashers
Should the inside of the elite dishwasher still be wet at the end of the cycle?
Martha,
If you are talking about having a small amount of water down in the bottom of your dishwasher, that is normal. There is a sump down there that needs to have water in it. If you are talking about having water on the walls, that is probably just condensation from the cycle when you run the heater. Try cracking the door after the cycle is done to let the excess steam out of the dishwasher and that may eliminate the water on the walls. Hope this helps!
Apr 03, 2015 | Kenmore Dishwashers
Ld 14aw3
Most dishes in any dishwasher are still wet when cycle is finished. The heat built up in the dishes during the washing cycle is what causes the water to evaporate when the machine stops.
If you want to accelerate the evaporation, simply open the door very slightly so that as the hot air escapes it causes the dishes to dry quicker.
Aug 04, 2014 | LG Dishwashers
Hi - i have a Turbo dishwasher (made in Italy). It has a foul smell when you open the door, i ran an dishwasher cleaner through it on an emply cycle last week, was good after that, now stinks again. also...
Your heater system has stopped functioning.
If you have a heated dry setting use it.
If it does not work you will have to repair the heat system.
Mar 26, 2011 | Dishwashers
My new Kenmore Elite panel ready dishwasher leaves wet
You need only enough space so the door does not rub when opened. If the unit is too far back under the cabinet the countertop (if wood) can be damaged by the exhausting moisture. The dry feature on the newer models is just as you describe. The moisture from the hotter dishes evaporates and is condensed on the cooler walls and door of the wash tub. Dry dishes wet tub is normal.
Eric
Jan 04, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Does not seem like the dishwasher is drying like it used to. After it has gone through its entire cycle the is steam condensation on all the dishes and the inner door. Previously, at the end of cycle...
Have you run out of Rinse Aid ?
This has a large effect on drying as well as how clean the dishes come out. Rinse aid [breaks up] the water dispersion, so at the end of the final rinse, the water just falls off the dishes, takes the sediment with it. So with the heat of the final rinse, & less water left on the dishes, they dry better.
Dec 12, 2009 | Kenmore Dishwashers
Condensation in dishwasher
Make sure you aren't selecting the eco setting to conserve power. Running a dishwasher in that mode disables the heating element that dries the dishes at the end of a cycle. Here a few ideas you can try,... with an empty dishwasher.. start a cycle and make sure you do not use that ECO mode if it has that feature.. then stop the dishwasher when it near the end of the cycle and open the door ./.. check to see if the water has been drained and that the heater element is on and hot. If there is a high volume of water in the bottom of the dishwasher, make sure the darin filter screen is clean and not restricting water flow... If that is clean.. and you have a lot of water in the bottom pan, you could have a problem with the pump, a hose in line with the pump or your house drain system is restrictive.. Good luck... and Hope this helps you..
Nov 29, 2009 | Kenmore Dishwashers
Water dripping from underneath
The water is most likely coming from the condensation that's drained out of the refrigerator during the automatic defrost cycle.
Be sure the bottom fan is running and clean out the condensation tray. Warm air pulled across the condenser coils is supposed to evaporate the condensate water. If the fan is not running when the refrigerator cycles on, replace it. This would also result in the refrigerator running excessively without cycling off.
While you're working under the unit, be sure to clean off the coils too.
Good luck. Hope this was helpful.
Nov 20, 2009 | Computers & Internet
Door is wet with condensation at the end of the cycle although dishes are dry
this problem should be under dishwashers not washing machines! however this is caused by lack of rinse agent this aids the drying process and removes moisture from crockery check levels if ok try using detergents with salt and rinse aid combined may be dispenser is not working properly.
Sep 26, 2009 | Bosch Classixx WFL 2066 Front Load Washer
LG LDF6810 Drying Cycle?
This is normal and the amount of water can depend on how soon after the cycle has finished as to how much condensation is on the walls.
Jul 26, 2007 | LG 24 in. LDF 7811 Stainless Steel...
Dishwashers Logo
196 people viewed this question
Top Dishwashers Experts
Owen Barnes
