Question about NetGear DG834G Router
I can't connect to my router. tried to access http://192.168.0.1 bot page won't open
    Sergeant:
  • 172 Answers
Plug in directly your netgear to your computer then turn on the router
open run > type CMD
in the CMD command line type "ipconfig"
check the default gateway that is the IP address of your router if still doesnt work
you can reset the router by pressing the reset button on the back but make sure that Ethernet cables are unplug. just the power cable connected to it and it must be on.
press and hold the reset button and wait until it flash and release the reset button. the IP will be back to the default 192.168.0.1
hope this help
Posted on Sep 07, 2010
    Problem Solver:
  • 10 Answers
If this is a brand new router and you are trying to connect to it for the first time then 192.168.0.1 should work, as long as you have the correct kind of cable plugged in and are following the directions.
The manual for this router is at: http://kbserver.netgear.com/pdf/dg834g_dg834gb_ref_manual_03Jun05.pdf
If you are not concerned about losing your routers settings and are setting it up for the first time then you can do a "hard reset" to make sure that the address of the router has not been changed.
First off, let's make sure you are plugged into the router correctly.
The cable from your computer to the router should be plugged in to one of the LAN ports, NOT the ADSL Internet port. If you have it plugged in correctly and you are unable to access it still then I would try to RESET the router to default settings.
You can do a reset by using a paper clip or similar object to press the RESET button, which is in the small hole as shown in the diagram.
1. Press and hold the Default Reset button until the Test LED turns on (about 10 seconds). 2. Release the Default Reset button and wait for the router to reboot.
YOU MUST HOLD THE RESET BUTTON UNTIL THE TEST LED TURNS ON!
This will rest the router to the factory default and allow you to access it at the address 192.168.0.1.
NOTE: After you reset the administration password is the word "password"
Please ask if you need further assistance. If you still cannot access the router at 192.168.0.1 after a reset then you should check your cabling and/or ask for more help.
2 Suggested Answers
eastpole
  • 22 Answers
SOURCE: set up router/modem as instructed
Problem can't be solved as described, a fixer would need more details.
What kind of modem/router is it?
What instructions are you working from so far (you say, "as instructed" so I take it you're looking at a Quick Start Guide of some sort?)
How are you connected to it?
What http address are you going to (E.g. some routers use 192.168.1.1, others 192.168.1.254 or various alternatives)
What happens when you enter that address on a browser?
Have you set your computer's address to a nearby address so it can talk to the route?
If I had one guess with not enough information, I'd say you need to set your PC to an address one different from the target you're going to.
( http://compnetworking.about.com/od/workingwithipaddresses/g/192-168-1-254-d.htm )
Posted on Jan 10, 2011
When I try to access my cisco e1000 router on firefox or google it keeps saying that it is busy and will not connect
Are you trying to access the setup page of the router?
Did you install the Cisco connect software on your main computer?
If you have cisco connect software installed then open Cisco connect.
Go to Router settings. Click on Advanced settings. It will open the setup page of your router.
If the cisco connect is not installed then try to power cycle the router. Unplug the power to the router, wait for 30 seconds. Plug in the power cable. Wait for 30 seconds.
Now try to access the setup page.
If that is also not working then I will suggest you to reset the router and reconfigure it manually.
Watch video.
How to reset Linksys router.
Watch Video:
Linksys router setup
Feb 24, 2012 | Cisco Linksys E1000 WirelessN Broadband...
My router seems to be destroyed. i tried to setup access point but right after that the light went red.. but i connect wirelessly. and my fone and my sisters' laptop can't connect to the internet...
You can also configure it with below method.
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. Then click on WAN settings set it as your internet service provider settings enable DHCP Then click on wireless and enable it. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
May 16, 2011 | Belkin Surf N300 Wireless N Router
My router wont work when it is connected to the modem. the message that on there says limited access
If you already verified that your modem works if computer connected directly to it, try powering down router and modem. Start modem first and wait at least 2 minutes before starting router.
if this doesn't help you will need to verify that your wired connection to router works first before you can attempt to use wireless.
With your computer connected to the router try to open router setup page. Based on router type you should be able to access it from browser using: http://192.168.1.1 or http://192.168.0.1 you will need to login using default admin/admin account or according to router user manual. Configuration page will allow you to verify if you have Internet connection and configure other settings including wireless connection.
Mar 15, 2011 | Computers & Internet
I can't access my routers administration page. It tells me to type in http://192.168.0.1 and all I get is a bunch of search results instead of the administration page
disconnect your modem from router, or turn off your modem from router...
Now try to open...
because the router admin page will be built inside the router itself... so you never require internet connection to be ON for opening the router admin page...
Aug 02, 2010 | Computers & Internet
WHERE DO I FIND A WPA SECURITY PASSPHRASE FOR MY LINKSYS
Use an Ethernet cable to connect the network-port on your computer to one of the LAN ports on the router.
Start Internet Explorer.
Access: http://192.168.0.1 or
Access: http://192.168.1.1 or
Access: http://192.168.2.1
to access the web-server software "inside" the router.
Login, and run the "Wireless Network Setup Wizard",
to choose WPA, and to set a password or a passphrase.
Aug 01, 2010 | Linksys Wireless-G Broadband Router
I have problem setting up my wireless network and redirecting my wireless client to my local webpages before they can access to internet.   see this diagram below :...
you need to replace your modem with a router that is capable of running Network Address Translation. You are trying to route private IP's (192,168.x.x) over the public IP (internet) network.
Jan 31, 2010 | Microsoft Windows 2000 Professional for PC
When I type 192.168.0.1 into a browser I am taken to the www not the router. Default gateway has not been changed. I am attempting to access a D-Link DIR-655 Wireless Router.
this address is correct for ur router now u go to network connection u change ur ip address to ip automatic i think u can access to page configure dlink, if have problem email to me billy_nguyen57@yahoo.com
Jan 15, 2010 | D-Link DIR-655 Wireless Router
Access routers configuration and wireless filter to edit MAC List to add MAC adress
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
For belkin router http://192.168.15.1
or
http://192.168.2.1
Then check wireless or wi fi settings you find there MAC filtering or mac security edit that list then save and restart router.
Dec 10, 2009 | Computers & Internet
NetGear DG834G Router Logo
55 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
