Question about HP LaserJet 2820 Printer
I have an hp colour laserjet 2820 printer and it tells me there is a jam in the paper path. i have taken out every carteridge that I possibly can and opened every door that can possibly open and there is NO paper stuck in that printer. No wrinkled, or crinkled or smushed up paper whatsoever. What else could be the problem and what can I do?
  • 1,218 Answers
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
http://www.fixya.com/support/t5993740-hp_4050tn
Posted on Oct 14, 2010
    Sniper:
  • 56 Answers
This error its tricky. You need to take out the fuser (in the back there are two blue locks) and inside the printer in the center of the paper path you will find a black plastick stick. Its a sensor for the paper path that did not went back to the regular position. Its dificult to explain, but if you can find it the issue will be solved 100% sure
Posted on Sep 07, 2010
Hp LaserJet Pro 400 paper jam in cartridge area
Clean all of the rubber feeders with alcohol/rubber restorer in the paper path of printer.
Sep 14, 2016 | HP Laserjet Pro 400 Mfp M425dn...
Hp Color Laserjet 1600 says Jam in tray 2 bt there is not paper jams
Open the paper feed area and the printer, examine the paper feed path and make sure there isn't a page or piece of paper jammed in the path somewhere.
Aug 21, 2014 | HP Color LaserJet 1600
How to clear error code 13.20.00 on CP3525dn
Error 13.20 indicating paper jammed.> check any paper jammed inside? remove it...observe the diagram of paper path & sensors where possibilities for paper jamming..
Oct 24, 2011 | HP CP3525DN Color LaserJet Printer
Jam in bin
this is a common fault. look where the paper was jammed, you may need a torch. There is a black or white sensor there that has been dislodged. Once clipped back into place it will then report to the printer that the paper path is clear and no longer a jam.
Oct 05, 2009 | HP Color LaserJet 2600n Printer
Had a jam on my color laserjet 2600n; cleared the jam but the printer continues to say the same message and won't clear.
you must clear the entire paper path. if you have done this than you could possibly have a bad paper switch in the paper path
Aug 14, 2009 | HP Color LaserJet 2600n Printer
HP laserjet 4650 with 'phantom' paper jam
hi , I had similar problem,the printer memory is locked on that last transaction feed,
either. check all copy transactions are deleted.you may not reolise you have 3 or 4 still programmed for shedule.
un-install the printer from your pc
the re-install shuld clear it.
set - printer to default mode
you may find your printer works fine on a friends pc, try all or either of above good luck colin leeds
Jul 16, 2009 | HP Color LaserJet 4650DTN Printer
My hp laserjet 1150 series stops printing after a paper jam
you probably have a piece of paper inside printer or you have damage a paper sensor path while removing jammed paper.
Jun 22, 2009 | HP LaserJet 1150 Printer
Paper jammed and now will not turn on
Pull out the laser cart and see if you can locate a sheet from that end.
May 31, 2009 | HP LaserJet 2840 Printer
I have an HP Laserjet 2820 which had a paper jam.  I cleared it and have reset it and it still says there's a jam.  Any advice?
Have you looked in the rear of the printer at the FUSER unit? Flip the blue levers and the fuser will come out.
Jan 25, 2009 | HP LaserJet 2820 Printer
Paper jam
try this....
try this, its probably a small part of jammed paper or then theres a problem with the pickup, try cleaning it.
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jan 19, 2009 | HP LaserJet 2820 Printer
HP LaserJet 2820 Printer Logo
101 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
