Question about Sanyo STW1523H2 Thru-Wall/Window Air Conditioner
I have a sanyo stw1523h2 unit. i have it set on low cool. it cools fine but every now and then it will start blowing out very hot heat. when it does i will cut it off and then cut it back on and it will cool fine. what would cause it problem? thanks
4 Suggested Answers
  • 334 Answers
SOURCE: Sanyo split high pressure side tube icing
ok, on these units, if by high side line you mean the small tube going from outside to inside, that tube is actually on the low side, the metering device is in the outdoor unit. If you shut the unit down, let everything thaw then restart and find that small tube is freezing up right at the outdoor unit right away, my guess is its low on charge. I see that you put some in, make sure it is the right knid of refrigerant. they do not hold alot. Where is your suction pressure running. If you put 2 to 3 pounds with no change, you may have overcharged but that is telling you that there is a restriction in the line inside the outdoor unit, probably the filter if it has one, or the metering device itself. Let me know what you find.
Posted on Jun 18, 2009
  • 3074 Answers
SOURCE: I have RCS-2HS4E sanyo air
the icons are;
snowflake = cool
raindrop = dehumidification
fan-blade = fan
sun = heat
I am assuming that you have it on the snowflake,hope this helps Tim
Posted on Apr 27, 2011
  • 125 Answers
SOURCE: Hello We just installed a Sanyo KHS1271 mini-split
The condensate drain line was not properly installed. Make them pull the wall unit and correct the problem.
Be persistant until you are satisfied they have the problem corrected. Do not pay any additional money. If they do not correct the problem then report them online to the state board of heating and air. Fill out their requested complaint form and follow thru with a second complaint if you do not get total satisfaction from the contractor that installed the unit.
Hope this helps.
Posted on Sep 23, 2011
Why does my sanyo model KHS2472 has a red light blinking in heat mode and a green in cooling mode, does not work in either mode makes a gurgling sound when it tries to run?
The red light indicates it's either heating or in defrost mode
Check the outdoor unit if the compressor is running - the large pipe on the outdoor unit should be hot on heating or cool to touch on cooling
When in heating mode - the indoor fan will not start until the indoor coil is warm enough
If the reversing valve that changes from heating to cooling is faulty then you may encounter the same symptoms too
Probably need a Refrig Tech to have a look at it?
Good luck
Jan 07, 2016 | Sanyo 24KS72 Split System Air Conditioner
Why is AC not cooling
It probably is clogged with dust and lint. Vacuum out after it has had a long while to dry out. Clean evaporator with fine bristled brush and wash fiter.
Jun 17, 2014 | Sanyo STW1523H2 Thru-Wall/Window Air...
Why is unit not cooling?
Most likely the induct grill is clogged pull the front panel off the grill should be clean
Armstrong Ultra SX 80 Central Unit won't kick off heat setting
From what you describe it sounds like it might be a relay problem.
It needs to be diagnosed properly first.
Apr 21, 2017 | Heating & Cooling
My coleman central electric furnace only blows cool air
The AC unit outdoors must be running and rejecting heat by its air flowing through it the 2 copper lines are the refrigerant lines, the fatter one should be "beer can cold" if not its low on refrigerant or not running.
Jan 01, 2013 | Coleman Home Electric Furnace Eb15b/Eb15d
Hello, I have a sanyo ac model # xs3622, c3622 and was wondering if there is a heat setting. I live in a warm climate and have never needed the heat. The remote control has a heat setting but when I...
Your a/c model is only cool, but remote may be heat and cool which normally supplied by all manufacturers. Don't worry. In your remote heat mode will not respond by unit. Helpful advise?
Jan 02, 2011 | Sanyo Heating & Cooling
Why would cool air be blowing out of my central ac unit condensor that sits outside? The other unit I have next to it blows out warm air and responds well to thermostat changes. The unit blowing cool air...
It probably has a low refrigerant charge. The air coming out of the outside unit should be warmer than the outdoor temperature when in the cooling mode and if it's a heat pump it should be colder than the outdoor temperature in the the heating mode. Check the big line going to the unit, it should be somewhere around the 40 F range and the small line should be hot.
May 23, 2010 | Goodman CKL24AR24 Air Conditioner
Uotside unit blowing cool air but hot on the inside
It sounds like you have a unit called a heat pump. When a heat pump unit is in cooling mode the outside unit blows hot air and the inside unit blows cold air. If the outside unit is blowing cold then the indoor unit is most likely blowing room temperature or warm air. It sounds like the thermostat could be controlling incorrectly or you could have a failed reversing valve which is the device that switches the unit from heating to cooling mode.
May 31, 2009 | Ruud UBHC Air Conditioner
My air conditioning unit is not blowing as cold as it did, nor is it blowing as hot as it did in the heating mode
90 percent of the time the freon charge is low and lack of freon lessens the amount of compressed heat that can be created and also the amount of heat that can be extracted. hence less cooling and less heating. however the exact same thing can occur when a change over valve gets stuck partially between heat and cool . it then mixes the hot and cold together and you get poor cooling and poor heating. you check it with a gage. fed law requires that you have an epa certification to apply a gage. low pressures in heat and cool on both high and low pressure gages are a sign of low charge. if low pressure and high pressure are close to the same on both gages then a good chance valve is stuck half way between. you can also sometimes check by feel . at the change over valve two lines should be virtually to hot to touch and two should be cold to the touch. one is heating flow and other is cooling flow. if the valve is stuck then temps will be within a few degrees of the same on all. low charge and the hot lines won't be hot hardly .and the cold line s barely cool. look for white frost forming in the heat mode outside at the condensor tubing shortly after you turn on the heat. thats a sign of low charge. good luck.
Nov 04, 2008 | Heating & Cooling
Sanyo STW1523H2 Thru-Wall/Window Air Conditioner Logo
52 people viewed this question
Top Sanyo Heating & Cooling Experts
Dennis Boxerman
Tim Whalen
Chuck
Are you a Sanyo Heating and Cooling Expert? Answer questions, earn points and help others
