Question about KitchenAid Dryers
I took apart the dyer and now am not sure how the belt goes back on. Where could I go to look for a diagram or picture?
  • KitchenAid Master
  • 43,501 Answers
Look under my Heatman101 profile and go back 7-9 pages in my tips and I have a tip that shows you...
heatman101
Posted on Sep 12, 2010
Belt come off! Need access
depending on the way the dryer is built you may need to take the dyer's top panel off then the front panel of the dryer to get to the internals while laying the dryer on its back to make it more easy to put the dryer back together when done if the belt however has snapped you can actually buy belts for the dryer you own er....one more thing make sure its unplugged before doing any of this but while its apart take your time to clean the dryer out with compressed air this will prolong the life of the dryer you own as well all dyers are easy to take apart and put back together as everything just snaps into place or screws back into place (PS: i worked on a LG TROMM dryer and it was easy as pie to put back together after cleaning and diagnosing it)
Feb 22, 2017 | Dryers
I took the dryer apart and lubercated the belt and now I cant put the belt back on. How do I do this?
Hi buttcrackplu...
The belt will go around the drum,around the motor and idler pulleys....
Go to this webpage to see how the belt is routed.
Free Answer.,..Please rate me
http://www.applianceaid.com/images/belt-config.JPG
Apr 18, 2011 | Maytag Neptune MDE4000 Electric Dryer
Machine turns on but doesnt spin and dry clothes, what can be the problem
my dyer has a belt that broke it goes all the way around the drum and goes around the motor than to a tension spring if you take apart from back access panel unplug before attempting to fix look and see if the belt broke or came off tension pulley
Jan 27, 2010 | LG DLG5988 Gas Dryer
Wiper motor output arm
This my help you it has picture and info for removal and replacement.
http://www.lincolnsonline.com/tech/00177.html
Dec 08, 2008 | 1986 Lincoln Town Car
Don't know if this is right model
Okay...took me a while to get a good cross reference on this one. Drop the last four characters of your model number and place a "110." in front of the remaining numbers. That way the number reads 110.86921100. The "110" identifies the manufacturer. Your dryer is made by Whirlpool. If you go to searspartsdirect.com and type in the model number I provided, there are a series of drawings on the next page showing an exploded view of the layout of your dyer. Does this look familiar to you? Under the "Cabinet" heading you will find the dryer belt listed as item number 56 (part number 341241). For a diagram of how the belt goes on, go to repairclinic.com and you will find a dryer belt diagram link listed under the "Repair Help" section. Locate the Whirlpool diagrams and you will use drawing "K". I apologize if this sounds like absolute madness. If you get confused, please post back and let me know. I hope this answers your questions.
Jul 23, 2008 | Kenmore 62872 Electric Dryer
Picture of dryer Dryer Belt
Go to repairclinic.com. Look under the "Repair Help" section. At the bottom of the menu options on the left-hand side of the page is a section listed as "Dryer Belt Diagrams". There's a whole list of diagrams based on your dryer manufacturer. Hope this guides you in the right direction.
Apr 09, 2008 | Dryers
How to open the dryer and replace the belt
all dryers open from the top so open the dryer door and look inside the top edge you will see two screws . remove the screws and lift the top panel . the front panel has two screws on the top one on the left and one on the right remove them both and lift up the front panel to remove it. the only way you can install the new belt is removeing the front panel because the belt goes around the drum from the front. once you remove the old belt out put the new one in . the belt goes around the drum from the front and then to the motor and idle roller . you can reach the idle roller from the front left corner or from the back of the dyer? i like to install them from the back cause its more easy. in the back of the dyer where the hose goes connected to the blower is the top with four screws remove the hose from the blower tube and remove the four screws. after you remove everything you should be able to see the dryer motor and idle rooler put the belt over the motor first then over the idle rooler .always make sure when you do this the dyer is unpluged and after your done plug it back and turn it on to make sure it runs correctly . if it runs ok put everything back together again.
Dec 21, 2007 | Dryers
Dryers Logo
Top KitchenAid Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Oloyede Monsuru
Are you a KitchenAid Dryer Expert? Answer questions, earn points and help others
