Question about Hisense TL1700 17 in. LCD Television
Hisense TL1700 17 in. LCD - AC Adapter
I believe my AC Adapter for my TL1700 Flat Screen has gone bad. My tv was having problems turning on, I would mess with the power cord and eventually it would come on. Now, it won't come on at all. I disconnected the Power cord to try and see if I could see a problem. It rattles! I have tried every where I can think of to get a new one. Hisense website won't accept any emails, the phone # doesn't work, nor the fax #. I'm at a lose! I need my tv back!!!!
Please help!
  • 3 more comments
  • Mickey2007 Jun 06, 2008
    The power converter box gets hot and the tv stops working, IF we unplug it for a while sometimes it will start working againg. We have been unable to find a new cord for it. We have contacted the company but they fail to respond. Were can we get a new power source?
  • pcsf Jun 19, 2008
    I had their US 800 # and never could get through. I found one on EBAY and it only cost me $39.00 including shipping! Best deal yet!
  • clinton79 Jun 24, 2008
    The adapter was bad when we got it but at first you un plug for a few min and it start back up but now it do nothing burnt out need another one home phone # (317) 809-4921 email address clinton79@sprintpcs.com
  • Anonymous Sep 03, 2008
    need a power cord
  • raftr1 Dec 13, 2008
    Seems they need a new powersupply supplier. These are junk, mine rattles and will not power up. I am afraid they may be a fire hazzard so I am getting a new one also.
    I have found other PS for as low as $6.00.
I found their web site for the U.S. and found a 800 number,we called and they we bought a new coverter box.
Posted on Jun 19, 2008
I had the same problem, the blue name comes up then the screen black, I use a universal cord I purchase at walmart for $17.00 dollars, and the tv works great again, so before anybody go's and spend a lot of money and time trying to find out what's wrong just change the cord, there's a defect with the one the company made they get hot and blows out. wizartofoz@live.com
Posted on Dec 28, 2008
I have a Hisense LCD TV and it just went dark one day. When I turn it on the light turns blue and the screen come on and then goes off. Found out the power pack is bad. I could not find one any where. I finally went to a CB shop and bought a base power supply for CD's. Sense the TV is run on 12 volt DC the power supply will run it and it is filtered for noise it does not interfere or cause any screen problems.
The only thing is the size. And be sure to put it where it wont overheat.
Hope this helps.
Terry Baker
Posted on Dec 22, 2008
My original power supply quit working after one year. Replaced it with a 12V 4.5 amp power supply. It lasted about 1 year. Since the second unit was rated at 1.5 amps over the 3 amps required to deliver 35 watts, it should have been "loafing". Since I see so many replacement power supplies advertised on the Net, should I assume this will be a perpetual problem?
Posted on Oct 15, 2008
Go to Best Buy (or other "big box") and get a Universal PC adapter, brand name Targus. We had the same problem with having to unplug the adapter to let it cool. Cost about $100.00. Make sure that the input and output levels are compatible (take the old one with you).
Posted on Jun 14, 2008
    Genius:
  • Hisense Master
  • 1,673 Answers
If it is only the power cord that is bad, find out if there is a local TV shop that can fix it for you.
Jerry G.
Posted on May 14, 2008
I have a Hisense 55" model #50K23DG . The screen went out but the sound is perfectly clear. You can only see the image when you put a flashlight up against the screen. What could be the problem?
i assume this is an lcd, not led tv. the flourescent backlighting's inverter unit has gone out. its usually a seperate ic card, so it is repairable, if you can source the part cheap
Oct 17, 2016 | Hisense Televison & Video
What causing this problem
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Sep 23, 2014 | Hisense Televison & Video
Horizontal lines LED hisense tv
- Flickering screen
- Dim screen
- Slow start
Apr 05, 2014 | Hisense Televison & Video
What is ac adaptor
the ac adapter is what powers your game player, the cord that goes from wall outlet to your wii, maybe a bad connection or your adapter has gone bad
Mar 23, 2013 | Nintendo Wii Console
My hisense 50 inch lcd tv has picture but no sound.
If you still have back light, then the T-con is probably defective. If you don't have back light, then you either have a bad power board/inverter or a defective panel
Mar 20, 2013 | Hisense Televison & Video
Samsung n145 will not power up
Related to a Samsung Np-n145 Notebook PC:
Plug the laptop into power for 24 hours. See if the Battery charges up.
Next test, or have tested, the AC adapter (Charger) See if it is putting out 19 Volts -> DC.
Know someone with a multimeter? I can guide you in testing.
AC adapter is good? Things go downhill rapidly here.
The next problem could be a DC Power Jack.
The DC Power jack is the jack on the laptop, that you plug the AC adapter into,
1) The DC Power jack may be broken
2) The solder joints holding it to the motherboard may be cracked. Poor connection to motherboard.
The DC Power jack can be replaced, or it's solder joints re-soldered.
DC Power jack proves to be okay?
Power MOSFET's have gone bad. The next link, is an article that deals with bad Power MOSFET's in an HP laptop. Used for an example,
http://mayohardware.blogspot.com/2010/04/important-parts-on-dv6000-and-dv9000.html
Let's hope it's a bad AC adapter
Regards,
joecoolvette
Jul 18, 2012 | Samsung Notebook Np-n145 10.1" Laptop...
Hisense tv
The problem with these poorly made (in my view) sets is they are made in China and the company there has gone out of business by my count 2 times---they make poor sets for export and no parts or service literature so when you replace it consider another brand and something worth being repaired.
May 24, 2012 | Hisense LHDN32V66AUS 32 in. LCD TV
Can't identify power source warning
Your AC Adapter Power Cord is bad based on what you are telling in your request for help. You need to replace the AC Adapter Power Cord.
You can further isolate and verify by the following steps:
If you remove the battery, and plug in the power cord, but the computer will not boot up or work, then the power cord is bad.
If you have them both plugged in and you are running off the battery then the power cord is bad and it is not charging the battery. Eventually your laptop is not going to power on because the battery will be drained and cannot be recharged until you get a working Power Cord.
May 15, 2012 | Computers & Internet
I have a 20" flat
bad luck :(, problems is with the motherboard power circuit no option you need a repair sorry
Jan 31, 2011 | Philips Televison & Video
Hisense TL1700 17 in. LCD Television Logo
931 people viewed this question
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Electro Med Services...
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
