Question about Maytag MSD2351HEB 33" 23 Cu. Ft. Side-By-Side Refrigerator w/ Dual Cool System & PuriClean II Water/...
My maytag refrig will make ice but will not dispense it, crushed or cubes. Model # msd2351heb
  • pjmrktng Sep 07, 2010
    Could it be the control board? I checked the voltage at the connection to the auger motor and I have 120 volts to the motor but only about 28 volts to the control board, is that right?
  • 944 Answers
Hi sir/madam,
Your control board is the problem
What voltage should it be?
You should have 120 volts.
You need a volt meter or a multimeter to check voltage.
The unit should be receiving 120 volts AC from the line.
Check that the wires from under the unit to the control panel are ok.Check you have any water marks on the board of the circuit lining.Check the shape of transistors edges.It should be properly shaped.It should not be melted or heated.
Replace the board alone.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 08, 2010
  • 3,083 Answers
It sounds like a stripped auger in the icemaker, or possibly frozen cubes jamming up the chute. Read the following blog, it's about this exact problem and how to fix it:
http://forum.appliancepartspros.com/refrigerator-freezer-repair/7136-ice-maker-works-wont-dispense-cubes-crushed-ice.html
At this page are diagrams and part numbers for your model:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5171175
Good luck, thanks for using FixYa, and hope this gets things working again.
Good luck, hope this helps, and thanks for using FixYa.
Posted on Sep 07, 2010
My Maytag Fridge Ice Dispenser stuck on crushed ice, so no whole cubes can dispense. What can I do?
If you look at the bottom out side area of the ice cube bucket/auger assembly, you will see a metal rod going front to back. That is the shift rod for cubes/crushed ice. Make sure it is free. Then look at the back of the refrigerator where the end of that rod goes into a square hole. There is a magnetic solenoid in that hole that shifts the rod for selection. The solenoid coil is either bad, unplugged, or for some reason stuck and not shifting that rod. That's where the problems is located.
Apr 12, 2015 | Maytag Refrigerators
Cube is dispensing crushed ice instead
Check selection on door front. Also you can try to unplug and let it reset for a couple of minutes then plug back in
Sep 02, 2014 | Maytag Refrigerators
Water and ice cube dispenser working fine, crushed ice not crushing. 26 cuft side by side model MZD266SHES
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid. Crushed ice is the default position and the solenoid is energized to cube ice.
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
Feb 21, 2011 | Maytag MFI2568A Side by Side French Door...
MAYTAG ZIG-ZAG FRIDGE-FREEZER WANT DISPENSE WATER
Sounds tome that there is a short in the dispenser control circuit, keyboard or Control Board. If you had the model number I could help you better than this. I possibly would be able to walk you through this, Let me know, Sea Breeze
Nov 19, 2009 | Maytag ZigZagW / B Side by Side...
Dispenses crushed ice and will not dispense ice cubes
Aug 17, 2009 | Frigidaire FRS23H7CS Side by Side...
MAYTAG Ice control doesn't change from Cubed to Crush
If you prefer ONLY cubes , remove the ice bin and 1 or 2 screws hold the long rod attached to the bin . Without this rod , you'll only get cubes . With the bin removed , the square hole where the rod inserts in the rear freezer wall , you'll see a square , white , plastic "gate" . Asolenoid with a plunger , raises this gate for cubed ice and keeps it lowerer for crushed ice . Usually this "gate" plunger , rusts , thereby replaceing the solenoid and plunger would have to be done . Without the rod on the bin , the inner flap would open automatically , dispensing cubed ice .
Aug 16, 2009 | Refrigerators
Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Sep 25, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
GE Freezer Side Ice Dispenser
It isn't supposed to free wheel and the only solution that I know of is tumbler replacement. I have the same issue and am currently hunting replacement parts.
Jun 16, 2008 | Refrigerators
MZD2666KES will no longer crush ice. The dispenser light is on however it dispenses cubes only.
Did you pull the icemaker out and then have the problem?
If so, select 'Crush' and Slide the ice maker out and slide back in. You will notice a rod on the end (bottom left of the unit) slides into a little cubicle that moves up and down to provide either crushed or cubed.
May 21, 2008 | Maytag Refrigerators
Maytag MSD2351HEB 33" 23 Cu. Ft. Side-By-Side Refrigerator w/ Dual Cool System & PuriClean II Water/... Logo
71 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
