Question about Aqua Flo Aquaflo Flo Master Xp2 Spa Pump 1.5 Hp Two Speed
2006 flo-master xp2 pump failed. need to buy a replacement. mine is 230 volts. I have seen replacements online that are 240 volts. will this work for me? Thank you Dan
    President:
  • Aqua Flo Master
  • 1,378 Answers
Yes, either rating is really saying the same thing.
John
Posted on Sep 07, 2010
Need 2 complete replacements for a FLo Master spa pump 06630397-2 -do you carry and how much?
best is to see if they can be repaired, you need a experienced pump repair shop with free testing, these are hard pumps to work on. or keep a eye out on craiggslist.
Sep 29, 2013 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
I am looking for a Flo-Master XP2 by Aqua Flo. Modal 06630397-2. How much would it be?
A quick google search brings up a number of online sites between $340, and $430
Sep 22, 2010 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
I have a flo master xp2 / 48 frame / 230V / 2.5 hp / 2 speed spa pump. I accidentally hooked switched the high and common lines when wiring the electricity. The low line was done correctly, because they...
You shorted the 230 lines at the motor terminal board. If you are certain you have reset any and all breakers feeding the spa and that the 230V is getting back to the pump motor then you blew the winding leads as you shorted the motor. While it is possible a motor shop could repair the leads it is far more likely the damage caused will cause the price to be that or more of a replacement motor.
John
Sep 21, 2010 | Aqua Flo Aquaflo Flo - Master Xp2 2 Speed...
Where cani find replacement thru-bolts for an Aqua Flo XP2 pump?
A local motor repair shop would have the thru bolts. If you have at least one good one, you could match up the size, and cut soem threaded rod. Most motors this size use either 8-32,10-24,or 10-32 bolts. You can buy threaded rod at hardware store. Try to find galvanized, to prevent corrosion, or paint the part inside the motor if you cannot.
Aug 18, 2010 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
I am trying to find a replacement for ann XP2
the 2" is inside diameter so you more than likely have a 2" suction/discharge. The motor is probably rated 5hp, especially since it is both a circulation and jet pump.
Dec 01, 2009 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
I have a flo-master 06620390-2 pump that failed in my hot tub. Is there a quieter and more efficient replacement or should I replace with same?
You are generally better off replacing the pump with the same model. Hot tubs are noisy unless you have a really good insulation job. It is unlikely changing the pump will make it any different as far as noise goes. The flip side is that the manufacturer sized the pump to match the hydraulic load present within your specific tub and to provide the necessary flow rate to keep the water clean. It can lead to problems if you put in the wrong replacement unit.
If you would like a quote on the replacement motor and/or pump end, contact us thru www.arrowpools.net.
Sep 10, 2009 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
Aqua Flo Aquaflo Flo Master Xp2 Spa Pump 1.5 Hp Two Speed  Logo
180 people viewed this question
Top Aqua Flo Pool & Spa Experts
Jay Finke
Jay Finke
Gene Haynes
David Spradling
David Spradling
Are you an Aqua Flo Pool and Spa Expert? Answer questions, earn points and help others
