Question about Nokia N73 Cellular Phone
Requesting for bluetooth security code whenever it is connected to a computer
    Guru:
  • 277 Answers
When the first time you connected with the computer, did it and the computer asked for any code? if yes then the same code has to be applied again
Posted on Sep 07, 2010
Bluetooth for dummies
Bluetooth is a means of secure, bidirectional data transport between a host device and a client. If you consider the most common application of Bluetooth connectivity, the hands free headset, first the headset requests to become part of a Bluetooth personal area network (PAN) and the host, your phone, approves the request. At this point your phone and headset are paired. They enjoy a relationship where, when they are connected, they communicate exclusively with each other. No other device may become party to the relationship unless the host allows it. Bluetooth itself is really only another form of RF communications, similar to WiFi, but more secure.
Oct 28, 2013 | Radio Communications
Tip
How can I reset a Bluetooth?
<p>Using a Bluetooth device for mobile phone or computer, it asks for a PIN or security code. The connection between two Bluetooth devices is based on this code. If you're not interested in connecting both devices in the future, you need the code again. On reset the Bluetooth devices to remove the existing code and will prompt you to enter in case you decide to return to be switched. <br /> <p><br /> <p>1. Go to the menu on your mobile phone. Find the connection options and select the "Bluetooth" option. In the Bluetooth menu, you can see the devices currently associated with the phone. <br /> <p><br /> <p>2. Use the arrow keys of the phone to disconnect the device you want to select. You will see a number of options from the context menu. Choose "Remove / Reset PIN." This will switch back to the default security code, usually '0000 '. <br /> <p><br /> <p>3. Disconnect the connection of Bluetooth devices; simply select the 'Delete' / 'Remove' option on your mobile phone. When you pair the devices in the future you will be writing a new code. <br />
on Jun 26, 2011 | Cell Phones
I have bluetooth on my laptop and on my phone can you tell me if i can send pictures from my phone to computer, and if so how do i do it, many thanks marilyn
Hi Purpleking, This is Gheng, yes you can send your pictures from your phone into your computer i your computer have external bluetooth device its capable to transfer it... if u detect and see your computer just send it to your computer... God Bless!
Jun 02, 2011 | Acer Aspire One PC Notebook
Hi.... i am using nokia 2690 how to lock the cell with password ???? plz guide me sir :(
Select Menu > Settings > Security and from the following options:
  • PIN code request or UPIN code request-to set the phone to ask for your PIN or UPIN code every time the phone is switched on. Some SIM cards do not allow the code request to be turned off.
  • Security level > Phone-to set the phone to ask for the security code whenever a new SIM card is inserted into the phone. If you select Memory, the phone asks for the security code when the SIM card memory is selected, and you want to change the memory in use.
  • Access codes-to change the security code (default code is 12345), PIN code, PIN2 code, or restriction password.
Jan 16, 2011 | Nokia 2630 Cell Phone (Unlocked) - Black
My computer says everything is in order regarding bluetooth, however my phones ask me for passcodes; where do I get these. Thanks
Bluetooth Passcode key is the key which you assign, so if it's the first connection between your computer and bluetooth device, give anything like 11 or 11111 or 0000 whatever that suits you and you'll need to give the same code on both the computer and the bluetooth device. This is only for security which means to securely connect between the two devices only not with the unauthorized devices or unknown connections.
Good luck.
Thanks for using FixYa.
Jul 05, 2010 | Dell Dimension 8400 PC Desktop
BT350 Bluetooth Headset Headset: the bluetooth's name won't come up...
Turn your headset off. Then, press and hold the answer/end button until the indicator light is solid lit in blue. It is in paring mode. Now, make your phone's bluetooth application search for new devices. After a while, the BT-350 should appear on-screen. Select it and make the application proceed. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing proces is successful, the headset should enter stand-by mode. The pairing process is timed.If you fail to complete it, you'll have to start it over, from the phone turned off phase. Once paired, whenever both your headset and your phone's bluetooth radios are turned on, they should connect to each other automatically. Otherwise, just press the answer/end button, and the link should be done again.
Hope you are able to sort your problems out.
Cheers! Carlos
May 17, 2010 | Jabra BT350 Bluetooth Headset Headset
Palm Treo and Jabra bluetooth headset
Turn your headset off. Then, press and hold the answer/end button until the indicator light is solid lit in blue. It is in paring mode. Now, make your phone's bluetooth application search for new devices. After a while, the BT-350 should appear on-screen. Select it and command the application to proceed. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing proces is successful, the headset should enter stand-by mode. The pairing process is timed.If you fail to complete it, you'll have to start it over, from the phone turned off phase. Once paired, whenever both your headset and your phone's bluetooth radios are turned on, they should connect to each other automatically. Otherwise
Hop
May 16, 2010 | Jabra BT350 Bluetooth Headset Headset
I have a g router and i tried to set it to secure but i guess i jacked it up cause it knows its there but it wont hook up i went back into security settings but it doesnt work for me please help
Usually when people set security they don't pay attention to the security code that it generates or you create.
  • Remote back into your router
  • Go to the wireless menu
  • Find security settings
  • Turn off security
  • Connect to that connection with your computer again.
  • return to the wireless security settings
  • Use the wpa security. It will request a password or code you want to use
  • Return to your computer and reconnect (it should show a padlock on the connection now)
  • Double click the connection name and it will request the wpa key.
  • You can use other securities, but you need to use that same key on both the router and computer
Oct 20, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
H350 Bluetooth Headset Black
typically, the standard default security code is 0000. You can change the code once you install it, but I wouldn't......
Oct 09, 2008 | Motorola Mobility H3 Bluetooth Headset,...
Forgot my security code
The default security code for Nokia is 12345
IMEI: 356438012346609
Master code: 0631367461
Close all applications on your phone.
With your phone switched ON, remove the battery.
Then remove the SIM card.
Replace the battery without the SIM card and switch your phone on.
Type in the security codes (any code) until the phone request the Master code, when it does, leave your phone still, don’t use it for 15 minutes, then type in the Master code.
This is the code needed to reset the Security code, nothing else, and it’s for your phone only.
If it does not request the Master code, your phone will have to be connected to a computer via an unlock box to restore the Security code.
Sep 08, 2008 | Nokia N73 Cellular Phone
Nokia N73 Cellular Phone Logo
19 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
