Question about Refrigerators
Galaxy Refrigerator Model Number 183.91772. Light blinks constantly possibly indicating a problem. Fan on back seems to barely move back and forth in beat with the light. Not cooling AT ALL. Please help.
    New Friend:
  • 50 Answers
Replace the fan..
Posted on Sep 07, 2010
New filter installed. how to turn off "change filter" light
There is usually a reset button near the change filter light. Without the model number I cant tell you exactly where.Please comment me back so I can further assist.
Jul 30, 2011 | Refrigerators
Evap fan stops turning
It sounds like the sensor circuit in the motor is out or the motor is binding slightly so that the motherboard can't tell what the fan rpm is. Replace the motor and you should be ok. This is a common failure I have run in to.
Post back if you have any questions.
Thanks/Mike
Nov 07, 2007 | Hotpoint HSS25GFP Side by Side...
Model gss20iepcbb freezer side works fine ...fridge
on most units they have two controls refrigerator control is electric t-stat that runs compressor freezer control think of it as a door colder freezer door is barely open warmer freezer door all the way open all cooling coils are in the freezer and a fan moves the air to refrigerater side possible problem fan not running
door freezer control all the way closed
light switch broken light staying on door gasket not sealing tight find door switch press verify light shuts off and fan starts
look for torn or damaged door gasket can look from outside with light and see if gasket contacts case on all four sides
freezer is cold enough so compressor is ok hopr this helps good luck ron
Dec 10, 2009 | Refrigerators
Our Kitchenaid bottom freezer refrigerator smells "smoky". Not sure what to do. Unplugged it because I'm afraid of a fire. Seems to be smoking (barely) from the back bottom panel.
Yes, unplugging your unit was a smart move. Now you need to find out if it is the fan motor or the compressor. Hopefully it is just the fan motor, that is the least exspensive and easiest to fix. If it is the compressor it may not pay you to fix it you may be better off getting a new one.
If it is the fan motor do a search for "appliance parts" input your madel number and you will get a list of parts to choose from. Check a number of different sites as the prices can vary greatly.
If you pull out your refrigerator, take off the back panel cover, you should be able to easily tell which part got over heated.
Nov 22, 2009 | KitchenAid KBFA25ER Bottom Freezer French...
HI mAYTAG gc20c7c3ev SIDE BY SIDE FRIDGE seems very loud lately - fan it seems . Is this a problem looming? can it be solved. It used to "charge up" and then wind down every so often - presumably to...
I would check to see if the fan blades are hitting something or if ice has built up around the area causing the sound to change.Based on your model number your fan should not be changing speeds. You'll need to remove the rear cover in the freezer to access it and you can also inspect the coils below the fan for ice build up which should be a light frosting but not a heavy buildup. Test the evaporator fan here. http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Sep 22, 2009 | Maytag MSD2656G Side by Side Refrigerator
2001 GE side by side refrigerator model TGX26KRDA WW Beginning about a month ago the refrigerator temperature rose to 60 deg. F. Freezer remained well below 0 deg F. Checked baffle which was open and...
Is the fan that moves the air from the freezer to fridge running If there is a switch in cabinet somewhere the freezer door would contract it, with door open push in switch hear the fan both are good. Don't hear fan check evaporator or freezer fan and that switch it may be a duel switch open light closed fan run. Tricky there are light switches, when out light on or when switch is in its lights out
Mar 17, 2017 | GE Refrigerators
My kenmore built-in dishwasher "clean" indicator light is blinking instead of a steady light. Now nothing will work on the dishwasher. I've tried to cancel, along with other possibilities and nothing seems...
press heated dry and hi temp back and forth till all the lights light up then hit cancel. You have a bad heater if the clean light is blinking
Jun 15, 2009 | Dishwashers
Toshiba 57h81 red light blinking
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jun 14, 2017 | Toshiba 57H81 57" Rear Projection...
SONY WEGA TRINTRON MODEL KV36FV15 RED LITE FLASHING
The model number is KV-36FV15 and blinking is constant no pause
Aug 01, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Refrigerators Logo
374 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
